- Ilya
19 May 2018 20:23 - 19 May 2018 20:23 #69326
by Ilya
Replied by Ilya on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
5v - actually any vibro from mobile will be good.
first I stick it with double side duct tape, than found a stock place.
Last edit: 19 May 2018 20:23 by Ilya.
- mchaves
19 May 2018 20:32 #69327
by mchaves
Replied by mchaves on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
tks
- Theta2
21 May 2018 14:20 - 21 May 2018 14:25 #69354
by Theta2
Replied by Theta2 on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Hello guys,
i need your help and i really hope you'll have any idea or some tipps related to my issue.
I have connection interruptions, with different drones. The firmware on my irx-ir8m is the latest one and i've tested different ones.
I have the v1 and also v2, the issues happens only on the v2. First i've noticed it with a eachine e010, suddenly the drone was falling down. First i thought it's the same old issue, the way i treating my lipos, pulling them out on the cable
So it did not bother or wonder me.
Three weeks ago i've builded a tiny whoop with a beecore v2, same issue but because of the better software the beecore is using, most of the interruptions was handled by betaflight but sometimes it also dropped completely. On each interruption the lights of the beecore are changing, and from that i can say, it happens 10-15 times on a 250mah, 1s.
Yesterday i've finished the modifications on my new ldarc king kong 200gt, same issue. On this one, the last signal will be hold sometimes and sometimes it will be increased to 100% input, what makes the usually funny experience with the drone to an dangerous adventure. Today i had round about 10 crashes, 2 were really heavy, because of the interruptions. Yesterday one heavy, were the drone dropped from about 8 meters on the concrete. Yeah, this will become heavily expensive really fast, i think.
After trying a lot stuff in beta flight, deleting and reflashing the irx-ir8m i've noticed i have the preconfigured fixid 123456, what i've deleted then and rebound all the drones. On the beecore the issue disappeared almost completely on the gt200 i have still the same issue. On the e010 i havent tested long enough, there it happend only 2-3 times over some weeks.
Please tell me which information you'll need to maybe get clearer or closer with this issue. I'm not a complete noob, i'm new in the sport, maybe 1 year, have about 18 drones and spent in total a few weeks with it, on top, i'm a software developer, so most of the technical stuff is no rocket science for me, totally not.
I hope i can answer possible questions well and also that maybe someone has an idea and i will not crash 20 times a day because of technical issues.
Thanks in advance.
Daniel
Sorry, i forgot: today i was out with my rodeo110 also, there i did not really noticed it. One time i had the feeling, an specific input was not my one... but nothing else.
Thanks in advance.
Daniel
Last edit: 21 May 2018 14:25 by Theta2.
- sfjuocekr
14 Aug 2018 23:13 #70248
by sfjuocekr
Replied by sfjuocekr on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
What receiver are you using?
Funny enough I also have the E010, E011, E011c, E010s (FrSky) and 200GT... suffered from the E01x quadcopters dropping from the sky at random as well
Decided to swap the module, but nothing changed.
Then I hooked up the included receiver, it worked flawless on both modules...
I soldered a tiny FrSky SBUS receiver onto the E010s to test if it worked as well, I have not had it drop from the sky anymore. Under the FrSky options I had to adjust Freq-Fine to bind, after binding I figured out the mid-point and left it there (+42). This is the receiver I used: m.banggood.com/2_4G-8CH-D8-Mini-FrSky-Co...utput-p-1140478.html
The Bayang boards work somewhat better, up to 10m no problem but after that it gets unreliable.
I have an XM+ on the 200GT and it works fine, flying over farmlands around my house and had it failsafe once so far; when I was behind a big shipping container...
Right now I wired an OPlink Mini to the PPM out port, OpenLRS has a LOT more range
My question is, does anyone know what PCB connectors are used? They look like JST ZH connectors and SH connectors I have are too small...
- Dugenou
15 Aug 2018 11:16 #70257
by Dugenou
Replied by Dugenou on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I am French and it is not easy for me to express myself in English.
I have FrSky receiver and can not bind them.
V8FR-II and D4FR-II
I need your help, thanks.
V8FR-II and D4FR-II
- sfjuocekr
15 Aug 2018 12:27 - 15 Aug 2018 12:27 #70260
by sfjuocekr
Did you try to increase/decrease Freq-Fine until it binds?
Last edit: 15 Aug 2018 12:27 by sfjuocekr.
- Dugenou
16 Aug 2018 17:06 #70288
by Dugenou
If I select Frsky-V8 there are no settings.
reciever is V8FR-II HV
sfjuocekr wrote: Did you try to increase/decrease Freq-Fine until it binds?
17 Aug 2018 00:55 #70296
Replied by hexfet on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Use the Frsky protocol to try to bind to the D4 receiver. Try changing Freq-Fine from -120 to +120 in steps of 10 until bind is successful. (Leave Freq-Coarse at 0).
If that works, the nightly build firmware has the Freq-Fine option available in the Frsky-V8 protocol. Upgrade to nightly build to try with the V8 receiver.
- Dugenou
17 Aug 2018 15:53 - 17 Aug 2018 16:03 #70306
by Dugenou
it binds from +60 to +120
so I put in setting +90?
This for the D4R-II
Thank you very much, so I will try with the V8FR-2
Which file should I download for iRangeX iRX-IR8M V2?
hexfet wrote: Use the Frsky protocol to try to bind to the D4 receiver. Try changing Freq-Fine from -120 to +120 in steps of 10 until bind is successful. (Leave Freq-Coarse at 0).
This for the D4R-II
Last edit: 17 Aug 2018 16:03 by Dugenou.
- GabrielRB
18 Aug 2018 16:36 #70329
by GabrielRB
Replied by GabrielRB on topic IR8M battery mod
So, I decided make some upgrade on the battery of my IR8M.
I bought two Li-ion battery LCR18500 with 1100mAh (you can find others with more capacity) and installed inside the radio. Also I removed the current conector and change for a JST in order to make more easy to charge.
Very simple mod very usefull, now I have space on the battery deck to put a external module
- Charoupas
12 Sep 2018 22:47 #70857
by Charoupas
Replied by Charoupas on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I have a big issue with my controller.
Suddently it stopped working. It was working normally and now it doesnt power up anymore.
Basically it powers up for a sec and it closes. The batteries are not the issue, i measured them with multimeter.
When i switch on the transmitter, the blue led behind "IRangeX" logo works for a sec and then it stops. and then nothing happens.
Anyone maybe can help me (what to look)?
- Kilgore Trout
16 Sep 2018 01:40 - 16 Sep 2018 02:30 #70926
by Kilgore Trout
Replied by Kilgore Trout on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I'm having a major issue with my throttle, and can't find the answer anywhere. Just set this TX up today, updated to the latest nightly build. My issue is that the channel output for the throttle doesn't go above 0%. There is throttle response down to -125%, but above mid-stick, I'm not getting any more throttle, which means I can't fly.
I have the V2, and I'm setting this up for Plane. I don't think I have a bad sensor on the gimbal, i get a full -100/+100 when I look in the stick input menu under channel monitor.
Last edit: 16 Sep 2018 02:30 by Kilgore Trout.
- kbg
25 Jan 2019 09:49 #72522
by kbg
Replied by kbg on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
This transmitter is really really bad. I just got a RF measurement device and have been testing it on various VTXs with good results. I tested it on IR8M and i seems that at 150mw it only outputs at maximum 2.5mw. So that exaplains why it's having range issues for everyone. Stay away from this crappy transmitter, it's only good for flying tinywhoops inside.
- GabrielRB
26 Jan 2019 11:24 #72536
by GabrielRB
Replied by GabrielRB on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
If you get 2.5mw or you are measuring wrong or the radio is defective.
I got >2 km with this radio and stock frsky receiver.
Also make sure that you are using original firmware. I check with Vlad and the new firmware may can cause range issues due some problems in the code.
The problem of this radio is the same I told also in the RcGroups: bad quality control.
If you have luck as me, everything works good as expected. If no, you got a useless plastic part.
- mchaves
26 Jan 2019 15:00 #72539
by mchaves
Hello, I agree with what GabrielRB said, my radio is with firmware e33b5db and today I made 1.2km with an S500 and rx Flysky, last weekend 1.6km with Redcon Cm703 rx.
The radio is not the best, but it works very well and I'm satisfied with it, as we say in my country: "pura sorte" (pure luck). thank you:P
- kbg
26 Jan 2019 23:08 #72563
by kbg
I also tested with range check and I get 8 meters before connection is lost, so that calculates to 310m max at 150mw, but the drone actually drops out of the sky in about 50m in real flight.
Maybe I just got a dud but it seems a lot of people got duds.
- mchaves
27 Jan 2019 00:34 #72567
by mchaves
Upgrade you firmware and test
- david drones
07 Feb 2019 09:27 #72746
by david drones
Replied by david drones on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Bonjour pouvez vous m'aider s'il vous plait je n'arrive pas à trouver le fichier de téléchargement dont vous parler qui s'appelle( le firmware e33b5db) ma radio-commande Irx-Ir8m V2 perd la transmission à 90 mètres maximum je suiss en recepteur AFHDS A
Je vous remercie d'avance e bien vouloir m'aider
Hello can you help me please I can not find the download file that you are talking about (the firmware e33b5db) my radio control Irx-Ir8m V2 loses transmission to 90 meters maximum I in AFHDS A receiver
I thank you in advance for helping me
Ps / I am French
Ps / I am French
- david drones
07 Feb 2019 11:37 #72753
by david drones
Hello I thank you very much for your help and your links I just update the firmware that of February 7, 2019 and I am limited to 100 mwW while the original of September 2017 allowed me to go up to 150mW, but I confirm that with the original firmware I pass the connection to maximun 90 meters I read on your forum that some people who had the firmware e33b5db) had no problem and flew over several miles in flysky
( www.deviationtx.com/forum/6-general-disc...ocol?start=180#72746 )
can you help me please my radio-control Irx-Ir8m V2 loses the transmission to 90 meters maximum I am in receiver AFHDS A
Ps / I am French
Ps / I am French
- GabrielRB
07 Feb 2019 23:14 #72785
by GabrielRB
My recommendation for all people having range issues is roll back to original firmware.
With original firmware I get >2km with FrSky receivers
Time to create page: 1.622 seconds
- iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
