24 Jan 2018 03:06 #67098 by dc59
Replied by dc59 on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
That's wired, around 2:28 of this video:
this TX used T8SG FW,vbut I confirmed with Jumper(T8SG maker), this TX is not produced by Jumper.
24 Jan 2018 04:06 - 24 Jan 2018 04:32 #67100 by vlad_vy
Replied by vlad_vy on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
SeByDocKy wrote: For my radio only the switches A & B are 3-way ..... other are two-way
Can you say how exactly switches changing at Channel monitor? Have you AUX4 and AUX5 at Channel monitor?
SWA:
SWB:
SWC:
SWD:
Last edit: 24 Jan 2018 04:32 by vlad_vy.
24 Jan 2018 04:55 #67101 by vlad_vy
I don't understand logic of implementation iRangeX iRX-IR8M, really.
24 Jan 2018 07:48 #67106 by SeByDocKy
Replied by SeByDocKy on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
dc59 wrote: That's wired, around 2:28 of this video:
Can we update the IR8M with the T8SG NB ? Someone already tested ? If not I will probably .... I don't think I can brick the radio ?
24 Jan 2018 08:10 #67109 by dc59
I'm not sure,I don't have this TX!
24 Jan 2018 09:25 #67110 by antennenfreund
Replied by antennenfreund on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Does anyone have a left to the manual? Or can she upload? Unfortunately, there was no one with me. I can not tie the recipient who was there. What do I have to do? Could anyone help me, please?
Many Thanks
24 Jan 2018 09:31 #67112 by dc59
vlad_vy wrote: Surprise!!!
iRangeX iRX-IR8M has Jumper T8SG firmware (t8sg-v5.x.x-2017-09-19).
Sorry,I missed your post.
Do they used same LCD driver as T8SG⁇
24 Jan 2018 09:37 - 24 Jan 2018 09:42 #67113 by vlad_vy
SeByDocKy wrote: Can we update the IR8M with the T8SG NB ? Someone already tested ? If not I will probably .... I don't think I can brick the radio ?
I think you can flash T8SG nightly build. First backup Tx filesystem and check if it has firmware *.dfu file, in order you can return back.
If it will work, LCD driver is the same as T8SG.
Bear in mind you will have RUD and AIL reversed.
Last edit: 24 Jan 2018 09:42 by vlad_vy.
24 Jan 2018 09:45 #67114 by vlad_vy
antennenfreund wrote: Does anyone have a left to the manual? Or can she upload? Unfortunately, there was no one with me. I can not tie the recipient who was there. What do I have to do? Could anyone help me, please?
Many Thanks
You can use Devo 10 manual
www.deviationtx.com/user-manual
24 Jan 2018 10:04 #67115 by vlad_vy
If you want to calibrate sticks and knobs, I think you need toggle shoulder switches to you (open switch), since they connected to AUX4 and AUX5 lines.
24 Jan 2018 12:08 #67116 by SeByDocKy
Here the default built installed in case it's not the strict indentical with the T8SG build but I think it's the same build.....
24 Jan 2018 12:12 #67117 by SeByDocKy
I found that the two shoulder 2-way and the two pots are connected togather !!!!! as AUX4 & AUX5.... It's a bit crazy.... but in practice if you calibrate with the pot, it's well proportional to the input....
24 Jan 2018 13:36 #67118 by vlad_vy
I think outer 2-pos switches can be replaced by 3-pos switches without any mods. The shoulder 2-pos switches can be modded to "H" and "G" switches the same way as for T8SG.
24 Jan 2018 16:47 #67120 by antennenfreund
Has anyone already managed to tie the remote control to the receiver that is there? I can not do it !!!!! :(
Can nobody help me?
24 Jan 2018 17:32 #67122 by vlad_vy
I havn't iRangeX iRX-IR8M but from images it looks like it is Flysky AFHDS 2A receiver:
www.banggood.com/818CH-Mini-Receiver-Wit...rch&cur_warehouse=CN
If it doesn't bind, try to use "Freq Tune" protocol option with step 10-20.
24 Jan 2018 21:03 - 24 Jan 2018 22:44 #67131 by betoinbeta
Replied by betoinbeta on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Hello Folks.
Has anyone been experiencing the same issues with the awkward centering of the gimbals?
If you have experienced this, do any of you have a solution or an idea for a solution?
Last edit: 24 Jan 2018 22:44 by betoinbeta.
25 Jan 2018 01:59 #67140 by Gerry
Replied by Gerry on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Centering issue could still be mechanical, this is worth a read.
www.deviationtx.com/forum/6-general-disc...tick-centering-issue
FFS (Forever Fixing Stuff)
25 Jan 2018 16:30 #67150 by SeByDocKy
I just flashed the last Jumper T8SG NB and the radio boots ok but the backlight colored are inverted ......
So I guess the correct NB to flash is more the U7E ....
25 Jan 2018 17:01 - 26 Jan 2018 10:55 #67151 by vlad_vy
Try these two builds with different contrast setting (last number at archive name = 24 or 25) and say which will be better. I think it will be 24. Also, try with all contrast settings (off, 1-10).
Files deleted...
Last edit: 26 Jan 2018 10:55 by vlad_vy.
25 Jan 2018 17:39 #67152 by SeByDocKy
The built x24 is working flawless :) Thanks :)
Time to create page: 1.294 seconds
