25 Jan 2018 17:49 - 25 Jan 2018 19:02 #67153 by vlad_vy
Replied by vlad_vy on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
OK. Can you try next build with wider contrast range and report last contrast value before screen become black.
File deleted...
Last edit: 25 Jan 2018 19:02 by vlad_vy.
25 Jan 2018 18:56 #67154 by SeByDocKy
Replied by SeByDocKy on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
vlad_vy wrote: OK. Can you try next build with wider contrast range and report last contrast value before screen become black.
Attachment not found
It's completly black at 9 .... This one with the default 5 value offers more black than first tested release. I needed to set to 3 to retrieve same contrast as before
25 Jan 2018 19:02 #67155 by vlad_vy
Thank you, I have all necessary information.
26 Jan 2018 03:44 - 26 Jan 2018 03:45 #67170 by vlad_vy
Since iRangeX iRX-IR8M has different LCD, RUD and AIL reversed vs Jumper T8SG and it can use 4xAA battery, we need different build for iRX-IR8M. At least for some time.
You can find fresh iRangeX iRX-IR8M builds at Builds category:
www.deviationtx.com/forum/builds/7605-irangex-irx-ir8m-builds
Last edit: 26 Jan 2018 03:45 by vlad_vy.
26 Jan 2018 05:00 #67171 by antennenfreund
Replied by antennenfreund on topic iRangeX iRX-IR8M builds
To run the remote control with the new receiver you need a specific software for the receiver. Not every version works. It is very important to set the value to 40-41 as in the photo.
26 Jan 2018 06:16 #67173 by betoinbeta
Replied by betoinbeta on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Unable to Bind to a Bwhoop Pro using the Bayang Protocol.
I go to initialize with it and it just doesn't bind.
Tips anyone?
26 Jan 2018 06:19 #67174 by betoinbeta
Transmitter powering up problem
If I turn off the transmitter I can’t turn it back on.
I tried unplugging the AA battery module and it often times still doesn’t power up.
At first I thought I had a bad batch of batteries but it still does it even with a fresh batch.
Sometimes waiting for more than few minutes does power it back up.
Does anyone else have this issue and possible fix?
26 Jan 2018 06:58 #67176 by antennenfreund
Replied by antennenfreund on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Is Freq-Fine 40-41????
26 Jan 2018 07:31 #67178 by SeByDocKy
betoinbeta wrote: Transmitter powering up problem
Yes the same for me .... :( :(
26 Jan 2018 10:34 #67187 by vlad_vy
I don't understand what is the problem? Before update and after update.
26 Jan 2018 10:50 - 26 Jan 2018 10:59 #67189 by vlad_vy
Just for sure I rebuild IR8M, try flash this build:
File deleted...
Last edit: 26 Jan 2018 10:59 by vlad_vy.
26 Jan 2018 11:01 #67191 by vlad_vy
I replaced IR8M build at Builds section with fresh 2018-01-26.
26 Jan 2018 11:26 #67193 by SeByDocKy
My full video
with the flashing procedure... with the Vladvy build....
26 Jan 2018 16:26 #67199 by Theta2
Replied by Theta2 on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I've got my one today from banggood and i'm really disappointed, because of a missing button.
When i checked out all of the buttons i missed the click-sound when i pushed down the button S12 (trim backwards).
I've decided to open the radio and i was really really disappointed about what i found, see the attachment.
The second thing is, also attached, that the wheels on top have a totally different zero point. I can fix this, but the button is still missing afterwards.
I'm asking myself, how can someone forget to solder a button on the circuit board. To they not have a quality assurance what will push each button at least one time?
And, the wheels are not the one displayed on all product pages? They show chrome wheels of stainless steel or chromatted wheels what i got are wheels of white steel. So they attract me with a higher quality than i will get. All in all this this makes me feeling like i got ripped off. Thats not a good way to create long term customer relations. It's far away from that.
Did someone else have the same problem with the irangex irx-ir8m? a missing s12 button on the board?
26 Jan 2018 17:32 #67200 by SeByDocKy
Theta2 wrote: I've got my one today from banggood and i'm really disappointed, because of a missing button.
back luck for the missing DIP :( :( ... In the worst can can take one from the throttle ?
For the POT. you can take the allen key to re-install correctly the button ?
27 Jan 2018 18:52 - 27 Jan 2018 18:53 #67217 by antennenfreund
The range is VERY VERY BAD with me!
Fuck!
Last edit: 27 Jan 2018 18:53 by antennenfreund.
27 Jan 2018 19:00 #67218 by SeByDocKy
Did you select 100mW ?
27 Jan 2018 21:04 #67220 by Fernandez
Replied by Fernandez on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Or tune the center freq in prot options. It is known that especially AFHDS2a there are many cheap receivers out there with X-Tal off center reducing range a lot. (or not bind at all)
28 Jan 2018 06:53 - 06 Feb 2018 14:44 #67227 by vlad_vy
Can the toggle switch and rotary knob be made into separate functions ?
Yes, with some soldering work. You will need two diodes for that mod. The shoulder switches will be "H" switch and "G" switch.
First, disconnect shoulder switches from mainboard.
Next, we need two diodes connected: anodes to C.6 and catodes (black or white strip) to SWH1 and SWG1. And, SWH switch center pin connected to B.6 and SWG switch center pin connected to B.8.
SWH = C.6 ●--►|--●--○ \--● B.6
SWG = C.6 ●--►|--●--○ \--● B.8
Soldering points:
C.6 -> right horizontal trim positive direction contact = S8 (or throttle trim (left vertical trim) positive direction contact)
B.6 -> SWC switch center pin
B.8 -> SWB switch center pin
hardware.ini change:
;switch_types: 3x4, 3x3, 3x2, 3x1, 2x8, 2x7, 2x6, 2x5, 2x4, 2x3, 2x2, 2x1, potx2, potx1
;Add nostock if stock FMOD and HOLD switches have been removed.
  extra-switches = nostock
  extra-switches = 3x4
  extra-switches = 2x2
  extra-switches = potx2
sw.name__bus(MCU pin # )___diode__switch__bus(MCU pin # )
SW "H" = PC.6 (MCU pin 37) ●--►|--●--○ \--● PB.6 (MCU pin 58)
SW "G" = PC.6 (MCU pin 37) ●--►|--●--○ \--● PB.8 (MCU pin 61)
Last edit: 06 Feb 2018 14:44 by vlad_vy.
28 Jan 2018 11:30 - 28 Jan 2018 11:31 #67230 by antennenfreund
SeByDocKy wrote: Did you select 100mW ?
No, I also fly to 150 mw, like my friend. He also has this remote condition I have the R-xsr receiver in it .. He has the Flysky i6b.
He has no ranges problems .. I do. :(
I did that too!
Last edit: 28 Jan 2018 11:31 by antennenfreund.
Time to create page: 1.206 seconds
