TS8G Jumper won't bind to anything Spektrum!
- Nobby
16 Feb 2018 15:11 #67532
by Nobby
TS8G Jumper won't bind to anything Spektrum! was created by Nobby
Hi there!
I'm new to Deviation and thought I'd come here for a little advice.
My Jumper radio won't seem to bind at all to anything remotely resembling Spektrum. I've tried everything now but I'm at a loss as to what may be the problem
I have a feeling that somehow the file system may have been damaged but all the other receivers I have (FRSky, Flysky?, ect) and the Symas and JD509 are fine.
Any thoughts and advice would be much appreciated.
John
John
- Brett_N
17 Feb 2018 18:09 #67560
by Brett_N
Replied by Brett_N on topic TS8G Jumper won't bind to anything Spektrum!
Which spektrum recievers? Was it working before?
I've found this to work (although I'm fighting with a HBZ Carbon Cub at the moment)
Turn on TX
Put Bind Plug in RX
Put TX In Bind mode
Power up RX and give it a couple seconds
Power down RX and take out bind plug
Power down TX, then power it back up
Power up RX and you should be good to go.
Turn on TX
Put Bind Plug in RX
Put TX In Bind mode
- Nobby
18 Feb 2018 21:40 #67571
by Nobby
Replied by Nobby on topic TS8G Jumper won't bind to anything Spektrum!
Thanks for the suggestion but no:( ...that doesn't seem to work either I'm afraid!
It's not like I don't have a Spektrum radio (DX7s)but it would be nice to have the option to hook up to all my Spek receivers. Binds up to my FrSky and Turnigy /Flysky Receivers no problem. Baffled!
19 Feb 2018 01:23 #67574
Replied by hexfet on topic TS8G Jumper won't bind to anything Spektrum!
The dsm protocols use a different radio chip than the protocols that are working for you. Sounds like a problem with the cyrf6936 device in your tx.
- Brett_N
19 Feb 2018 02:13 #67575
by Brett_N
LOL - Nobby your a jinx
one of my 10 or so spektrums gave me hell at the airfield today and would refuse to apply throttle.
Weird - I wonder if you've got the issue of the random crystal value on the TX. I just ordered another jumper, so when it gets here I'll look and see if there's a difference between the 2 circuit boards. I still want to solder in a better crystal and see if it makes a difference
- Nobby
19 Feb 2018 06:39 #67577
by Nobby
LOL Sorry about jinxing you!
Never heard about the issue with the crystals on the circuit boards but given that my TS8G is one of the later models with a USB connection that I can use without taking the back off the radio, it would seem to make sense. Ahhhh well, another lesson learned. Let us know how you get on with the new TS8G.
Still happy with the Tx and using the Deviation software, in fact it has seemed to been a little easier to get in to it than with my Taranis but maybe the Taranis made my line of thought different!
- Nobby
19 Feb 2018 06:53 #67579
by Nobby
Is this a fixable problem or just one I'll have to live with? Is it really a problem given I have a perfectly good DX7S? To be honest no I don't think it is a problem. I don't think I'm losing out as I still feel that TS8G is a cracking little Tx for the money and for using on my toy grade quads. The difference it has made just to the flying qualities of these cheap machines is worth the money.
hexfet wrote: The dsm protocols use a different radio chip than the protocols that are working for you. Sounds like a problem with the cyrf6936 device in your tx.
- Brett_N
19 Feb 2018 14:49 #67587
by Brett_N
Hey have you tried binding to a DSM2 RX instead of a DSMX?
If it'll bind to a DSM2 that at least rules out an issue with your radio chip.
- Nobby
19 Feb 2018 23:45 #67602
by Nobby
Hi Brett
Just tried a DSM 2 and an Orange DSM 2 with 3 axsis stabilisation and no joy. Really baffled as on the YouTube everyone seems to bind up ok with their Spek stuff. Think I'll just resign my self to the fact that it isn't going to bind. Shame really as I wanted to test it out on a little Align 250 heli out I have with a DSM 2 already installed.
20 Feb 2018 02:32 #67603
might be fixable if you're comfortable opening the radio module and diagnosing the problem. Or get a replacement from the vendor.Nobby wrote:
then it's not a problemNobby wrote: Is it really a problem given I have a perfectly good DX7S? To be honest no I don't think it is a problem.
- Brett_N
20 Feb 2018 03:18 #67606
by Brett_N
Nobby - post up your INI file - I'll test it with my Jumper and spektrums for you.
If it works on mine, then it's probably a radio issue, which, given how new the jumpers are, whoever you bought it from (banggood?) should replace it.
- Nobby
20 Feb 2018 09:17 #67620
by Nobby
- Nobby
20 Feb 2018 09:24 #67622
by Nobby
Ok Brett. ..I'll have to get back to you on that as I'm not familiar with how to go about getting the ini file but from what I can gather it's like using Windows so it shouldn't be a problem.
As for sending it back to Gearbest. ...
I'll probably just buy another. It'll be a lot easier! !!
- Brett_N
20 Feb 2018 15:03 #67629
by Brett_N
Plug in your radio to USB, turn it on from main screen (hit ENT) and it will show up as a disk in windows explorer. Copy the .ini to windows folder, then upload it here.
DO NOT OPEN THE .INI in windows WITHOUT NOTEPAD++ -- it will ruin the .ini structure.
- Nobby
20 Feb 2018 23:34 #67642
by Nobby
Right Brett....
Seem to have come to a hurdle. It would appear that I have not got the correct size of USB cable needed for the Jumper. I thought I did, but I haven't!
I'll source one from somewhere then I'll upload the ini file for you to have a look at. Not sure what type of USB it is? Seems smaller than the one I use on my quads. Micro USB?
- Nobby
19 Mar 2018 12:32 #68207
by Nobby
Ok i'm back!
Managed to source a cable for the Jumper and i've copied and pasted the radio files to the desktop.
Now....cant find any file that is called "ini" so what am i looking for?
Regards John
Regards John
Time to create page: 0.275 seconds
- TS8G Jumper won't bind to anything Spektrum!
