Range Test and Recommended Power Level
- mgilbert
11 Mar 2018 03:23 #67996
by mgilbert
Range Test and Recommended Power Level was created by mgilbert
I just finished building an Align 470LP (380 sized) helicopter. I used two Lemon DSMX satellites - one on the tail boom, and one hanging below the side. I have a white Devo 10 radio running Deviation 5.0.
What power level do pilots use with the Devo 10 for this size helicopter?
And, what kind of range should I see when using the 100 micro-Watt range test feature on the Devo 10?
Thanks...
Thanks...
- sbstnp
12 Mar 2018 03:53 #68018
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Range Test and Recommended Power Level
If you stay close, lets say 100m then 10mw to 30mw should be more than enough.
For range test look for at least 30 paces. I usually get around 40 to 45 on mine with the standard 2dBi antenna in a location without wifi hotspots. In noisy locations you might get less.
mgilbert wrote: I just finished building an Align 470LP (380 sized) helicopter. I used two Lemon DSMX satellites - one on the tail boom, and one hanging below the side. I have a white Devo 10 radio running Deviation 5.0.
Thanks...
Devo 10 + 4in1
Time to create page: 0.789 seconds
- Range Test and Recommended Power Level
