Need Help Binding to my FrSky tinyFish
- GMalatrasi
20 Mar 2018 22:06 #68231
by GMalatrasi
Need Help Binding to my FrSky tinyFish was created by GMalatrasi
I have a Boldclash BWhoop B05 which uses the tinyFish FC and an FrSky Rx, so I ordered myself a Jumper T8SG to use with it and with the few other hobby grade drones I have.
Unfortunately I've been unable to bind to the B05 or any other drone i have for that matter.
I followed the instructions that came with the Boldclash, vague as they may be, and got nowhere.
I looked up YouTube videos and still no luck.
I have to believe someone else here has a tinyFish FC and a T8SG.
Please let me know if you have any ideas that could help me.
Any help would be greatly appreciated.
- Elmtree
22 Mar 2018 05:04 #68259
by Elmtree
Replied by Elmtree on topic Need Help Binding to my FrSky tinyFish
Are you using the frsky protocol, not frskyX?
- GMalatrasi
22 Mar 2018 11:19 #68270
by GMalatrasi
Replied by GMalatrasi on topic Need Help Binding to my FrSky tinyFish
I tried both. Which one do you think I should be using?Elmtree wrote: Are you using the frsky protocol, not frskyX?
- GMalatrasi
25 Mar 2018 19:47 #68349
by GMalatrasi
Bump for some advice...
- Elmtree
25 Mar 2018 20:15 #68351
by Elmtree
You should be using frsky. Do not use frskyX. Sorry for being unclear
- GMalatrasi
25 Mar 2018 20:20 #68352
by GMalatrasi
No worries. I was already using FrSky so that wasn’t the issue.
Elmtree wrote: You should be using frsky. Do not use frskyX. Sorry for being unclear
- GMalatrasi
28 Mar 2018 01:12 #68376
by GMalatrasi
Anyone have any ideas?
- Wene001
29 Mar 2018 21:34 #68410
by Wene001
Replied by Wene001 on topic Need Help Binding to my FrSky tinyFish
Try tuning the fine variable in the frsky protocol options. Try -40 or +40
- GMalatrasi
29 Mar 2018 22:18 #68413
by GMalatrasi
Thanks, I’ll give it a try.
Wene001 wrote: Try tuning the fine variable in the frsky protocol options. Try -40 or +40
- GMalatrasi
30 Mar 2018 15:52 #68426
by GMalatrasi
Tried the fine frequency from -40 to +40 in 10 point increments.
Every single one had the same results.
- I plug the battery in while holding down the bind button on the RX board.
- I get a steady gree light.
- I hit bind on the TX
- I get a blinking red light on the RX board.
Any other ideas?
Any other ideas?
- Elmtree
30 Mar 2018 15:54 #68427
by Elmtree
Do you need to change the receiver serial port on the craft?
- GMalatrasi
30 Mar 2018 16:15 #68428
by GMalatrasi
Is that something I do in betaflight?
Elmtree wrote: Do you need to change the receiver serial port on the craft?
- GMalatrasi
30 Mar 2018 19:46 #68429
by GMalatrasi
So i was playing around in BetaFlight looking for anything that seemed out of place, when I turned on the transmitter to check it's firmware version.
I noticed the channel monitors looked different from before so I moved the sticks and the bars moved accordingly!
I have no idea how but it was working. But after I unplugged the FC and plugged it back in, the transmitter was no longer working.
Cycled everything again but no go.
Not sure why it worked that one time, but I can't make it happen again.
- GMalatrasi
31 Mar 2018 01:40 #68433
by GMalatrasi
Got it working!
No real clue what made it finally work.
My best guess is that it needed the arm switch in betaflight.
Time to create page: 1.094 seconds
- Need Help Binding to my FrSky tinyFish
