Eachine Flyingfrog q90, Devo 7e Connection Problem
- Brotchip
22 Apr 2018 08:48 - 25 Apr 2018 15:52 #68789
by Brotchip
Eachine Flyingfrog q90, Devo 7e Connection Problem was created by Brotchip
I´ve recently bought the Eachine Flyingfrog q90, with the DSM2 receiver, and because I already have got the Devo 7e transmitter, flashed with the Deviation FW: devo7e - v5.0.0, I wanted to use it to fly the quad.
But the Problem is:
When I try to bind it with DSMX the LED on the receiver board first rapidly flashes and then stays on, just like the manual describes it, but the motors won´t spin.
I connected the quad to my computer and looked into Betaflight, in the receiver tab nothing moves, so I assume there is no connection?
I checked in the configuration the receiver settings, but it was also set to the right receiving mode: "Serial receiver(SPEKSAT, SBUS, SUMD)" and serial receiver: "SBUS".
I´m aware that this quad also has an FPV system but I want to get it flying first.
I´m pretty new to this so don´t really know what to do next, would appreciate any help, thanks!
UPDATE:
So still my first post I´ve tried some things so I wanted to give you an update:
I´ve still set the receiver mode to "Serial receiver(SPEKSAT, SBUS, SUMD)" but switched the serial receiver setting to the options "SBUS, "Spektrum1024" and "Spektrum2048" and tried them with the transmitter protocols "DSM2" and "DSMX".
I´ve tried switching the serial Port in Betaflight to "UART2" / "UART3", same result with the different UARTs.
I´ve even tried to resolder the UART cable from the receiver to the other UART port like shown in this video:
The DSM2 receiver is the CYPRESS CYRF6936.
But the Problem is:
UPDATE:
Last edit: 25 Apr 2018 15:52 by Brotchip. Reason: Update
- wasp09
04 May 2018 17:51 #69031
by wasp09
Replied by wasp09 on topic Eachine Flyingfrog q90, Devo 7e Connection Problem
I have 2 ARF and 1 BNF frogs. I am using DSM2 sat RXs on the ARFs, and the BNF came with DSM2 RX connected to sbus.
Which one do you have? And how do you connect your RX to the FC?
If you are using sat/sbus, make sure com port of BF is configured for serial first. The BNF frog DSM2 RX would switch to PPM mode after a few seconds if your TX is not ready fast enough. You have to get your TX ready first. The binding instruction is wrong.
- Eachine Flyingfrog q90, Devo 7e Connection Problem
