Two different servo speeds in one config ?
- dado099
29 Apr 2018 14:30 #68921
by dado099
Two different servo speeds in one config ? was created by dado099
As the title say I would like to set two different speeds on the same servo with a switch.
Is it possible ?
At the moment I'm running two configs, with a different servo speed, but it's not a cute solution.
Any help ?
Is it possible ?
Any help ?
- dado099
01 May 2018 10:17 - 01 May 2018 10:17 #68950
by dado099
Replied by dado099 on topic Two different servo speeds in one config ?
I suppose there is no solution,
can you confirm ?
can you confirm ?
Last edit: 01 May 2018 10:17 by dado099.
01 May 2018 10:20 - 01 May 2018 10:21 #68951
Replied by FDR on topic Two different servo speeds in one config ?
I think you can use two identically configured virtual channels but with different servo speeds, and then switching between the two on the output channel.
Last edit: 01 May 2018 10:21 by FDR.
01 May 2018 14:04 #68953
Replied by vlad_vy on topic Two different servo speeds in one config ?
Virtual channels havn't settings except name.
Time to create page: 0.024 seconds
- Two different servo speeds in one config ?
