Corona protocol issue (fixed)
- Hoodooguru
30 Jul 2018 01:10 - 30 Jul 2018 13:13 #69986
by Hoodooguru
Corona protocol issue (fixed) was created by Hoodooguru
Devo 8s with Banggood 4 in 1.
Corona rx are not binding, have tried everything I believe.
Tested all 4 rf chips, all working and binding using other protocol and rx, including cc2500. Frsky X8R is binding and working including telemetry.
Tested several Corona rx.
Tested swamping.
Tested fine tuning from 0 to +/- extremes.
Tested std binding proceedure and every other combination imaginable.
Get led double blink with bind button in.
Get flashing after turn off/on
Evering seems as it should be, just never get final link or solid led.
Have been using Corona for years with Corona TX module on ppm with Hitec, JR and Devo Tx's (have both JR and Futaba modules, positive and negative shift). Have at least a half dozen Corona rx 4 6 and 8 channel.
If anyone is successfully using Corona protocol what Deviation build are you using and what bind method?
At this point I can only asume something is wrong with Deviation protocol.
Any help most appreciated.
John
Tested swamping.
John
Last edit: 30 Jul 2018 13:13 by Hoodooguru.
30 Jul 2018 02:16 #69989
Replied by hexfet on topic Corona protocol issue
I've just made a fix for Corona protocol. Please try with tonight's nightly build.
- Hoodooguru
30 Jul 2018 02:43 #69990
by Hoodooguru
Replied by Hoodooguru on topic Corona protocol issue
Will do.
Thanks so much, will let you know how it goes.
Cheers
John
Cheers
John
- Hoodooguru
30 Jul 2018 13:12 #69995
by Hoodooguru
Thanks hexfet, all good. Was able to bind several Corona rx with ease.
Just need you to confirm another change I have not seen. Instead of arrows in top right corner to select different pages, there is now a numbered list, correct?
Cheers
John
Cheers
John
31 Jul 2018 00:51 #69999
That's a difference between the nightly builds and 5.0 user interface.
Time to create page: 0.034 seconds
- Corona protocol issue (fixed)
