T8SG v2 plus stuck
- Tang10
01 Oct 2018 22:15 #71130
by Tang10
Replied by Tang10 on topic T8SG v2 plus stuck
I'm in the same boat with my radio......its in RAW format. I have tried everything I can think of. Tried Linux fdisk and even bought a format utility, but o luck.
Jamie
Jamie
02 Oct 2018 04:56 - 02 Oct 2018 05:07 #71136
Replied by vlad_vy on topic T8SG v2 plus stuck
It looks like flash memory chip can't be writed. It can be faulty flash memory chip or chip connection issue. I think T8SG has the same connections as Devo F4 (F7):
With Devo F4 it can be (pin connections from SST25VF032B to STM32F103RBT6):
1. CE = SPI1_CE (PB2, pin 28)
2. SO = SPI1_MISO (PA6, pin 22)
3. WP = 3.3V (VDD_4, pin 19)
4. VSS = GND (VSS_4, pin 18)
5. SI = SPI1_MOSI (PA7, pin 23)
6. SCK = SPI1_SCK (PA5, pin 21)
7. HOLD = 3.3V (VDD_4, pin 19)
8. VDD = 3.3V (VDD_4, pin 19)
Check flash memory chip soldering and traces. It's 8-pin chip to the left from MCU. Check connection for pin 1 (chip select) and 3 (write protect, has to be connected to pins 7 and 8, =3.3V).
Last edit: 02 Oct 2018 05:07 by vlad_vy.
- zulmohd
02 Oct 2018 05:25 #71138
by zulmohd
Replied by zulmohd on topic T8SG v2 plus stuck
Thanks again vlad_vy,
I am going to the distributor later, see if they can do anything for me 1st (They'd better). If can't, then I will open up and check the continuity between the pins.
- Tang10
02 Oct 2018 16:22 #71149
by Tang10
If the flash chip is damaged, can I just buy a new chip and solder it in?
Seems like a easy solution
- aMax
02 Oct 2018 18:03 - 02 Oct 2018 18:07 #71151
by aMax
Replied by aMax on topic T8SG v2 plus stuck
I doubt that this is the solution for all.
On my 7e the whole 2MB backup( Walkera firmware) could be writen in DFU mode and be saved thereafter to compare.
But no formating after the Deviation firmware flash until the file system part was revised.
Since then the transmitter works as usual like the four
years before that mishap
But try......
Edit : Any feedback will take my attention.
But try......
Last edit: 02 Oct 2018 18:07 by aMax. Reason: edit
- Tang10
02 Oct 2018 21:26 #71153
by Tang10
Well boys and girls, I have success. Can't 100% say what my fix was, but applied a little heat to the flash chip with the solder iron and a small amount of solder for good measure. Then used Windows Disk Management tool to delete the volume and then formatted the flash in Disk Management.
Mine is now alive after 2 plus weeks of being dead!
Jamie
Jamie
- zulmohd
02 Oct 2018 21:43 #71154
by zulmohd
Thanks for sharing the update Tang10. Will take note of this useful step together with those we have tried from this very helpful community.
For my case, i got a 1 to 1 replacement from the distributor. Hopefully can fly........thanks again everyone
03 Oct 2018 04:04 #71157
Electronics is the science of contacts...
- aMax
03 Oct 2018 09:32 #71158
by aMax
Congrats.
- Tang10
05 Oct 2018 12:42 #71185
by Tang10
My problem now seems after loading the nightly build and file system on the screen seems fine, but after a few seconds/minutes the characters on the screen go unreadable.
Any thoughts?
Any thoughts?
- Ultracon
01 Nov 2018 19:30 #71522
by Ultracon
Replied by Ultracon on topic T8SG v2 plus stuck
A lot of the time your drive will have hidden items. If you click to show hidden items it should pop up.
- BIllyU
09 Mar 2019 20:55 #73291
by BIllyU
Replied by BIllyU on topic T8SG v2 plus stuck
Similar problem with IrangeX IR8m, but the build with bulk flash memory erase didn't fix it. The disk is not recognized by PC. Thanks
- Cricket
27 Apr 2019 19:19 #74155
by Cricket
Replied by Cricket on topic T8SG v2 plus stuck in USB mode
Hi, did you resolve the issue? I just did the same thing! I did a backup of the original firmware before I did the new fw update hopefully that may help? I dont know what steps to take. I unfortunately chose the wrong update as did you. I have the t8sg v2 plus but chose the t8sg v2 instead. Radio is now stuck in usb mode.
- Moeder
27 Apr 2019 20:25 #74156
by Moeder
Replied by Moeder on topic T8SG v2 plus stuck in USB mode
Just reflash with t8sg_v2_plus firmware, and don't forget to copy over filesystem. Or use Java deviation_uploader and do full install with the zip file.
- whoopa76
03 Aug 2019 08:04 #74825
by whoopa76
Replied by whoopa76 on topic T8SG v2 plus stuck in USB mode
1. I connect from t8sg v2 plus model to my computer.
2. turn on the transmitter.
3. there is USB mark on the transmitter LCD screen.
4. Some USB drive pop up in my comuter.
5. I cannot read this drive. but also it does not work with mouse right click button.
6. I cannot format and erase this drive.
7. I tried to updated lastest firmware on transmitter. but result is same.
03 Aug 2019 08:48 #74826
Replied by vlad_vy on topic T8SG v2 plus stuck in USB mode
Try to flash custom build, run it once and try to format USB drive.
www.deviationtx.com/forum/3-feedback-que...2-plus-bricked#74684
- Ultracon
07 Aug 2019 01:52 #74835
by Ultracon
Replied by Ultracon on topic T8SG v2 plus stuck in USB mode
Go back to the drive window and make sure you have clicked to show "Hidden Drives". It will be there. Mine was. Then proceed.
- I.A.G.A
29 Aug 2019 12:33 #75054
by I.A.G.A
Replied by I.A.G.A on topic T8SG v2 plus stuck
Hello, I've the same problem, I was persisting to do the upgrade with the erase build and after many times and try and error later it was succesfull. But, now I'ts the same problem here again. First after the upgrade was succesfull and I was copying the files onto the drive I've had several times needed to copy all of the content. Here are several problems and errors about copying some files. Finally all of the files are copied but on the next startup of the device the same problem was again overthere, all of the content was lossed and I need to redo all of that without succes. Please can anybody help me about this issue? Many thanks in advance and kind regards!
- starleas
20 Jan 2020 03:01 #75759
by starleas
Replied by starleas on topic T8SG v2 plus stuck in USB mode
20 Jan 2020 04:11 - 20 Jan 2020 04:12 #75760
It looks like you have a problem with LCD. First, try to reseat LCD cable. Next, try to renew USB filesystem from firmware archive.
Last edit: 20 Jan 2020 04:12 by vlad_vy.
Time to create page: 0.202 seconds
- T8SG v2 plus stuck
