Devo 12S Upgrade Failed
- DanKhuu
05 Sep 2018 10:35 #70658
by DanKhuu
Devo 12S Upgrade Failed was created by DanKhuu
I am trying to upgrade my Devo 12s with Deviation 5.0.0 but it keeps failing. I followed both methods using Walkera Dfuse and Deviation Uploader without any luck.
I tried the official release(deviation-devo12-v5.0.0.zip) as well as the nighly build(deviation-devo12-v5.0.0-3bcbb8f), when I reboot the Tx, its stuck in USB mode. I can browse to the USB drive on my computer.
When upgrade using the Deviation Uploader 0.8.0, I can see the progress bar goes 1/3 of the way then a windows popup "Copy Completed" but when I reboot my Tx it's stuck in the USB mode.
I also tried using the Walkera Dfuse 2.31, the Firmware upgrade went fine but I keep getting the below error Upgrading the Library
This error for Verify
I since restored the stock Firmware 1.5A 100mw without any issue
Any helps would be greatly appreciated, Its doing my head ins
Dan
Dan
- DanKhuu
18 Oct 2018 02:30 #71434
by DanKhuu
Replied by DanKhuu on topic Devo 12S Upgrade Failed
Anyone out there can help?
- magic_marty
18 Nov 2018 06:53 #71783
by magic_marty
Replied by magic_marty on topic Devo 12S Upgrade Failed
You might try doing a complete format of the 12s drive ..
Mine got corrupted once and i had to completely format and reinstall everything.
Hope you get it sorted out i know how bad it sucks when a update fails..
- DanKhuu
19 Nov 2018 09:35 #71807
by DanKhuu
OMG finally someone reply
I am still struggling with this LOL...How do I do a complete format and reinstall everything?
Thanks in advance
Thanks in advance
19 Nov 2018 14:05 - 19 Nov 2018 14:15 #71808
Replied by vlad_vy on topic Devo 12S Upgrade Failed
I don't think it will help. You can't write DFU library (filesystem 'media' folder) into parallel flash memory 16M (S29GL128P10TFI01).
Try to flash original Walkera firmware and library. If it fails, you have damaged parallel flash memory 16M chip.
Or you have problem with parallel flash memory chip CE or WE lines.
Last edit: 19 Nov 2018 14:15 by vlad_vy.
- DanKhuu
20 Nov 2018 06:49 #71821
by DanKhuu
Thanks vlad_vy
Correct, I can flash the stock FW but not the Library now everytime I switch to programming mode I get the fuzzy horizontial line screen, somehow I lost the Walkera programming....screen
How do I work out if S29GL128P10TFI01 is faulty? What is WE line sorry?
Looking like another project in the pipeline to replace the parallel chip. Is there another compatible chip or will I need the exact one?
20 Nov 2018 09:04 - 20 Nov 2018 09:09 #71823
CE - chip enable (pin 32)
WE - write enable (pin 13)
http://www.spansion.com/Support/Datasheets/S29GL-P_00.pdf
www.deviationtx.com/wiki/hardware/devo12
Last edit: 20 Nov 2018 09:09 by vlad_vy.
- DanKhuu
20 Nov 2018 12:39 - 20 Nov 2018 12:40 #71825
by DanKhuu
Thanks again Vlad_vy very good information
Do you know of a way to troubleshoot the chip without removing it? or at lease find out CE or WE lines faulty or not?
Last edit: 20 Nov 2018 12:40 by DanKhuu.
- merc4now
20 Nov 2018 18:07 #71830
by merc4now
Replied by merc4now on topic Devo 12S Upgrade Failed
FOLLOWING
as I'd like to dust my f12e off and see if its possible to use for frsky stuff. and actually make use of the transmitter.
- DanKhuu
21 Nov 2018 12:44 #71834
by DanKhuu
What are you planning to you with your f12e installing module?
merc4now wrote: FOLLOWING
- DanKhuu
24 Nov 2018 09:56 - 24 Nov 2018 10:00 #71869
by DanKhuu
I am thrill! After struggling for so long trying to figure out what was wrong with my TX. I finally fixed it by retouched on all the pins on the IC
a BIG THANK YOU to vlad_vy for pointing out the parallel flash.
Last edit: 24 Nov 2018 10:00 by DanKhuu.
Time to create page: 0.120 seconds
- Devo 12S Upgrade Failed
