FS-A8S 1 xSuccess & 1 xFailure but why ?
- charlied43
11 Sep 2018 20:43 #70810
by charlied43
FS-A8S 1 xSuccess & 1 xFailure but why ? was created by charlied43
So I have 2 identical RTF quads: HGLRC / XJB 145
Both quads have identical recievers installed ( FS-A8S Flysky )
I also have 2 identical Taranis 9xd Plus
One with a iRangeX 4 in 1 : tinyurl.com/y9q5desc
Other with a ' Ytech ' 4 in 1 Module ( unbranded + no ABS JR case) : tinyurl.com/yaux5efy
Both radios have been flashed with " opentx219-14296db-multi-2016-12-20-taranis-plus "
Both radios display the Multi Language menu under éxternal RF' Bind
Both Recievers display SOLID LED confirming the bind.
Only one quad picks up the Radio signals when checking in Betaflight
Anyone Please help!
Anyone Please help!
- propnut
13 Sep 2018 06:18 #70867
by propnut
Replied by propnut on topic FS-A8S 1 xSuccess & 1 xFailure but why ?
Surely the right place to ask this question would be the openTX forums ???
13 Sep 2018 07:56 #70869
Replied by vlad_vy on topic FS-A8S 1 xSuccess & 1 xFailure but why ?
Most likely you need fine tune module frequency for AFHDS 2A protocol. Ask how to do it at "DIY Multiprotocol TX Module" forum or "OpenTX" forum.
- propnut
13 Sep 2018 12:00 #70874
by propnut
Actually I just looked on my Taranis. Make sure that both of them are set to PWM/IBUS or PWM/SBUS. You will see this setting to the far right of your options.
If that still doesn't work take both receivers out and connect them to normal servos. If they both work outside of the quads then maybe you have a duff controller in one of the quads.
- Leo Li
13 Sep 2018 15:38 - 13 Sep 2018 15:40 #70885
by Leo Li
Replied by Leo Li on topic FS-A8S 1 xSuccess & 1 xFailure but why ?
DIY-Multiprotocol-TX-Module FLYSKY AFHDS2A bind problem has been fixed on v1.2.0.22 or above version.
Please read github.com/pascallanger/DIY-Multiprotoco...Protocols_Details.md
- under FLYSKY AFHDS2A - 28 section "RX_Num is used to give a number a given RX. You must use a different RX_Num per RX. A maximum of 16 AFHDS2A RXs are supported."
Last edit: 13 Sep 2018 15:40 by Leo Li.
- charlied43
13 Sep 2018 15:51 #70886
by charlied43
Replied by charlied43 on topic FS-A8S 1 xSuccess & 1 xFailure but why ?
Thanks, yes the RX which bound AND gives signals in Betaflight can be switched from S to iBus by holding the bind button, the RX which is bound but doesn't give signals does not react to holding BIND. Interesting
- charlied43
13 Sep 2018 15:53 #70887
by charlied43
Isn't that what I already have ? If not do I need to flash the JR module?
Cheers
Cheers
- charlied43
13 Sep 2018 16:02 - 13 Sep 2018 16:03 #70888
by charlied43
http://tinypic.com/r/344uo2c/9
Which release and how ?
Cheers
Cheers
Last edit: 13 Sep 2018 16:03 by charlied43.
- Fernandez
13 Sep 2018 18:02 #70890
by Fernandez
Replied by Fernandez on topic FS-A8S 1 xSuccess & 1 xFailure but why ?
Take care sbus need to be connected to inverted Rx Uart. (or dedicated labeled sbus port) Howver Ibus can use any Rx uart univerted, but not work on Sbus input pin.
For full Ibus telemetry and Rc signals, over just one pin in bidirectional mode, you have to connect to a Uart Tx pin and make sure use correct port config in
CLI:
serial 1 4160 115200 57600 115200 115200
see here:
github.com/betaflight/betaflight/wiki/Si...Sky-(IBus)-telemetry
CLI:
see here:
- Leo Li
14 Sep 2018 08:50 - 14 Sep 2018 09:02 #70897
by Leo Li
You need download lastest source v1.2.1.0 from
github.com/pascallanger/DIY-Multiprotocol-TX-Module
then following documents 5.Compiling and programming the module->STM32 Multiprotocol Module complie lastest version hex file.
If you don't know how to compiling and programming the module, please ask for help in RCGroup www.rcgroups.com/forums/showthread.php?2...tiprotocol-TX-Module
Last edit: 14 Sep 2018 09:02 by Leo Li.
- charlied43
14 Sep 2018 10:11 - 15 Sep 2018 14:48 #70898
by charlied43
Yes im familiar with compiling no worries, my question was which version on the release page? There are 8 different iterations
Also which dongle should I use out of these 2..
USB TTL or
FTDi 232 ?
USB TTL or
FTDi 232 ?
Last edit: 15 Sep 2018 14:48 by charlied43.
Time to create page: 1.503 seconds
- FS-A8S 1 xSuccess & 1 xFailure but why ?
