No throttle output past mid-stick?
- Kilgore Trout
17 Sep 2018 02:42 #70938
by Kilgore Trout
No throttle output past mid-stick? was created by Kilgore Trout
I've looked everywhere for an answer to this question, and can't find one.
I'm having a major issue with my throttle. I Just set this TX up yesterday, updated to the latest nightly build. My issue is that the channel output for the throttle doesn't go above 0%. There is throttle response down to -125%, but above mid-stick, I'm not getting any more throttle, which means I can't fly. I get a full -100/+100 when I look in the stick input menu under channel monitor. Limits are set to 250, scale 100. I'm setting this up for a plane, but I get the same symptoms if I change the mode to heli or multicopter.
- Leo Li
17 Sep 2018 04:46 #70940
by Leo Li
Replied by Leo Li on topic No throttle output past mid-stick?
Have you run sticks calibration ?
- Kilgore Trout
17 Sep 2018 16:47 #70952
by Kilgore Trout
Replied by Kilgore Trout on topic No throttle output past mid-stick?
Many times.
- Leo Li
18 Sep 2018 13:21 #70971
by Leo Li
Then next step is open transmitter and try to swap stick channel to test.
- Kilgore Trout
19 Sep 2018 01:43 #70978
by Kilgore Trout
Solved:
It was specific to that model slot. I created a new slot, and bam, it works fine. I cross-checked everything between the two slots, and there were no differences. Weird. Thanks for the replies.
Time to create page: 0.494 seconds
- No throttle output past mid-stick?
