Jumper T8SG Plus V2 battery
- smartiz
28 Sep 2018 13:32 #71080
by smartiz
Jumper T8SG Plus V2 battery was created by smartiz
I'm looking for a 2S battery to put in the Jumper T8SG Plus V2.
Do you guys have any recommendation?
I've found this one www.banggood.com/ZOP-Power-7_4V-1500mAh-...-Plug-p-1085890.html
Do you think it can fit?
- nacraracer
28 Sep 2018 21:23 #71087
by nacraracer
Replied by nacraracer on topic Jumper T8SG Plus V2 battery
Hobby King Turnigy 1800MAH 2S 12C Lipo. SKU is T1800.2s.12RX
- daive
- ksaves2
06 Oct 2018 16:14 - 06 Oct 2018 16:14 #71202
by ksaves2
Replied by ksaves2 on topic Jumper T8SG Plus V2 battery
Ok, look at my post here:
www.deviationtx.com/forum/6-general-disc...itter?start=80#70401
The 1800mah 2S HK battery fits the area and allow for maximum capacity. You have to doctor the pack as shown by clipping those massive
wires from the tabs. Just carefully disassemble the pack. You do need to have some replacement shrink wrap available. I use an angle
cutters and cut the large wires off the solder "blobs" at the tabs. It's to much work to desolder and then resolder. Besides the other wires
will flop off the tabs when you desolder. Just carefully clip the big wires off. Reassemble the pack and you can reapply some of the foam
tape to pad and insulate against a dead short. Apply shrink wrap and your done. I drain my packs to storage capacity when I mess with them
to avoid "vaporization" if I do something stupid during a battery mod and suggest anyone else do the same. Check the V and charge up the
pack. Can still do balance charging etc. Kurt
Last edit: 06 Oct 2018 16:14 by ksaves2.
- smartiz
- Tigger
19 Oct 2018 20:04 #71440
by Tigger
Replied by Tigger on topic Jumper T8SG Plus V2 battery
My jumper V2 Plus has a 2600 mah 2 cell made from two $5 power banks bought locally from Five Below. The ultra thin version has a 2600 mah 1S in it that is almost perfect in size except for the little insets in the top of the battery box which are easily removed. The added benefit is that the assembled pack in a 2S configuration is quite a bit thinner than others I have tried which makes it much easier to get to my dfplayer voice card.
- ddfwaj
14 Jan 2019 04:07 #72315
by ddfwaj
Replied by ddfwaj on topic Jumper T8SG Plus V2 battery
Hey great find, did you have to modify the battery at all to get it to fit? Is this the correct battery?
hobbyking.com/en_us/turnigy-1800mah-2s-1....html?___store=en_us
Thanks,
Dennis
Thanks,
Dennis
- smartiz
14 Jan 2019 08:45 #72316
by smartiz
Replied by smartiz on topic Jumper T8SG Plus V2 battery
Yes it is the correct battery.
Time to create page: 0.328 seconds
- Jumper T8SG Plus V2 battery
