vss and vdd short circuit
29 Sep 2018 13:46 - 29 Sep 2018 14:28 #71092 by wireless240
vss and vdd short circuit was created by wireless240
My devo 7E(this is another one making for my friend) works fine, until I try to fix the component too crowd problem, I want to remove the protection plastic layer of wfly module(not seen at here, it's at the back of devo7E but it is at the position of throttle) and save 1mm or 2mm. Then the devo 7E won't turn on. I use multimeter find out the red and the black of the throttle is short circuit, it's not the throttle part, it's at the motherboard part. So, even I put back the protection layer, they aren't fixed. I also check the mcu. all vdd and vss legs , that are vdd_1 vss_1, vdd_2, vss_2, vdd_3, vss_3, vdd_4, vss_4, vdda, vssa are short circuit. Any clue which part it is broken?
I check the motherboard 's plug, label as THRO, AILE, RUDD, ELEV's red and black wire are all short circuit.
Last edit: 29 Sep 2018 14:28 by wireless240.
29 Sep 2018 16:51 #71094 by wireless240
Replied by wireless240 on topic vss and vdd short circuit
I think it's 95% the mcu is broken, lol. I am done with mcu...
Time to create page: 0.285 seconds
