T8SG - FrSky BNF issue
02 Feb 2019 17:30 #72670 by Swanjp26
T8SG - FrSky BNF issue was created by Swanjp26
I have a Frsky BNF Eachine M80. I was able to bind using Frsky (D8) protocol and set up the flight mode and turtle mode switches. It responds to the switches, but will not arm or fly at all. Props will spin up in turtle mode, and the led changes color for the flight modes. Any ideas? M80 manual
02 Feb 2019 17:34 #72671 by Swanjp26
Replied by Swanjp26 on topic T8SG - FrSky BNF issue
I have tried to reassign the channel numbers to get it to match the order in the manual, but not sure I was doing it right. Could this be the issue?
02 Feb 2019 19:00 #72673 by hexfet
Replied by hexfet on topic T8SG - FrSky BNF issue
The default channel order for Frsky is AETR, while DSM is TAER. From the pic it looks like they don't adjust the channel assignments based on the protocol. You have the right idea to change the assigments in the tx. In the mixer for channel one change the SRC to THR, channel 2 AIL, and channel 3 to ELE. The labels in the left column on the mixer page are determined by protocol and can't be changed.
03 Feb 2019 02:01 #72683 by Swanjp26
When I reorder them that way, it just assigns throttle to my pitch stick on the right. I've also tried messing with the scale +/- and subtrim for the throttle, although I'm not entirely sure which way to go with which settings to be sure end points are low enough. Still no go tho... :( Any ideas are appreciated.
08 Apr 2019 03:55 #73730 by Flo
Replied by Flo on topic T8SG - FrSky BNF issue
I have the exact same issue
08 Apr 2019 14:27 #73738 by hexfet
Swanjp26 wrote: When I reorder them that way, it just assigns throttle to my pitch stick on the right.
So that channel order isn't correct. Just need to figure out the correct order. How do you know the throttle is working? Props shouldn't spin if not armed.
Also should have asked if you use mode 2. Since you mentioned right pitch stick I'd guess it is.
In mode 2 the right vertical stick is the ELE source. With the assignments mentioned ELE was source for channel 3. And moving the right vertical stick caused the throttle to react? That indicates throttle is controlled by channel 3 (matching the default Frsky channel order). Assign source THR to channel 3.
Then need to figure out what channels control pitch, roll, and yaw. Maybe with throttle control you can arm and use prop response to figure that out. The common channel orders with throttle on channel 3 are AETR and EATR. Seems like AETR should be right for an Frsky receiver.
19 Jun 2020 11:04 #76503 by propnut
Replied by propnut on topic T8SG - FrSky BNF issue
name=M80
mixermode=Advanced
type=plane
[radio]
protocol=Frsky
num_channels=8
fixed_id=1
tx_power=150mW
[protocol_opts]
Telemetry=On
Freq-Fine=0
Freq-Coarse=0
AD2GAIN=0
RSSIChan=None
[channel1]
template=simple
[mixer]
src=THR
dest=Ch1
scalar=125
[channel2]
template=simple
[mixer]
src=!AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=ELE
dest=Ch3
[channel4]
reverse=1
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=SW H1
dest=Ch5
curvetype=expo
points=0,0
[channel6]
template=simple
[mixer]
src=SW G1
dest=Ch6
curvetype=expo
points=0,0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch1
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
[voice]
Time to create page: 1.798 seconds
