12s possible bug?
27 Feb 2019 23:51 #73050 by Birdman
12s possible bug? was created by Birdman
Not new to deviation but have just set up a new 12s and getting familiar with it, but seem to have a very odd issue.
I have bind a Walkera 1202 rx (no ID) and when I scroll through menu and get to button monitor or range test the bind screen appears. If throttle is up the safety screen appears and when lowered the bind screen then appears. It is like the tx thinks it has been turned off.
So, I made a another new model and set it up for a DMS2 rx with ID and get a similar thing happen. When I scroll menu and get to button monitor or range test page instead of the bind window appearing I see the DSM2 rx looses signal and the led starts flashing indicated this has in fact happened.
Need help please..
28 Feb 2019 00:24 #73051 by Birdman
Replied by Birdman on topic 12s possible bug?
using vlads build with latest protocols
28 Feb 2019 00:58 - 28 Feb 2019 00:58 #73055 by Birdman
Bind 1202 with ID and it now does the same as DMS2 rx that is set up as a different model. Bind window no longer appears but when scrolling rx led goes out and starts blinking indicating loss of signal.
Tripple checked all settings, done some searching, nothing more I can do.
Anyone????????
Last edit: 28 Feb 2019 00:58 by Birdman.
28 Feb 2019 15:53 #73066 by vlad_vy
Replied by vlad_vy on topic 12s possible bug?
I think it related to "Scanner" page. You can see it if you go to "Range test" page from "Scanner" page, and if you go to "Button monitor" page from "Scanner" page. At both cases if you leave "Scanner" page, it lead to protocol init. I think it's only case for this "bug".
28 Feb 2019 16:40 - 28 Feb 2019 16:40 #73067 by vlad_vy
It will be fixed with next v5.0.0 build with latest protocols.
Last edit: 28 Feb 2019 16:40 by vlad_vy.
28 Feb 2019 21:38 #73072 by Birdman
Ok, thanks. Much appreciated.
01 Mar 2019 04:20 #73077 by vlad_vy
You can flash new build with the problem fixed:
www.deviationtx.com/forum/builds/6407-de...cols?start=440#73075
01 Mar 2019 06:22 #73082 by Birdman
Thanks, it is fixed.
I only flashed the firmware, not lib or any other files, is this ok?
01 Mar 2019 07:25 #73084 by vlad_vy
OK. Nothing changed except firmware.
01 Mar 2019 07:34 #73086 by Birdman
may have created another issue, now I can't bind 2 tx to same rx
01 Mar 2019 10:04 #73088 by Birdman
also, if i turn tx off i now have to rebind rx,
at this time it appears that firmware has done something it shouldn't have
01 Mar 2019 10:19 #73089 by Birdman
put other firmware back in still does same thing, this is looking bad
01 Mar 2019 11:37 #73091 by Birdman
Have tx binding again after being turned off.
But still can't get the 2 tx to bind to same rx like I was able to.
01 Mar 2019 12:05 #73092 by vlad_vy
If you use walkera receiver you need first bind without Fixed ID, then set Fixed ID, after that receiver will be always bound.
01 Mar 2019 12:07 #73093 by Birdman
My problem could be totaly unrelated to firmware change.
But I did have ladybird, mini cp and genius cp v2 bound and working on 8s and 12s, now i can not get any rx to bind to both tx.
01 Mar 2019 12:08 #73094 by Birdman
vlad_vy wrote: If you use walkera receiver you need first bind without Fixed ID, then set Fixed ID, after that receiver will be always bound.
Yes, I know that.
01 Mar 2019 12:10 #73095 by Birdman
when i bind without fixed id then set fixed id rx will not bind
01 Mar 2019 12:17 #73097 by Birdman
to elaborate:
Before I would bind first tx with no fixed id, window said none, and rx would bind, then i tap "none" and there is a 6 digit number already in next page, I would record this number and tap "done".
Then on second rx i would do the same, tap "none" and change the fixed id to same number as first tx. This worked.
Now when I change number in second tx it does not bind.
I don't "think" i am doing anything different
01 Mar 2019 12:20 #73099 by Birdman
yes i have txid=xxxxxxxx in hardware of both tx
01 Mar 2019 12:21 #73100 by Birdman
vlad_vy wrote: You need bind without Fixed ID, do not power off anything, set custom Fixed ID and press bind button.
ok, will try that
Time to create page: 0.808 seconds
