Jumper t8sg v2 plus
- oldjoe
22 Apr 2019 12:18 #74083
by oldjoe
Jumper t8sg v2 plus was created by oldjoe
Windows 10 does not recognize usb. tried trouble shooting and that did not help. Anyone ever figure out how to get windows 10 to see T8 sg plus? I am stuck with the usb screen on my Jumper.
- Carlos_Ribes
27 Apr 2019 22:00 - 27 Apr 2019 22:04 #74157
by Carlos_Ribes
Replied by Carlos_Ribes on topic Jumper t8sg v2 plus
I have not had any problem with USB in Windows 10. In my case I used USB 3, I do not know if that is the reason.
Have you put the Jumper in USB mode?
Before, in DFU Mode at first it resisted but after updating the drivers in Windows update it worked.
Then going to USB mode worked fine.
Last edit: 27 Apr 2019 22:04 by Carlos_Ribes.
- oldjoe
28 Apr 2019 10:54 #74159
by oldjoe
Replied by oldjoe on topic Jumper t8sg v2 plus
I ended up using a old computer that I still had with windows 7 and it worked fine. I was locked in usb mode on my Jumper and now it is working fine again. Thanks for the reply. I will probably try windows 10 again sometime.
- Carlos_Ribes
28 Apr 2019 11:24 #74161
by Carlos_Ribes
My USB unit in the Jumper runed so slowly that it was imposible in W7. Then I made the connection in a new W10. It runned slowly but worked.
I had the idea of format the USB unit but I realized that it was much more used than the size of the firmware files.I am afraid that there must be some system files that can not be seen in the Pc.
Do you know something about the slowlyness of the USB unit of the Jumper?
- harpoon
02 May 2019 08:51 #74187
by harpoon
Replied by harpoon on topic Jumper t8sg v2 plus
I don't know if it can be usefull (i'm a new) but i have done this (with RF4.5):
- Setted up a new "plane" model (also if you use heli), protocol usbhid
- Connected to usb and press re-init.
- Installed UJR and VJOY
enjoy
enjoy
Time to create page: 0.095 seconds
- Jumper t8sg v2 plus
