Jumper T8S V2 Plus + FrSky SmartPort Telemetry
- gpo123
26 May 2019 20:36 #74393
by gpo123
Jumper T8S V2 Plus + FrSky SmartPort Telemetry was created by gpo123
I am trying to get the extended telemetry to work on my Jumper T8SG. The receiver is a XSR, the telemetry data is sent out correctly from the flight controller. I have cross checked this with my Taranis QX7. So far I am only able to receive and show the basic telemetry like VBAT AND RSSI from the receiver. The extended info like ALT or ACC is not shown. I even have a hex-File directly from git, version is 6cdaf33. Could not find a missing entry in the ini-files, so what I am missing here ?
28 May 2019 02:15 #74404
Replied by hexfet on topic Jumper T8S V2 Plus + FrSky SmartPort Telemetry
Thanks for reporting this. When I added the CRC check for Qlrs telemetry it broke the over-the-air s.port telemetry (which does not have an s.port CRC).
Please try the test build here (219d660) . I've tested the fix with an XSR and simulated Qlrs telemetry. PR #875.
- gpo123
09 Jun 2019 05:53 - 09 Jun 2019 05:54 #74482
by gpo123
Replied by gpo123 on topic Jumper T8S V2 Plus + FrSky SmartPort Telemetry
with the test build 219d660 the telemetry is working as expected. I checked out your deviation branch to do some personal changes on two protocols. After compiling this version showed up as version 4.01. Although running fine, out of curiosity: How I manage to get a 5.0 version ?
Last edit: 09 Jun 2019 05:54 by gpo123.
Time to create page: 0.097 seconds
- Jumper T8S V2 Plus + FrSky SmartPort Telemetry
