Devo7e control set up
- Bry1
02 Jun 2019 23:27 #74449
by Bry1
Devo7e control set up was created by Bry1
Hi all
I have just modded my Devo 7e, I am using it to control a twin motor bait boat which has been rewired and upgraded to 2.4ghz. The boat has two torpedo motors each controlled by separate esc. These are Mtroniks 15’s the left stick controls the right motor and the right stick controls the left motor.
The problems I’m have are the right hand motor doesn’t sound it is running at the same max rpm as the other motor
The other problem is when I put both motors into reverse the left motor runs intermittently until I reduce the rpm on the right motor,
Has anyone got any suggestions as to what the problem maybe
I ave also added a third switch to the transmitter as this operates a bait dropper, the other two original switches operate the lights and a fish finder on the boat.
- Gerry
- Bbrad
08 Jun 2019 07:00 #74477
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Devo7e control set up
Try
swap the channels for escs to determine if esc/motor problem or Tx/Rx problem.
Calibrate Tx
Calibrate ESCs
Calibrate Tx
Calibrate ESCs
- Bry1
09 Jun 2019 06:20 - 09 Jun 2019 06:22 #74484
by Bry1
Replied by Bry1 on topic Devo7e control set up
Hi Gerry
Thanks for the reply, I have already done what you have suggested but it just transferred the problem to the other motor.
But it has now got worse and the right hand esc is now blowing fuses!
I’m assuming that the esc,s have now blown?
It has also been suggested the best way to have the controls is to add a mixer and have the throttles for both motors and steering on one stick?
Last edit: 09 Jun 2019 06:22 by Bry1.
- Gerry
- Bbrad
09 Jun 2019 07:24 #74485
by Gerry
what about if only one esc is plugged into the rx at a time.
have you disconnected one of the red wires from one esc at the servo lead?
- Bry1
09 Jun 2019 08:08 #74486
by Bry1
Didn’t try only connecting one and yes I have disconnected one of the red wires
- Gerry
- Bbrad
17 Jun 2019 07:04 #74554
by Gerry
Any progress?
you could also swap motors on each esc to determine if motor or esc is problem.
make sure both motors spin free by hand.
are you spinning one motor CW and the other CCW? some brushed motors might not like spinning backwards.
is there a brake function on the escs? should be forward and reverse only for boat, no brake.
I too would have suggested a master throttle and a mixer arrangement for control on one stick.
- Bry1
12 Oct 2019 19:22 #75240
by Bry1
Hi
I have been running my boat and it has been ok apart from the intermittent running of the motors when in reverse at full throttle, I even changed the motors but still had the problem.
I have decided that it would be easier I’d I could control the forward/ reverse and steering from one stick, what is the easiest way to do this?
- Bry1
18 Oct 2019 17:27 #75281
by Bry1
So I have now fitted the mixer and both motors run using the one stick but when I use the stick to steer the boat on of the motors cuts out, can the devo 7e be set up so it just slows one of the motors down giving a smooth steering action?
- Gerry
- Bbrad
18 Oct 2019 22:39 - 19 Oct 2019 01:58 #75282
by Gerry
something like this I think works..........
master throttle on throttle stick
aileron stick slows one motor or the other
you could swap the aileron for rudder and have all control on one stick (mode 2)
adjust scalar and or 3 point curve values in second mixer page of each channel to tune.
Model file attached below.
[channel1]
template=complex
[mixer]
src=THR
dest=Ch1
[mixer]
src=AIL
dest=Ch1
scalar=60
usetrim=0
muxtype=add
curvetype=3point
points=0,0,-50
[channel2]
template=complex
[mixer]
src=THR
dest=Ch2
[mixer]
src=!AIL
dest=Ch2
scalar=60
usetrim=0
muxtype=add
curvetype=3point
points=0,0,-50
[channel1]
template=complex
[mixer]
src=THR
dest=Ch1
[mixer]
src=AIL
dest=Ch1
scalar=60
usetrim=0
muxtype=add
curvetype=3point
points=0,0,-50
[channel2]
template=complex
[mixer]
src=THR
dest=Ch2
[mixer]
src=!AIL
dest=Ch2
scalar=60
usetrim=0
muxtype=add
curvetype=3point
points=0,0,-50
Last edit: 19 Oct 2019 01:58 by Gerry. Reason: more info
- Bry1
20 Oct 2019 08:38 #75291
by Bry1
Thanks I will give this a go
- Bry1
22 Oct 2019 18:47 #75295
by Bry1
Hi
Tried the above settings but it didn’t work
- Gerry
- Bbrad
23 Oct 2019 00:40 #75296
by Gerry
what does happen?
- Bry1
23 Oct 2019 06:07 #75297
by Bry1
Hi
Both motors ran but in opposite directions when the left stick was pushed forward and I had no steering control on the left to right movement on the left stick
- Gerry
- Bbrad
26 Oct 2019 04:34 #75314
by Gerry
your description makes me think one of your esc is not calibrated correctly.
swap the channels the esc's are using on the rx to check if same side still spins opposite direction or other side.
If this is the case use mix like couple posts above and re-calibrate esc's.
on the second page of both mixes make the scalar 100, see if that makes a difference.
- Bry1
26 Oct 2019 17:31 #75323
by Bry1
Ok so I have now put all settings back to simple mode.
Stick mode 1
Connected up the mixer again and I can get both motors to run on the one stick and both are going in the correct direction.
When I push the stick forward and then start to move it to the right the left motor cuts out!!!
Well confused!!
Still need to get smoother steering control On the same stick set up?
Stick mode 1
Well confused!!
- Bry1
27 Oct 2019 20:22 - 27 Oct 2019 22:08 #75328
by Bry1
Hi
First of all thanks for the help Gerry
I have now managed to sort out a few of the issues and have the set up working, the only issue I have at the moment is the motors are spinning in opposite directions, I assuming this will be simply swapping the polarity of the incorrect motor,
Last edit: 27 Oct 2019 22:08 by Bry1.
- Gerry
- Bbrad
17 Jun 2020 08:49 #76489
by Gerry
I know its been awhile but this topic might interest you.
www.deviationtx.com/forum/model-requests...3-help-devo-10-setup
Time to create page: 0.292 seconds
- Devo7e control set up
