Devo 8s over voltage input cannot power on
02 Nov 2019 17:40 #75358 by mangmeephol
Devo 8s over voltage input cannot power on was created by mangmeephol
I am input 11.1v. Lipo battery and switch on lcd power on display show 1-2 sec display lcd off. After cannot use. Hlep me please.
03 Nov 2019 00:23 #75360 by Birdman
Replied by Birdman on topic Devo 8s over voltage input cannot power on
Given it only takes 6v i reckon you have fried something. Could be you are not the first, do a search. Or open tx and you will probably see where the smoke came out.
03 Nov 2019 00:43 #75362 by Birdman
There are 2 8s in my household, I can possibly help you identify components.
03 Nov 2019 00:59 - 03 Nov 2019 01:00 #75363 by Birdman
www.deviationtx.com/forum/3-feedback-que...a-resistor-burn#9665
Even with only a 2s lipo you must use diode to drop voltage.
I have 2s lipo with diode in my 8s and it works fine like this.
Last edit: 03 Nov 2019 01:00 by Birdman.
03 Nov 2019 05:27 #75364 by mangmeephol
Replied by mangmeephol on topic Devo 8s over voltage input cannot power on
No have burn in circuit. But VDD. Output 2.08v. Only
03 Nov 2019 05:59 - 03 Nov 2019 06:04 #75365 by Birdman
Ok, may or may not be visible to naked eye, but I still reckon you have fried something.
Sounds like you have a DMM, problem "might" be easy to find. Check reg and other associated components in supply.
Reg input and output would be a start.
Last edit: 03 Nov 2019 06:04 by Birdman.
03 Nov 2019 06:24 #75366 by mangmeephol
Have capacitor near L04A 1 unit. Multimeter check but no have capacity.
03 Nov 2019 06:24 - 03 Nov 2019 06:25 #75367 by Birdman
Will look at my tx.
www.deviationtx.com/forum/search?query=d...te=all&childforums=1
Part of 8s power circuit can be found in above link.
Last edit: 03 Nov 2019 06:25 by Birdman.
03 Nov 2019 06:43 #75368 by mangmeephol
03 Nov 2019 06:48 #75369 by Birdman
I think you are looking in the wrong place. I cannot see 3v3 reg, maybe it is on other side.
Out of curiosity, what is blue wire on STM32?
03 Nov 2019 07:06 #75370 by mangmeephol
This no have in and output no have voltage.
03 Nov 2019 07:08 #75371 by mangmeephol
This ok.
03 Nov 2019 07:10 - 03 Nov 2019 07:34 #75372 by Birdman
The RT9167A (LO4A) is a LDO reg but I would expect the 3v3 reg to look more that pictured below with yellow spot.
Last edit: 03 Nov 2019 07:34 by Birdman.
03 Nov 2019 07:21 #75373 by mangmeephol
LM78D06 have 6v. output When insert charger cable. RT9167A have 6v. input when insert battery and have output 2.08v. only.
03 Nov 2019 07:28 - 03 Nov 2019 07:30 #75374 by Birdman
Ok, maybe LM78D06 is for charging, it's been a while and I need to familiarise myself again.
My tx has 6v in (red circle) and 3v3 out (yellow circle) of RT9167A,
Last edit: 03 Nov 2019 07:30 by Birdman.
03 Nov 2019 07:41 - 03 Nov 2019 08:26 #75375 by Birdman
Absolute maximum input rating for RT9167A is 8V
edit:
So if input is batt voltage it could be damaged. A schematic would make things much easier. The RT9167A-33CB are on Ebay
33 is 3V3 output voltage and CB will be package/pinout.
It appears you have enough knowledge to fix this. Keep us updated, it will help others.
Last edit: 03 Nov 2019 08:26 by Birdman.
03 Nov 2019 08:49 #75376 by mangmeephol
Thank you very very much.
03 Nov 2019 08:57 #75377 by mangmeephol
This capacitor you can check have how much capacity? I am check this capacitor check no have capacity.
03 Nov 2019 08:59 #75378 by mangmeephol
This is problem VDD =2.08v. yes or no?
Time to create page: 0.884 seconds
