Jumper T8SG V2 Plus Voice Control issue
- Picos310
26 Nov 2019 02:54 - 26 Nov 2019 02:55 #75484
by Picos310
Jumper T8SG V2 Plus Voice Control issue was created by Picos310
Anyone know why it doesn't work?
In the Hardware ini file I set the two below and made sure there was no semi colon
voice-uart5=1
voice=dfplayer
Formatted an sd card to fat32 and placed the mp3 folder from this website there.
When I turn on the radio it just keeps saying saving over and over and over without stopping and when I go into voice control it says that it is not availabe.
voice-uart5=1
voice=dfplayer
Last edit: 26 Nov 2019 02:55 by Picos310.
- fmurray
26 Nov 2019 18:39 - 26 Nov 2019 18:50 #75485
by fmurray
Replied by fmurray on topic Jumper T8SG V2 Plus Voice Control issue
I had a super-good working and configured T8SG v2 Plus. Updated the f/w from T8SG-v2-plus-v5.0.0-e801244 that id came with to -28ce50f from the most recent daily build.
Now, whenever turning it on, it says "saving" over and over without end. It used to say that once on power-on right before "Welcome to Deviation" before the update.
Also, when I go into the Model Menu, Voice Config, I get a message "External voice currently not available."
Any ideas?
Update:
I copied the hardware.ini file from my backup into the top directory of the T8SG v2 plus, overwriting the one that came with the nightly build (-28ce50f) and all voice problems are solved. I've listed both files side-by-side and have not been able to find any difference in the files.
Any ideas?
Update:
Last edit: 26 Nov 2019 18:50 by fmurray. Reason: Follow-up
- Picos310
26 Nov 2019 18:48 - 26 Nov 2019 18:49 #75486
by Picos310
Replied by Picos310 on topic Jumper T8SG V2 Plus Voice Control issue
I'm in the same boat as you and can't figure out why this is happening. Mine never said Welcome to Deviation and I'am also getting the External voice currently not available issue. For the moment I removed the sd card so it can shut up lol
Last edit: 26 Nov 2019 18:49 by Picos310.
- Picos310
27 Nov 2019 03:30 #75487
by Picos310
I figured it out and it was very easy to fix. When you download the sound files there is a voice.ini file that you need to copy into the media folder of the radio. That fixed all the issues for me.
Time to create page: 0.106 seconds
- Jumper T8SG V2 Plus Voice Control issue
