Blade 150S cyclic to throttle mixing
- Timbo77
14 Feb 2020 02:44 - 14 Feb 2020 02:45 #75918
by Timbo77
Blade 150S cyclic to throttle mixing was created by Timbo77
Last edit: 14 Feb 2020 02:45 by Timbo77.
- -=Hubi-Dirk=-
15 Feb 2020 05:33 #75923
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Blade 150S cyclic to throttle mixing
Hi
you might be able to do this with a complex mixer set up on Ele and Ail and add 20% to the throttle channel.
I have never done something like this before, in earlier days for the Acro Mode a V-shaped curve was programmed for the throttle channel if you didn't have a ESC with Govenormode. But the Blade 150S has one, you can see it on the throttle channel at position 2 of switch B, 90% in all 5 positions.
Personally, I would first change the throttle channel settings (e.g. Sw B with 100% on all 5 points) and try to determine if the power is sufficient for my flying style. More than 100% throttle is also not available by mixing.
- -=Hubi-Dirk=-
15 Feb 2020 08:41 #75924
by -=Hubi-Dirk=-
- Timbo77
16 Feb 2020 06:28 #75932
by Timbo77
Replied by Timbo77 on topic Blade 150S cyclic to throttle mixing
Thanks, I will give it a try, I was trying to set aileron and elevator to cyclic 1, 2 respectively, it then gives you throttle cyclic - aleron and elevator mixing options prior to virtual channels. I then set DR/expo but no where can I see how to mix 20% throttle. Plus, the cyclic was all wonky and nothing moved correct.
- -=Hubi-Dirk=-
16 Feb 2020 09:32 #75933
by -=Hubi-Dirk=-
Don´t forget to program this also for Ail
At page 1 and page 2 you can give Expo at "Curve" for Ele and Ail. Never use DR, in extrem Situations you will be thankful to have the maximum steering option! I use cyclic at Helicopters with Paddles, not for one with stabilisation.
- txinsuranceguy
10 Sep 2020 04:05 #76774
by txinsuranceguy
Replied by txinsuranceguy on topic Blade 150S cyclic to throttle mixing
Hi
did you get it to work? would you be willing to share your INI file? i'm not able to figure it out for my 150S.
- Timbo77
10 Sep 2020 05:23 #76775
by Timbo77
No, flew very unstable. Ended up getting a used dx6
- txinsuranceguy
10 Sep 2020 05:24 #76776
by txinsuranceguy
i'm surprised the 230's ini wouldn't work. dang.
- PaulB
08 Oct 2020 09:34 #76865
by PaulB
Replied by PaulB on topic Blade 150S cyclic to throttle mixing
This is my .ini for my 150S and it works fine, TH on G, Panic (Recovery) on H, Flight modes (3) on D and throttle swash mixing on.
Time to create page: 0.697 seconds
- Blade 150S cyclic to throttle mixing
