Jumper T8SG Plus V3 Carbon
05 May 2020 16:55 #76229 by pcrane87
Jumper T8SG Plus V3 Carbon was created by pcrane87
Good Morning
like a dumd ass i did not back up my files to my transmitter and now I am paying for it I am able to get into the DFU mode but I am unable to format the drive F: so now its in stuck mode USB and device manager says USB storage drive.
and I downloaded correct firmware for the control how do I know if it is bricked now and if it is how do I fix that.
06 May 2020 02:42 #76238 by roso
Replied by roso on topic Jumper T8SG Plus V3 Carbon
vou tentar ajudar.
1-modo dfu e uma coisa ,modo usb e outra coisa.
2-como sabe se firmware e o correto??? foi daqui do forum fez download ??
3-qual versao firmware??
4-se esta tendo essses problemas o mais certo e o firmware nao ser o correto,
eu tive todos esses problemas tambem.
5-nao formate ainda ,se o windows nao pedir.
6-nao panic ,sei bem o que esta passando amigo.
06 May 2020 14:41 #76242 by pcrane87
Replied by pcrane87 on topic Jumper T8SG Plus V3 Carbon
Thank you
I downloaded the firmware from the form and used Ts8g v2 plus and after that it stay in USB mode and i did the lipusb software on my computer and that still did not work for me to log onto my transmitter.
06 May 2020 14:53 - 06 May 2020 14:58 #76243 by vlad_vy
Replied by vlad_vy on topic Jumper T8SG Plus V3 Carbon
For carbon version with LCD display you need use "t8sg_v2" firmware. Flash latest firmware, then in USB mode use USB drive erase procedure.
1) "Power ON" transmitter with USB mode (ENT + Power ON)
2) Press "UP" button
3) After short beep press "DN" button
4) After short beep "Power OFF" transmitter
5) "Power ON" transmitter with USB mode (ENT + Power ON)
6) Format transmitter USB drive with "Quick Format" option enabled
Last edit: 06 May 2020 14:58 by vlad_vy.
06 May 2020 15:52 #76244 by pcrane87
Ok I tried that about ten times and nothing
here is a picture of the back of my transmitter.
06 May 2020 16:00 - 06 May 2020 16:02 #76246 by vlad_vy
With nightly builds 2020-05-05 firmware?
Last edit: 06 May 2020 16:02 by vlad_vy.
06 May 2020 16:09 #76247 by pcrane87
yes
07 May 2020 12:15 #76264 by roso
pena nao ter respondido ao que perguntei?
sabe entrar modo dfu ?
ou esta bloqueado em modo usb,
veija gestor dispositivos se aparece em dfu.
consegue ver ficheiros dentro cartao (modo usb)?
07 May 2020 14:54 #76266 by pcrane87
i was able to get pass that and update firmware and format control and place correct files in there.,
07 May 2020 21:55 #76269 by roso
ok...
vamos la
passe aqui....www.jumper-rc.com.......apenas aqui tem zip que acho que vai resolver tudo....assim espero.
faca tudo como se fosse do versoes noturnas..
diga como ficou .
um abraco.
17 Oct 2020 02:20 #76887 by Skillin
Replied by Skillin on topic Jumper T8SG Plus V3 Carbon
I did and it killed ma screen now all streeks
17 Oct 2020 10:01 #76894 by roso
ok. nao se preocupe
explique melhor o que tem na tela ...riscos preto?
fez isto passe aqui .... www.jumper-rc.com ....... apenas aqui tem zip que acho que vai resolver tudo .... assim espero.
faca tudo como se fosse do versoes noturnas ..
diga como ficou.
um abraco.
18 Oct 2020 13:40 #76897 by propnut
Replied by propnut on topic Jumper T8SG Plus V3 Carbon
1. If you are using a MAC then forget it, you will NEVER fix this problem as the MAC is the thing causing it.
2. Assuming you have access to a Windows PC then search through my posts and you will find the link to the correct build where the up down process described by Vlad actually works.
Sorry Vlad the nightlies don't work. The original build you posted ages ago does.
29 Oct 2020 07:29 #76956 by alphasierra
Replied by alphasierra on topic Jumper T8SG Plus V3 Carbon
why can we not leave dfu files in here?
the firmware that works best for me is t8sg_v2-v5.0.0-487d7be1
31 Dec 2020 11:09 #77151 by Max_Doubt
Replied by Max_Doubt on topic Jumper T8SG Plus V3 Carbon
After my BRAND NEW Jumper T8SG plus v3 (LCD screen) suffered the dreaded USB screen of death after only a single use, I spent several late nights trying fruitlessly to fix it. In my case, I found the main problem was that connecting the Jumper to my PC resulted in the wrong driver being installed which meant that I couldn't sucessfully format the drive or proceed with firmware installation.
I finally figured out a fix and documented it in the attached PDF. I hope it helps someone save a lot of time and frustration! :)
10 Feb 2021 04:12 #77233 by D.Ricks
Replied by D.Ricks on topic Jumper T8SG Plus V3 Carbon
do you have a copy of that firmware or a link to where i can get it
25 Mar 2021 11:59 #77328 by Max_Doubt
Yes, look at the attachment I put in my post above. All the links are in there.
Time to create page: 0.156 seconds
