[solved] XK K110 lags
30 May 2020 16:28 - 31 May 2020 07:08 #76382 by yaKOS
[solved] XK K110 lags was created by yaKOS
Hi!
I finally ordered and received my first CP-Heli, the K110.
But I have trouble to establish a stable connection.
When I turn on both TX and RX, it takes quite a while until they are connected.
When I get a connection it seems to be very unstable, anyways the Heli responses very delayed (about 1 second).
What could be the problem, does anyone have a clue?
Could the CC2500-module be defect?
[EDIT]Just tried another module - same behaviour [/EDIT]
I am using a Devo 7e with stock-module plus CC2500 and one of the latest nightly builds.
Thanks for any advice,
Last edit: 31 May 2020 07:08 by yaKOS. Reason: solved
31 May 2020 07:12 #76388 by yaKOS
Replied by yaKOS on topic [solved] XK K110 lags
It finally works!
I have downgraded the Deviation Firmware to 5.0.0 and now it works.
Even better: it works with a CC2500-module salvaged from a MJX-F645-Transmitter,
and it also works with a module from aliexp. with PA and LNA...
So now I'll have to put back together the MJX Transmitter...
...after some maidening with my K110... B)
Time to create page: 0.064 seconds
