Naming of Mixers
19 Jun 2020 11:20 #76505 by propnut
Naming of Mixers was created by propnut
Does anyone know how to give a Mixer a name e.g. Hold, Acro etc. This is quite easy in OpenTX but not so obvious in DeviationTX. It would be quite nice to be able to rename existing mixers as well
For example, I had to channel my channel order to TAER for a specific model but in the mixers 1-AIL and I would like to rename it THR.
27 Jun 2020 02:37 #76532 by 52dgj
Replied by 52dgj on topic Naming of Mixers
Virtual channel support
29 Jun 2020 19:34 - 30 Jun 2020 08:05 #76536 by propnut
Replied by propnut on topic Naming of Mixers
Hadn't thought of those. Thanks will take a look
EDIT: Yes that works thanks, great idea !!
Now the only problem I have now is that because the radio is AETR and my M80 needed TAER everytime I turn on the radio it complains that channel 3 is not at -100. Sadly it seems there is no way to change this on the radio and the M80 does not support cleanflight or Betaflight so I can't change the channel order on there to AETR.
Oh well it is a minor issue
Last edit: 30 Jun 2020 08:05 by propnut.
30 Jun 2020 14:12 #76543 by 52dgj
What protocol are you using?
01 Jul 2020 00:21 #76545 by Gerry
Replied by Gerry on topic Naming of Mixers
You can change the start safety channel.
Use notepad++ to change the model file
[safety]
Auto=min
change to
[safety]
Auto=none
or
Ch1=min
or maybe
Thr=min
FFS (Forever Fixing Stuff)
02 Jul 2020 08:02 #76561 by propnut
Thanks mate, that did it
I used Thr=min
Time to create page: 0.715 seconds
