DEVO 8
- aerocarv
10 Jan 2021 22:44 #77169
by aerocarv
DEVO 8 was created by aerocarv
Using DEVO 8 for helicopter. Channel 7 is used to set one of three gyro conditions. Manual, stabilized and return to home. BUT, software, Devention 4 and 5 do not see switch position 0 (zero). It is a three position switch, but software only sees two positions.
Is this common problem and if so, a solution? Can't fly the helicopter without all three positions and their values. Could my transmitter have a faulty switch?
- aerocarv
11 Jan 2021 15:52 #77174
by aerocarv
Replied by aerocarv on topic DEVO 8
Vlad, thank you.
The Wakera G400 helicopter requires that Chan 7 controls the Gyro and Ch 8 control flight mode. The Flight Mode switch and the Gyro switch are three position types. I have tried using the :complex" setting for the Gyro's switch. In the complex menu we have: Mixers, Page, Switch, Mux, Srv,, Curve, Scale and Offset. I do not know what each is? Some make sense.
Please advise. It is not logical!
- -=Hubi-Dirk=-
- aerocarv
- aerocarv
- aerocar
15 Jan 2021 00:02 #77181
by aerocar
Replied by aerocar on topic DEVO 8
New question. How download and then copy "supported models" to the USB internal file system in the DEVO8? Do the chosen models have to use the same protocol? I have original Walkera chip. I want to load "BLADE" helicopter models.
Time to create page: 0.194 seconds
- DEVO 8
