Devo 7e with 3in1 binding FrSky V8R4-II / D8R-II +
06 Nov 2021 21:32 #77615 by GeorgXXX
i got a Devo 7e with 3in1 module.
I flashed the latest daily firmware and modified the hardware.ini.
It looks like all modules are detected successful. The devo booting without errors.
I tried to bind FrSky receivers without success.
V8R4-II (V8 Mode binding)
Protocol: FrSky
Freq-Fine: tried all between -127 and 127
D8R-II plus
Protocol: FrSky-V8
Freq-Filne: tried all between -127 and 127
I also tried different PPM In settings etc.
Is there any way to check that the transmitter CC2500 really works?
My hardware.ini
[modules]
enable-cyrf6936 = B12
has_pa-cyrf6936 = 0
enable-a7105 = A13
has_pa-a7105 | = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
; enable-multimod = A13
Maybe someone know different settings to get it working?
08 Nov 2021 06:44 #77616 by GeorgXXX
after some tries and errors.... I found my mistake and also a wrong information in the protocoll list.
www.deviationtx.com/wiki/supported_protocols
This list invert some information about supported receiver versions:
Frsky => Older Frsky protocol used by the V series RX's
Frsky-V8 => Newer Frsky protocol used by the D series RX's
Frsky-X => Newer Frsky protocol used by the X series RX's
The "FrSky" and "FrSky_V8" description is swapped. The pdf manual is correct but this list not.
I was confused in the beginning. Because the name"_V8" should be the V8-mode, but the description say it is for D receiver.
Maybe someone can correct the list and check also all other protocols for mismatches?
I can bind my receiver after i use the FrSky_V8 protocol for my V8R4 Rx.
Thanks.
09 Nov 2021 23:52 #77617 by Gerry
i think your hardware.ini has error as well
has_pa-a7105 | = 1
should be
has_pa-a7105 = 1
FFS (Forever Fixing Stuff)
Time to create page: 0.072 seconds
