Voice alerts on designated points in channel
24 Aug 2022 04:29 - 24 Aug 2022 09:09 #78059 by McGyver
I’m trying to set few voice alerts on one channel. For example ch5 flightmode. At -85, -53, -20, 12 points. Is there way to do it? I assume I should use some remaining unused channels or virtual channels to „clone” throttle value and than play alert for each channel? I really don’t have enough experience to do it for now. Can anyone help me with that and point how to do it properly?
Ok it's good to discuss with ourselves :) and find some answers in many tries.
For now I got:
[virtchan2]
template=complex
[mixer]
src=Ch5
dest=Virt2
[mixer]
src=AIL
dest=Virt2
scalar=-85
usetrim=0
muxtype=voice
curvetype=fixed
[virtchan3]
template=complex
[mixer]
src=Ch5
dest=Virt3
[mixer]
src=AIL
dest=Virt3
scalar=-53
usetrim=0
muxtype=voice
curvetype=fixed
Virt2=286
Virt3=287
So basicaly it works, but plays each step when I cross desired range. I expected to play voice only in desired points.But if I go from -85 to -20 directly by switch it plays voice for middle value -53 which I don't want, only that -85 and -20. Is there a way to separate that? Or I have to assign some switch position as play condition if that is possible? So for example If I move from -85 to -20 i'll do it by switch FMOD0.
It's little too complicated how exactly that mixer works :(
Last edit: 24 Aug 2022 09:09 by McGyver.
27 Aug 2022 17:09 #78066 by hexfet
Yes, I think you'd have to use a switch to ensure only one alert would play. Not sure if it might work to use one virtual channel as a switch for the other.
Time to create page: 0.032 seconds
