Devo 7e with rf module from Walkera WK-2801 pro
24 Sep 2022 19:25 #78099 by PanKek
Hello all.
Is it possible to install the rf module from an old Walkera WK-2801-pro to Devo 7e?
I am interested to run Devo 7e under dsmx protocol with telemetry and full range power.
25 Sep 2022 07:43 #78100 by vlad_vy
I think it can be used.
Pinout:
1 - CSN
2 - SCK
3 - Reset
4 - MOSI
5 - MISO
6 - +5V
7 - GND
fcc.report/FCC-ID/S29WK-2801PRO
This browser does not support PDFs. Please download the PDF to view it: Download PDF
26 Sep 2022 19:54 #78101 by PanKek
I am planning to remove the stock module and install the WK-2801 module alone. It's a CYRF6936 module. Should the pinout remain the same as you suggested?
Thanks for your time.
30 Sep 2022 04:57 - 30 Sep 2022 04:59 #78102 by vlad_vy
Use Wiki to install your module to Devo7e.
www.deviationtx.com/wiki/rf_module_installation/devo7e
If one module is being installed, CSN should connect to the 'TMS' pin.
Last edit: 30 Sep 2022 04:59 by vlad_vy.
07 Jan 2024 12:53 #78349 by PanKek
After a year I finally got the time and install the RF module from my old WK-2801 pro, to Devo 7E.
I follow the pinout suggested by vlad_vy and it works fine.
Also now I can bind Devo 7E, with Spektrum SPM4650 (SRXL2 protocol) micro receiver. With the stock RF module I couldn't do it.
With 150mW output on TX, the range goes up to 520m before rxloss and GPS rescue begin (2.5" quad with Betaflight 4.4.2.).
So I guess now I am jumping to expressLRS pages for more range?
Time to create page: 0.377 seconds
