Problems with DevoDfuSe_v1.41_Win7
- Primera06
07 Oct 2012 14:35 #2026
by Primera06
Problems with DevoDfuSe_v1.41_Win7 was created by Primera06
Hello
I'm new here and I'm from Switzerland
I would like to shop on my Devo 8S Deviation 1.1.2
My problem is DevoDfuSe_v1.41_Win7 instaled and also updated the drivers but when I Run the program it finds the remote control I have not
It once had Works
Please someone can help me
I thank them in advance
greetings Raphael
It once had Works
greetings Raphael
- sbstnp
07 Oct 2012 16:19 #2027
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Problems with DevoDfuSe_v1.41_Win7
Make sure USB cable is inserted correctly.
Start TX with Ext button depressed, should go intro programming mode.
Run DFuse as administrator, this might be it.
Devo 10 + 4in1
- Primera06
07 Oct 2012 16:41 #2029
by Primera06
Replied by Primera06 on topic Problems with DevoDfuSe_v1.41_Win7
Thanks for the answer
I have already tried everything but still does not work unfortunately
The computer recognizes the controller but does not indicate it in the program
- coaster
07 Oct 2012 18:22 #2030
by coaster
Replied by coaster on topic Problems with DevoDfuSe_v1.41_Win7
try the last version 1.5.0, works fine on my Windows 7
cheers
Graziano
cheers
Graziano
- Primera06
07 Oct 2012 18:28 #2031
by Primera06
Hello
The version 1.5.0 I have already tried it, unfortunately, not
The program is not easy to control
not really looking further
- sbstnp
08 Oct 2012 01:39 #2036
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
If nothing works and you're using Win 7, set compatibility mode to Win XP SP3 for DFuse, it worked for me at one time.
Devo 10 + 4in1
- j35u5fr34k
08 Oct 2012 02:27 #2038
by j35u5fr34k
Replied by j35u5fr34k on topic Problems with DevoDfuSe_v1.41_Win7
Honestly, I had to use XP3. Couldn't get Dfuse to work at all on win7 even in compatibility mode.
- Primera06
08 Oct 2012 05:15 #2040
by Primera06
Hello
The problem still exists
With my computer had ever works and not all at once more
no one can help me
no one can help me
08 Oct 2012 07:07 - 08 Oct 2012 07:08 #2041
Replied by vlad_vy on topic Problems with DevoDfuSe_v1.41_Win7
Go to Device Manager and check STM device (should have a yellow exclamation mark next to it indicating it needs a driver to work)
Maybe you need run Device Manager from Control Panel as Administrator.
Device Manager->Right click on the STM device (should have a yellow exclamation mark next to it indicating it needs a driver to work)->Update driver->choose where to search for driver->Select the folder mentioned above, do not try selecting the x64 or x86 sub-folders as they will not work. You need to select the parent direct which has the .inf file. Click on OK. Several times it failed to install the driver but then worked when I unplugged the radio before clicking OK.
Last edit: 08 Oct 2012 07:08 by vlad_vy.
- Primera06
08 Oct 2012 10:40 #2042
by Primera06
That with the driver I made is on the newest state
The program was no longer about 3 weeks ago is still the autonomous control and Jezt
The program DfuSe_Demo_V3.0.2_Setup assumes control but I need so that other programs
- marc
08 Oct 2012 13:17 - 08 Oct 2012 13:19 #2043
by marc
Replied by marc on topic Problems with DevoDfuSe_v1.41_Win7
Download v1.5. from Walkera and follow the steps as described by Helipal:
image.helipal.com/helipal-devo8-update-firmware-big-1.jpg
Especially follow the steps regarding the setup of the driver.
Also install the application to "Programme (x86)" and not to "Programme", and choose the driver for 32-bit (even if you should use 64-bit Windows).
I installed Dfu on several computers in thi manner, and it always worked.
Marc
Marc
Last edit: 08 Oct 2012 13:19 by marc. Reason: Link
- Primera06
08 Oct 2012 18:25 #2047
by Primera06
I've done it like this but it's still not working, I know not what more do Jezt
I Thank you all for the help
- dado099
09 Oct 2012 06:56 #2089
by dado099
Replied by dado099 on topic Problems with DevoDfuSe_v1.41_Win7
Try this last:
please use
DevoDfuSe_v1.41_Win7.exe
and specify to install to new directory
c:\Programx86
For me it worked !
please use
c:\Programx86
For me it worked !
- Primera06
09 Oct 2012 10:55 #2099
by Primera06
Thank you for your help I've tried everything but it still does not work, the Devo 8 and 6 are simply not recognized by the program
I know nothing around Jezt also do what
- digitracer
09 Oct 2012 11:06 #2100
by digitracer
Replied by digitracer on topic Problems with DevoDfuSe_v1.41_Win7
Try different USB cable. Sometimes thinn cables don't work properly - even if the device is being recognized by windows.
Install everything on a second PC/Laptop.
If Deviation FW hasn't been installed already, have you checked/posted on the Walkera forum already?
- coaster
09 Oct 2012 12:14 #2102
by coaster
may you can test if the USB Port is recognised by the OS,
try to attach a Mobile Phone or something like that to test.
cheers
Graziano
cheers
Graziano
09 Oct 2012 12:22 #2103
Replied by FDR on topic Problems with DevoDfuSe_v1.41_Win7
I hope you don't try to upgrade your DEVO 8 with the UP-02.
I've seen such try before...
- Primera06
09 Oct 2012 17:03 #2113
by Primera06
I tried different USB cable and wrote the Walkera also can not help me
I was just at a colleague and had it on his computer when I made like him and went without problems
No I do not use the adapter UP02
- coaster
12 Oct 2012 02:44 #2175
by coaster
Any news Primera06 ?
cheers
Graziano
cheers
Graziano
- Primera06
13 Oct 2012 05:04 #2191
by Primera06
Hello
Thanks for the demand.
Today I have the Windows 7 set up again the thought that any is incorrect because it is all gone at the beginning but unfortunately I have no luck, the control will not appear in the Program.
I do not know anymore what to do
Time to create page: 0.800 seconds
- Problems with DevoDfuSe_v1.41_Win7
