Problems with DevoDfuSe_v1.41_Win7
13 Oct 2012 05:29 #2192 by coaster
Replied by coaster on topic Problems with DevoDfuSe_v1.41_Win7
it's your windows 7 64 or 32 Bit, there are different drivers
to install the x64 directory for 64 Bit and the x86 Directory for 32 Bit,
cheers
Graziano
13 Oct 2012 06:10 #2194 by Primera06
Replied by Primera06 on topic Problems with DevoDfuSe_v1.41_Win7
I have not tried it again but goes.
The controller is properly instaled but economically not appear in the Program.
I'm getting the full nose
16 Oct 2012 10:36 - 16 Oct 2012 10:43 #2280 by kosem
Replied by kosem on topic Problems with DevoDfuSe_v1.41_Win7
Hi Raphael,
I'm sorry, I don't come with a solution for you ... I just have the same problem with Win7 x64.
I mean everything is installed correctly, the driver is recognized but I can't launch the application. It won't be displayed but rather be "hidden" in the background.
On my wife's Vista laptop it works flawless.
Any help would be very appreciated!
WIN7 Event viewer:
Faulting application name: DevoDfuSe.exe, version: 1.5.0.0, time stamp: 0x4fbc9168
Faulting module name: DevoDfuSe.exe, version: 1.5.0.0, time stamp: 0x4fbc9168
Exception code: 0xc0000005
Fault offset: 0x000065bf
Faulting process id: 0x1768
Faulting application start time: 0x01cdab8ac02b5276
Faulting application path: C:\Program Files (x86)\Devention Upgrade Tools\DevoDfuSe.exe
Faulting module path: C:\Program Files (x86)\Devention Upgrade Tools\DevoDfuSe.exe
Report Id: fdde72eb-177d-11e2-adfb-5404a62c5e85
Last edit: 16 Oct 2012 10:43 by kosem.
16 Oct 2012 10:56 #2281 by Primera06
Hello
I have found the problem
You have, as usual, the program install and manage the drivers
Not Start Program
Right click on the sympol
then click Properties
Then, for compatibility
put a hook in the program in compatibility mode for:
then select Windows XP
I hope I can help you or others here have the same where
I thank you again to all who try to help me
16 Oct 2012 14:17 #2284 by kosem
I'm happy for you, enjoy :-)
I've tried already, it doesn't work.
I'm gonna open another thread with my problem, hope I could fix it.
06 Jan 2013 20:28 #4746 by clearprop88
Replied by clearprop88 on topic Problems with DevoDfuSe_v1.41_Win7
I got the DevoDfuSe tool working in another computer.
This computer has Windows 7, but it's the starter edition.
When I plug in my devo 8 it doesn't recognize it.
I get no response.
well I'm halfway there.
Also when I download the zip files from the Walkera site I get a notice that says that the zip SW is not free, and that I get a 30 day trial for the SW.
  • rbe2012
  • rbe2012's Avatar
06 Jan 2013 20:54 #4750 by rbe2012
Replied by rbe2012 on topic Problems with DevoDfuSe_v1.41_Win7
Trial? Are you sure that comes from the firmware and not from the zip-tool you use?
06 Jan 2013 22:16 #4756 by clearprop88
I don't know where it comes from. It suddenly appears when I unzip the files. I never saw it before. I assume it comes with the zip files.
07 Jan 2013 01:14 - 07 Jan 2013 16:13 #4765 by clearprop88
I got my Devo 6 working using the advice from vlad-vy.
I went into DEVICE MANAGER, and was able to load the Device driver.
Last edit: 07 Jan 2013 16:13 by clearprop88. Reason: correction
Time to create page: 0.391 seconds
