Devo7e work
22 Jan 2013 04:46 - 22 Jan 2013 04:47 #5352 by vlad_vy
Replied by vlad_vy on topic Devo7e work
Don't use high dbi antenna, they have narrow radiation pattern with maximum perpendicular to the antenna. Most used dbi = about 2-5 dbi, no more.
Last edit: 22 Jan 2013 04:47 by vlad_vy.
22 Jan 2013 06:05 - 22 Jan 2013 06:36 #5356 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo7e work
vlad_vy wrote: Most used dbi = about 2-5 dbi, no more.
OK, so I'd guestimate from it's size that the existing antenna is no more than 2dbi, would a 5dbi antenna give an appreciable range increase without a module hack required?
[EDIT] Does this pic represent what you mean for higher gains? ie., the pattern gets progressively narrower as the gain gets higher? SO you'd have to be more careful to always aim the antenna perpendicular to the model? ie. angled or 90degree antenna, and always moving your TX...
Last edit: 22 Jan 2013 06:36 by RoGuE_StreaK.
22 Jan 2013 07:47 - 22 Jan 2013 07:48 #5358 by vlad_vy
2dbi -> 5 dbi = 3dbi = 2 times of power = 1.4 times of range
Yes, this image is a good representation of antenna dbi and antenna directivity.
Last edit: 22 Jan 2013 07:48 by vlad_vy.
22 Jan 2013 09:18 #5359 by RandMental
Replied by RandMental on topic Devo7e work
That picture represents the gain at a single frequency (the resonante frequency of the antenna). As you move away from this frequency, up or down, the pattern stay the same, except the absolute gain reduces (the horizontal axis shrinks from both sides to the center.
Antennae design is a tradeoff between gain, directionality and bandwidth (and matching impedance). I seriously question any stub antenna, as those sold on eBay, with reported gains of more than 3dBi (x2). It is just physical and theoretically impossible to get these high gains from a passive ¼ wave, ⅝ or dipole antenna in that form-factor.
The Devo 7e antenna has a gain of 2.81 at 2405MHz and it drops to 1.12 at top of the band 2479MHz
22 Jan 2013 11:14 - 22 Jan 2013 11:20 #5361 by Xermalk
Replied by Xermalk on topic Devo7e work
PhracturedBlue wrote: Th V911 module will not be affected by this limitation on the CYRF module. I'll try to get you pin-outs tonight.
Would be appreciated, iv already prepared the v911 module with wires, just need to know where they go on the 7E.
Ps you might want to update the pdf with this tip.
Unsoldering the flysky module is very easy if you just connect all the pins with solder, then you can just pull it straight out when you heat the solder.
Then you still have all the pins, and their great for supporting you when you solder the wires to the module.
Last edit: 22 Jan 2013 11:20 by Xermalk.
22 Jan 2013 16:41 #5373 by PhracturedBlue
Replied by PhracturedBlue on topic Devo7e work
Here is the pin out:
From left to right:
1) Chip Select
2) CLK
3) MISO
4) MOSI
5) Reset
6) Vdd
7) GND
note that like the other Tx, you probably don't wanttouse the Vdd connected to the module, as it is likely battery voltage, an the V911 module requires 3.3V. You can get that from the 5pin header right below the module.
22 Jan 2013 16:48 #5374 by Xermalk
PhracturedBlue wrote: Here is the pin out:
From left to right:
1) Chip Select
2) CLK
3) MISO
4) MOSI
5) Reset
6) Vdd
7) GND
Thanks, I'm presuming you disassemble the 7E similar to how one would disassemble the 10? Haven't gotten around to opening up mine yet.
22 Jan 2013 16:50 #5375 by PhracturedBlue
Xermalk wrote: Thanks, I'm presuming you disassemble the 7E similar to how one would disassemble the 10? Haven't gotten around to opening up mine yet.
I dunno. my solution is:
take out all the screws and the rubber pads until it opens.
22 Jan 2013 17:48 #5377 by dehalo
Replied by dehalo on topic Devo7e work
Xermalk wrote: 7 ? ouch, i wonder how that would work with my master cp.
Mind making a Guesstimate on how long the range would be on a Master CP with 7 mW?
Anyway, im guessing this is what we would need to upgrade the range?
www.ehirobo.com/shop/product_info.php?products_id=11530
Edit: Hrm, only 7 solder points on the 7E Module? the 8s one seems to have 10
A quick range comparison using a Walkera V200DO2:
Devo 7E with Deviation @150 mW ~80 m
WK-2801 Pro (10 mW?) ~120 m
22 Jan 2013 17:54 - 22 Jan 2013 17:55 #5378 by Xermalk
From left to right:
1) Chip Select
2) CLK
3) MISO
4) MOSI
5) Reset
6) Vdd
7) GND
I Checked out the flysky pdf but its using different names for the pins.
So i'm unsure where the Flysky pins go
1) SCS -> Chip Select?
2) SCK -> CLK?
3) SDIO -> MISO?
5) GND ->7 GND
6) 3.3V -> 5 pin furthest right hole - Vcc
Last edit: 22 Jan 2013 17:55 by Xermalk.
22 Jan 2013 18:10 #5380 by PhracturedBlue
Almost.
SDIO<->MOSI
You don't connect to the chip-select pin with the Flysky module. you use the 'TMS' pin (unlabeled but it is the 2nd pin on the pin header below the module as in the Devo8/10)
22 Jan 2013 18:31 - 22 Jan 2013 19:22 #5381 by Xermalk
PhracturedBlue wrote: Almost.
SDIO<->MOSI
Just to be fully sure i got everything right.
Edit: Corrected pins.
Last edit: 22 Jan 2013 19:22 by Xermalk.
22 Jan 2013 19:10 - 22 Jan 2013 19:10 #5382 by PhracturedBlue
(1) is wrong. it goes to the 2nd pin of the 5-pin header (just like on the Devo8/10)
Last edit: 22 Jan 2013 19:10 by PhracturedBlue.
22 Jan 2013 19:23 #5383 by Xermalk
PhracturedBlue wrote: (1) is wrong. it goes to the 2nd pin of the 5-pin header (just like on the Devo8/10)
Image corrected, feel free to reuse it if you make a 7E/Flysky guide/pdf.
22 Jan 2013 19:30 #5384 by PhracturedBlue
Double-checking my notes, I have MOSI and MISO swapped in the list above. If so (3) connects to the 3rd pin from the right. I don't have my Tx in front of me, but it looks like the pinout of the module is actually:
CS
CLK
MOSI
MISO
RST
VCC
GND
22 Jan 2013 19:46 #5385 by Xermalk
PhracturedBlue wrote: Double-checking my notes, I have MOSI and MISO swapped in the list above. If so (3) connects to the 3rd pin from the right. I don't have my Tx in front of me, but it looks like the pinout of the module is actually:
CS
CLK
MOSI
MISO
RST
VCC
GND
Good thing i checked the thread before soldering heh, moving pin 3 1 step to the left on the rx then should fix it.
soldering 2&3 next to each other might be a bit tricky though. Ill likely solder one onto the rx and the other on the 7E pcb.
22 Jan 2013 21:14 - 22 Jan 2013 21:18 #5392 by Xermalk
Done soldering, but i cant seem to get it to bind to my v939.
Binding still works with devo, so at least nothing is shorted.
Is there any way to check that everything is ok without binding it to something?.
This is how i soldered it
Last edit: 22 Jan 2013 21:18 by Xermalk.
22 Jan 2013 21:22 #5393 by PhracturedBlue
It looks right to me. I can probably put together some sort of debug build to save a log file to determine what is going on.
I don't think I've tested the V911 module since I reworked the code for the 7e, so it is could be a software bug too.
I need to do more testing I guess
22 Jan 2013 21:27 #5395 by Xermalk
Ok, ill just semi fixate it inside until its been tested, or you release a test build.
Im using the same nick, Xermalk on skype in case you want realtime testing done.
22 Jan 2013 21:31 #5397 by PhracturedBlue
Just to verify: What is the process you tried to use to bind your V939?
Time to create page: 0.580 seconds
