Devo7e work
11 Feb 2013 15:15 #6253 by PhracturedBlue
Replied by PhracturedBlue on topic Devo7e work
You could theoretically wire it new buttons into the matrix, but you can't use them for switches. The rules with the matrix is only one button can be detected at once. so you can't 'hold one down' and still use the buttons, and that is what would happen if you tried to wire up a switch.
11 Feb 2013 15:29 #6256 by cmpang
Replied by cmpang on topic Devo7e work
PhracturedBlue wrote: You could theoretically wire it new buttons into the matrix, but you can't use them for switches. The rules with the matrix is only one button can be detected at once. so you can't 'hold one down' and still use the buttons, and that is what would happen if you tried to wire up a switch.
I understand different scanning algoithm gives different beheavior.
My thinking is the routine would scan ALL cross points in the matrix (continoue scanning to the end no matter how many closes have been detected), should it detects B5/C7, it would register and hold it until the next scanning cycle..
11 Feb 2013 17:10 #6262 by PhracturedBlue
This page illustrates it well I think.
pcbheaven.com/wikipages/How_Key_Matrices_Works/
You can reliably read 2 concurrent presses a button matrix, but if you read 3 you can get masking or ghosting, making it difficult to figure out what is going on. This is a hardware issue which can't be overcome with different algorithms to my knowledge without further modifying the hardware.
11 Feb 2013 18:11 #6264 by cmpang
PhracturedBlue wrote: This page illustrates it well I think.
thank you for the excellent explaination...
further elaboration on the 7e button matrix let me think like it this way:
assumming that column is the input to the matrix, then if I put a didoe in series with the to be added-on switch at B5/C7, then it would block the backward current coming from the buttons on other columns on the same row (C7) that would flow back into column B5 otherwise.. that seems to be abe to avoid the ghosting and masking problem..
the same applies to the B5/C9 switch
adding a mere two diodes is still a resonably simple mod..
11 Feb 2013 18:48 #6269 by dehalo
Replied by dehalo on topic Devo7e work
You seem to know your electronics!
Can you tell me how I would connect a Devo 8s module instead of the 7E TX module?
  • rbe2012
  • rbe2012's Avatar
11 Feb 2013 18:51 #6270 by rbe2012
Replied by rbe2012 on topic Devo7e work
You would have do place a diode in every button's line, not only for the additional buttons to keep it working.
You would have to measure / read the button matrix code to understand in which direction the diode has to be used (high on rows or low on rows).
Wouldn't it be easier to look for unused inputs where you can do whatever you want? There must exist a lot (GPIOD: only pin2 used, when I have read correctly). I am quite sure that some of them will have connections/testpads where a wire could be easily soldered.
11 Feb 2013 20:11 #6277 by PhracturedBlue
As RBE said, it is not enough to add diodes only to the new switches. they'd need to be added to all of the existing switches.
11 Feb 2013 21:43 - 11 Feb 2013 21:49 #6281 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo7e work
From a different perspective, could you use momentary buttons for soft-toggle? Not as handy I know, but could be a way around the above mentioned issues?
For example, throttle hold may not be something you need a physical toggle for, you know when it's turned on or off; then frees up the physical toggle for another purpose like dual rates or something, where a physical indicator of state is more readily required?
Momentary also doesn't need to be a push style button, could use the momentary toggles like some TX's have for Trainer; then you've got a big lever to quickly flick, but only interacting with the matrix in momentary mode.
Just throwing out some possible routes, to see if anything sticks :P
Last edit: 11 Feb 2013 21:49 by RoGuE_StreaK.
11 Feb 2013 21:56 #6282 by domcars0
Replied by domcars0 on topic Devo7e work
RoGuE_StreaK wrote: For example, throttle hold may not be something you need a physical toggle for, you know when it's turned on or off; ....
I'm sorry but I do not understand what you mean? To fly my heli, I really
need the physical toggle to switch off quickly the motor in case of emergency...
11 Feb 2013 21:58 #6283 by PhracturedBlue
throttle hold may be a bad example. flight mode or dual/rates are something you could probably take 2 presses to enable if needed though, and may better fit with what Rogue is talking about. Doing it isn't hard. I'd wantsome consensus that it is actually valuable though.
11 Feb 2013 23:23 #6286 by cmpang
to me the 7e is unique for its tiny size but with a model grade control sticks. Carrying it around with a micro heli like the VL911 is a breeze. Too bad it comes short of output channels just because it lack the number of input switches..
Anyway, I will do an experiment in these two days using two diodes to short out B5/C7 and B5/C9 to test if it really affects the other button's operation. Right now I can confirm that no two buttons cannot be pressed at the same time...
12 Feb 2013 00:02 #6288 by PhracturedBlue
I drew out the actual graph, and with the specific alignment of the 7e (B5/C7, B5/C9) and I think you are right that a switch + diode is sufficient to be able to detect those 2 switches plus one additional button-press.
So give it a shot. It should not be hard to patch it together.
12 Feb 2013 00:17 #6289 by cmpang
PhracturedBlue wrote: I drew out the actual graph, and with the specific alignment of the 7e (B5/C7, B5/C9) and I think you are right that a switch + diode is sufficient to be able to detect those 2 switches plus one additional button-press.
good news. I will do the hard wiring today or tomorrow but.need your update on the fw for these switches to work..
12 Feb 2013 00:35 #6290 by PhracturedBlue
Do you know how to build and patch the code? If so I can provide the code.
Otherwise here is a completely untested build which creates the AIL_DR and ELE_DR switches.
This is only useful for cmpang with his modified tx. It probably won't break for anyone else, but I make no guarantees.
12 Feb 2013 02:40 #6291 by RW9UAO
Replied by RW9UAO on topic Devo7e work
software SPI need 4 pin - MISO-MOSI-SCK-CS and atmega8 help as to use 15 3-pos switches.
12 Feb 2013 07:04 - 12 Feb 2013 07:07 #6296 by OnceAFly
Replied by OnceAFly on topic Devo7e work
How's the range test on shorted diode mod?
Last edit: 12 Feb 2013 07:07 by OnceAFly.
12 Feb 2013 08:08 #6298 by cmpang
PhracturedBlue wrote: Do you know how to build and patch the code? If so I can provide the code.
thanks very very much PB.. I will wire my 7e up and perform a test soonest possible...
12 Feb 2013 08:11 #6299 by cmpang
OnceAFly wrote: How's the range test on shorted diode mod?
too busy at the moment due to our Chinese New Year.. too many social gathering.. initial range test at home when set to 1mW shown performance is no different from my Devo10. Will perform field range test soonest possible.
12 Feb 2013 08:41 - 12 Feb 2013 08:42 #6300 by Xermalk
Replied by Xermalk on topic Devo7e work
150m+ along the ground (tx and rx 1.5m above ground). As thats where i ran out of space when testing with my master cp (it has a tiny single antenna).
Should be farther up in the air. Im waiting for temps above 0 before i try another range test.
Last edit: 12 Feb 2013 08:42 by Xermalk.
12 Feb 2013 10:45 #6301 by cmpang
PB, I have wired up the switches with diodes and have the following observation:
1. After mapping the AIL_DR and ELE_DR to Ch3 and Ch4, it is able to control both channels output by flipping the switches.
2. However, the wiring have to be done on B7/C7 and B7/C9 instead of B5/C7 and B5/C9 according to the button matix table
3. Enabling either or both switches would lock up all the front panel buttons
4. After enable Ch3 by AIL DR switch, it can be disabled by engauging Thottle Up trim. This lead me to point 5 below.
5. Revisiting the ghosting/masking let me think that we have to engauge 3 or more button in order to confuse the matrix. However, after disconnecting all my wiring for further test, I found that the current firmware seems not able to detect two buttons at the same time. For example, I cannot perform trimmig on both elevator and rudder. This lead me think that the scanning routine is not a 'go through' but stop further scanning once a button is detected.
The is the observation so far. Not successful but very promising... would be glad if you can revisit the scanning procedure to see if there is any hint...
Time to create page: 0.514 seconds
