Devo7e work
13 Jun 2013 22:21 #10936 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo7e work
Welcome to the fold stingrazor ;)
I haven't tried it, but I think you should be able to grab the model bin files using dfuse, powering the TX when holding EXT, and supposedly "upload" will grab stuff from the TX (going on one thing I read, don't have either TX or dfuse here to test)
Or maybe with ENT held you might see the bin files under USB device in a file explorer?
You can grab some stock model bins from the Walkera site as a basis, if the above doesn't work
link
14 Jun 2013 04:44 #10941 by FDR
Replied by FDR on topic Devo7e work
You can download your model configs one by one using the DfuSe tool, however you can't use them in deviation. You have to manually reconfigure them...
14 Jun 2013 04:49 - 14 Jun 2013 04:50 #10943 by vlad_vy
Replied by vlad_vy on topic Devo7e work
I have a question, is it hard to create application for conversion original Devo models to Deviation format?
Last edit: 14 Jun 2013 04:50 by vlad_vy.
14 Jun 2013 05:09 - 14 Jun 2013 05:10 #10944 by RoGuE_StreaK
Hmm, I originally read it as asking if a backup could be saved in case you went back to stock firmware, but now I'm not sure. If not, then no, there currently does not exist an easy transferal method.
vlad, I guess the first question is whether anyone has found a way to read a bin file as plain text? Won't know what's involved until we can see if anything correlates in the files. I'd also guess that all of the devo TXs have a different bin format, complicating things.
Maybe a very simple "devo 0-100 range" to "deviation -100 - +100 range" converter could be a useful tool as a starting point? Slot in a 0-100 figure, press Convert, and get the corresponding deviation figure?
Last edit: 14 Jun 2013 05:10 by RoGuE_StreaK.
14 Jun 2013 05:15 - 14 Jun 2013 05:17 #10945 by stringrazor
Replied by stringrazor on topic Devo7e work
I do want a backup but I also need a quick way to document the existing models so I can recreate them after switching firmware.
Last edit: 14 Jun 2013 05:17 by stringrazor.
14 Jun 2013 05:23 #10946 by RoGuE_StreaK
Ah. Quickest way at the moment is probably pen and paper, and going through the menus systematically. :blink:
14 Jun 2013 09:58 #10949 by FDR
vlad_vy wrote: I have a question, is it hard to create application for conversion original Devo models to Deviation format?
I thought I will do one, but didn't do it.
The difficulty is that every DEVO tx has it's own binary format, which is very time consuming to reverse engineer.
Furthermore I have only a DEVO 8, so I could only do it for that one.
I know someone did it for the DEVO 7, but that is not supported by deviation, so doesn't really matter here...
14 Jun 2013 19:59 #10970 by dehalo
Replied by dehalo on topic Devo7e work
A bit more elegant than pen paper would be to use the emulator to set up the models with the TX besides. Then you can upgrade to Deviation and copy the models from the emulator to the TX.
14 Jun 2013 22:51 #10975 by Lyndros
Replied by Lyndros on topic Devo7e work
Hi guys,
Thanks for the range mod I did it, was pretty easy and also I took the opportunity to add a nice power led to my devo 7e... :-)
On the other hand I would like to know if its feasible to fly a 450 after the range mod without any range problem ?
Some people will kill me for what I am gonna say. For my 450s I am using my DX7 but actually I feel more comfortable with 7E and deviation... Can you guys confirm me that ? Or I should expend some money on a 8S.
Thanks all!
15 Jun 2013 09:42 #10983 by Xermalk
Replied by Xermalk on topic Devo7e work
Lyndros wrote: Hi guys,
Thanks all!
With the range mod there shouldn't be any real difference in range compared to a devo 10/8.
Hopefully someon e that has done a propper range test with a dsm2/dsmx/walkera fullsize reciver can awnser.
I have only done a range test with the master cp and got to ~140m. But the mastercp has a single tiny antenna.
15 Jun 2013 09:50 #10984 by dehalo
Can you please provide some info on the Power LED (what part, where connected...)?
15 Jun 2013 21:14 #10996 by RandMental
Replied by RandMental on topic Devo7e work
Lyndros wrote: On the other hand I would like to know if its feasible to fly a 450 after the range mod without any range problem ?!
Our tests have shown the maximum power output of the Devo8s and a modified Devo7e is about the same. One difference is the antenna, on the Devo8 one can tilt the antenna up to be perpendicular to the line of sight to the model. If you hold the Devo7e upright so the antenna is also perpendicular to the model, you should get similar distances.
15 Jun 2013 21:37 #10997 by Xermalk
you should also be able to remove the plastic antenna cover, and position the Devo 7E antenna as you like.
Though beware of getting crap in the tx, so you might have to plug up the hole.
16 Jun 2013 17:57 - 16 Jun 2013 19:27 #11015 by Xermalk
Currently doing a battery test with my devo 7e with diode mod and flysky module.
I left my 2700 mah nimis charging overnigh.
I set my tx to dsm2 / 100mw tx power
I enabled the backlight at level 1.
Voltage started at 5.40V
It is now currently at 4.90V after 2h 35m and 19 seconds.
Will do a update again when it hits 4.70V
Edit: 3h 25 minutes.
Last edit: 16 Jun 2013 19:27 by Xermalk.
16 Jun 2013 19:28 #11018 by sbstnp
Replied by sbstnp on topic Devo7e work
I'm interested in your results. I used LSD NiMH packs for a while but I came back to LiPO, my Devo 10 is lighter and I can recharge my 2500mah pack every week or so, maybe 2 weeks if I don't fly a lot.
I never exactly measured but I think I get around 10 hours of full 100mw, 15% backlight on flight time.
Xermalk wrote: Currently doing a battery test with my devo 7e with diode mod and flysky module.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
16 Jun 2013 19:42 - 16 Jun 2013 20:06 #11019 by Xermalk
sbstnp wrote: I'm interested in your results. I used LSD NiMH packs for a while but I came back to LiPO, my Devo 10 is lighter and I can recharge my 2500mah pack every week or so, maybe 2 weeks if I don't fly a lot.
Doesn't the Devo 10 run a ~50% higher voltage? it uses 6 AA battery's instead of the 7E's 4.
A 2500mah pack for the 10 will last much longer then 2500 mah for the 7E.
Edit: I'll drain mine down to 4.2V and see what happens.
Edit2: 4.7 -> 4.4 10 Minutes.
4.4 -> 4.2 4 Minutes
Total 3 Hours 39 Minutes from 5.4V to 4.2V
Last edit: 16 Jun 2013 20:06 by Xermalk.
16 Jun 2013 20:05 #11021 by sbstnp
Is uses 8xAA. That's double the wattage, theoretically. No idea about losses, though.
My Devo 10 used to become unreliable around 1.05V/cell or 8.2V. Usually I was recharging well before that but I did a few experiments just to find out how far I can stretch the pack.
What I don't like about NiMH is the self discharge rate. Even LSD cells still have much much higher self discharge compared to LiPOs.
Devo 10 + 4in1
Spektrum Dx9
16 Jun 2013 20:09 #11022 by Xermalk
sbstnp wrote: Is uses 8xAA. That's double the wattage, theoretically. No idea about losses, though.
Im using NiMh's as i don't really mind using them, and i have several spares around.
As im using the built in charger in the Devo7E their usually well charged for when i want to go out and fly.
17 Jun 2013 00:41 #11027 by dc59
Replied by dc59 on topic Devo7e work
Hi Xermalk,
I recently got a FS GT3B tx for my RC CARs,and I found something might help,Someone changed voltage regulator from 7805 to RECOM R-785.0-0.5 high efficiency regulator,it could extend battery life ~50%.
Could it be used in DEVO7E ro DEVO10?
info:
overkillrc.webs.com/gt3b.htm
Voltage Regulator Modification section.
Thanks.
17 Jun 2013 12:10 #11051 by cmpang
Replied by cmpang on topic Devo7e work
dc59 wrote: ....Could it be used in DEVO7E ...
Thanks.
7e doesn't need that. It can operate on as low as 3.7V.. I used 1S to power my 7e for more than two months now..
cmPang
Time to create page: 0.393 seconds
