Devo7e work
17 Jan 2013 11:23 #5109 by Xermalk
Replied by Xermalk on topic Devo7e work
old4570 wrote: If you can flash the radio , what is stopping the reading and saving of the Firmware [ OS ] ?
Sorry , the Devo7e tempts me ..
Lots of catching up to do ..
Walkera DfuSe does not support backing up firmware. And as far as i know noone has bothered trying to write one themselves, as DfuSe does its job.
17 Jan 2013 11:30 #5110 by sbstnp
Replied by sbstnp on topic Devo7e work
Read protection prevents you from doing that. These chips can lock themselves pretty tight.
If you don't have it yet buy the 10, much better radio.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
17 Jan 2013 11:33 #5111 by Xermalk
+1 on this, i wish i went for a 10 instead of a 7e myself. Only having normal and st1 is annoying as you usually use normal simply to spool up the helis.
  • rbe2012
  • rbe2012's Avatar
17 Jan 2013 12:08 - 17 Jan 2013 12:08 #5114 by rbe2012
Replied by rbe2012 on topic Devo7e work
Xermalk wrote: Unless they'v updated the manual it mentions nothing of this.
Sorry: I looked for 7E but got results for Devo7 and did not became aware.
Last edit: 17 Jan 2013 12:08 by rbe2012.
17 Jan 2013 12:46 #5115 by old4570
Replied by old4570 on topic Devo7e work
Hmmm , flash tools usually read , wipe , write and read to verify .
Sounds like it should be possible to lift the original firmware from the chip on the Tx ..
hmmmm
  • rbe2012
  • rbe2012's Avatar
17 Jan 2013 13:26 #5116 by rbe2012
old4570 wrote: Sounds like it should be possible to lift the original firmware from the chip on the Tx ..
This might not be so easy because ST has built-in read protection (look here: STM32 proprietary code protection overview ).
17 Jan 2013 13:40 #5117 by old4570
Wow - OK , that looks interesting ..
So much for writing a new flash tool , or modifying the existing one to read . Hmmmm
Might still be worth a look , Hack Devo !
17 Jan 2013 14:21 #5118 by PhracturedBlue
Replied by PhracturedBlue on topic Devo7e work
Well, I found the bug (though I odn't fully understand it yet), and now the J6pro binds ok too :)
So I just need to test the DSM and WK protocols, and will be ready for a 1st release.
17 Jan 2013 15:35 #5119 by Xermalk
Im guessing flysky support/testing wont be until release 2 or 3?
Im currently lying low until walkera releases a firmware or deviation has been fully tested, as i only have one tx.
17 Jan 2013 19:17 #5124 by PhracturedBlue
If 2 people are willing to install deviation, I could possibly extract the Walkera firmware from the tx. because of the process I'd need to use, it requires 2 tx that are running Walkera's firmware. Each one would be corrupted in the process and would need to move to Deviation after running the script with no guarantee of going back.
Another problem is that even if it worked, I don't have permission to distribute Walkera's firmware, which means I couldn't actually give it to anyone :(
Because I am not sure it is even possible, and it would be quite a bit of work to develop, and don't know if there are actually anyone out there willing to proceed, I'm not really enthusiastic about spending time on it.
17 Jan 2013 20:16 - 17 Jan 2013 20:17 #5126 by Xermalk
Well, you can count me in as soon as deviation for 7e has been tested to work with A7105.
Main reason i want to use deviation is beeing able to fly my v911's and v939 with the 7E.
Though it would be much better if walkera would release the firmware themselves.
Last edit: 17 Jan 2013 20:17 by Xermalk.
17 Jan 2013 22:41 #5128 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo7e work
PhracturedBlue wrote: So I just need to test the DSM and WK protocols, and will be ready for a 1st release.
Forgive my ignorance, but does that include DSM2, and/or is it a relatively simple mod once those are proven?
Reason I ask is I'm holding off purchase of the 7E depending on whether you think it can support other cheap receivers, such as the DSM2 OrangeRX R610 ($6), or others in the sub-$10 category. That said, I most probably will only be flying the Devo model for some time before trying to bring across my other stuff, so hopefully by that time WK have released an official firmware for easy reversion.
Do you ever sleep? :lol:
17 Jan 2013 23:25 #5131 by PhracturedBlue
Sorry, once verified Deviation-7e will support everything supported by Deviation-6/8/10
That means (currently):
without any modification: Devo, WK2401, Wk2601, Wk2801, DSM2, DSMX, J6Pro
with A7105 module: Flysky, Hubsan
There is no 'DSM'
18 Jan 2013 03:47 #5134 by PhracturedBlue
Ok. I've released the 1st Devo7e build here:
www.deviationtx.com/forum/builds/1312-de...ae43d-devo7e-support
It is only lightly tested, so if you aren't willing to have your Tx broken for a couple days, I don't necessarily recommend it.
It has been tested with all CYRF based protocols (see above) and found to work ok.
If anyone is willing to take the risk, I will attempt to provide quick resolution to issues that are found.
18 Jan 2013 04:45 #5137 by RoGuE_StreaK
PhracturedBlue wrote: It has been tested with all CYRF based protocols (see above) and found to work ok.
Good enough for me, just bought the SuperCP+Devo7E :P
18 Jan 2013 08:47 #5142 by Tom_ate
Replied by Tom_ate on topic Devo7e work
...I will go for Devo7E-DeViation tomorrow or latest sunday !!! Many thanks for spending 3 weeks especially for us 7E-Users!
BTW: I need no "going back"-path to original Firmware - and I am sure, nobody else would really need it...
Kind regards,
Matthias
18 Jan 2013 17:11 - 18 Jan 2013 17:12 #5156 by Xermalk
PhracturedBlue, when you have time could you locate the pins needed for adding the A7105 module?
Iv got some of free time this weekend so adding one to my 7E would be a perfect project.
Also, the module will be deactivated when flying the devo protocol right? so There's no garbage data being sent over the 2.4 fhz band.
Last edit: 18 Jan 2013 17:12 by Xermalk.
19 Jan 2013 00:18 - 19 Jan 2013 00:20 #5167 by RoGuE_StreaK
Following Xermalk's post I've been reading up on the addition of the A7105 module, and it mentions the Turnigy 9X; my question is, does it support the "v2" receivers ? HK make a point of saying that the v2 receiver is only compatible with the 9X v2, and vice-versa. Tried searching the web for an answer but didn't see one.
Last edit: 19 Jan 2013 00:20 by RoGuE_StreaK.
19 Jan 2013 11:04 #5185 by old4570
Yeah , + Id like to bind to the orange Rx from HK , so I can fly a 250 and a micro on the same Tx
19 Jan 2013 15:51 - 19 Jan 2013 16:08 #5193 by magiceddi
Replied by magiceddi on topic Devo7e work
Untested, but this is supposed to be the original 7e firmware...
hth,
Boris
EDIT PB: Can't distribute Walkera's firmware on this site without permission. I've removed the attachment until rights are confirmed
Last edit: 19 Jan 2013 16:08 by PhracturedBlue.
Time to create page: 0.481 seconds
