Devo7e work
- SadSack
06 Jan 2013 11:02 #4727
by SadSack
Replied by SadSack on topic Devo7e work
Just a random thought ...
Any reason that we can't swap out SST25VF016B would there be anything to be gained would it help keep features?
Its only 8 pin soic after all and cheap enough.
www.aliexpress.com/item/SST25VF032B-80-4...pping/727649109.html
And
uk.rs-online.com/web/p/flash-memory-chip...462677633D424F544826
And
06 Jan 2013 11:19 #4728
(If it would help) This would divide the users in those wo are able and willing to solder inside their tx and those who are not. Two different versions of deViation should exist (and be maintained...).
Replied by rbe2012 on topic Devo7e work
SadSack wrote: Just a random thought ...
- SadSack
06 Jan 2013 13:13 #4733
by SadSack
That's fair comment. Did cross my mind while making breakfast
06 Jan 2013 13:25 #4734
Replied by PhracturedBlue on topic Devo7e work
It wouldn't help anyway. We can't use the flash for code-space.
What would help would be to swap out the MCU for the STM32F103RCT6, but the number of folks with the equipment to swap a 64pin LQFP package is probably pretty small.
If I could figure out how to use flash for code space, it would make things much better, sinc 2MB of flash is a lot more than we need for resources and model data.
I am currently battling RAM usage. We use too much RAM in stack and heap today.
- SadSack
06 Jan 2013 13:36 #4736
by SadSack
Well I'd swap it but you'd have to support it and well the hand full that would do it wouldn't be worth your time. So can offer nothing that helps
- SadSack
06 Jan 2013 13:39 #4737
by SadSack
btw i don't have have any special tools. Just sharp blades/Flux and soldering iron. Can use something other for Solder braid but need flux for sure.
- dc59
07 Jan 2013 07:38 #4778
by dc59
yes,i see.
I mean that dose devo7e hardware support 100mw output?
Replied by dc59 on topic Devo7e work
Tom_ate wrote: ...up to now there is no Devo7E deviation version...
yes,i see.
07 Jan 2013 19:41 #4815
The Devo7e identifies as being '10mW' but that doesn't mean anything. Until I can take the shield off, i won't know what it can actually do.
I got slowed down by unrelated stuff, but did manage to get Deviation to boot on the Devo7e. Currently there are no menus, and no way to save changes, so it isn't useful for anything other than testing that the hardware works. I'm struggling to figure out how to handle INI files. My original idea of translating them into binary on the PC before uploading is still very appealing, but I'm having difficulty actually doing it without a large amount of maintenance code which I don't want.
07 Jan 2013 21:44 #4826
Have you thought about shrinking the ini-files to raw data where you can find values at fixed positions? You will have some overhead for unused / unset values but this could perhaps be controlled by flags. This way the file could be small (ok, does not matter) and the code for extracting informations could be easy (no converting from strings, no search in the file, binary numbers can directly used...).
When I wrote this down I got more and more sure that you reflected this already. When I unterstand the problem correct, then the code needed for handling ini-files with all their advantages takes too much space. If we could go without
- random places for attributes and their values in the file
- number values written as strings
- open length of values (strings)
- reconverting numbers to strings when saving (might be necessary for displaying too)
it could bring some spare code space.
08 Jan 2013 02:14 #4828
We had a discussion about this back when i decided on the ini file. to make an extensible file-format, you need to have index tables and other stuff that allows you to flexibly define parameters. While that code would probably be smaller than the code we have, it wouldn't help much. It would also mean i need to maintain 2 different slutions (since the ini syntax is far superior for tx that can support it)
using a memory-dump of the relevant structures requires virtually no code, so is ideal, but requires some mechanism to generate those files on the host-PC (ideally without needing to write/support a lot of additional code). I have an idea that I'll give a try, and see how well it works.
08 Jan 2013 06:31 #4832
Perhaps the emulator could be used if he could understand both formats?
- RandMental
08 Jan 2013 10:33 #4840
by RandMental
Replied by RandMental on topic Devo7e work
The emulator could become the user interface for such a PC based model:
1) Model Upload
2) Model Download
3) Model New Model
4) Model Edit (existing model)
5) Model Copy (duplicate existing model)
6) Model Compare (to another model)
7) Model Archive (to PC disk)
etc.
May be such a PC suppport environment for Deviation is not a bad idea!
1) Model Upload
2) Model Download
3) Model New Model
09 Jan 2013 08:55 #4852
Replied by FDR on topic Devo7e work
Lost message:
suvsuv wrote:
Here is a sample project showing how to run a program from external NOR Flash, I don't try it as I don't have Keil and JLink, but one of my friends told me it works. The original post is in Chinese, if you are interested, I can have the post translated in English.PhracturedBlue wrote: It wouldn't help anyway. We can't use the flash for code-space.
Even it is possible to run codes from the NOR flash, it could be very slow and might not be usable for deviation as the TX program is timing-critical. You might consider only put some large size constants into the NOR Flash
12 Jan 2013 05:34 - 12 Jan 2013 05:34 #4939
FYI, while I haven't been around here for the last week, it doesn't mean I haven't been busy.
I've been doing major surgery to the GUI to drastically reduce memory usage.
I have a branch I'm working on here:
bitbucket.org/PhracturedBlue/deviation7e
The code as it is doesn't fit on the 7e, but I'm primarily working on reducing RAM usage. I'm targetting 6kB of RAM reduction (down to ~10kB on the 7e). My hope is that I can then fit a full page of ROM into ram, and can then run programs on the 7e. I'm then hoping I can load the protocol code into RAM. If it works out, I'll have enough room to support model ini files. As I've looked at it, I am really not happy with a solution without this feature.
The amount of work is really large, so it is taking a lot longer than I'd hoped.
Last edit: 12 Jan 2013 05:34 by PhracturedBlue.
- Xermalk
13 Jan 2013 18:21 - 13 Jan 2013 18:26 #4984
by Xermalk
Replied by Xermalk on topic Devo7e work
Wonderful, would it be possible to extend the number of modes on the 7e, having only normal and st1 is very limiting (one could use the unnecessary trim tabs for fbl helis atleast).
Edit, has Walkera released any updates for their 7e firmware?
Last edit: 13 Jan 2013 18:26 by Xermalk.
13 Jan 2013 21:33 #4991
So things are looking good.
It has taken a lot of effort, but I've reduced the Devo10 build by 24kB of ROM and almost 7kb of RAM without significantly changing functionality.
Part of that was done by using improved stdlib functions, but the hard partwas reworking the GUI to only allocate exactly the number of widgets needed, and removing the virtual-page support (which while easy to use was memory intensive)
The devo7e build now fits in the available ROM and RAM. I removed A7105 support (no Flysky/Hubsan) to achieve that though, so I am not done yet.
The good:
* Devo7e build has INI support (full compatibility with all model files)
* There is more than 4kB of RAM available. This should be enough to run 'programs' from Flash ROM (specifically the protocol code)
The not so good:
* Devo7e does not have language support. There really isn't much to be done here. Just not enough RAM. One possibility would be to build different dfus with the languages compiled in.
* Devo7e does not support the 'standard' mixer. It takes up ~10kB of ROM which just isn't available. Even getting rid of the 'Advanced' mixer doesn't make it even close
* Devo7e does not support the A7105 module. This is next on my list to remedy
* The changes have completely trashed the Devo8 build. merging the code is going to take a large amount of work.
The good:
The not so good:
- Xermalk
13 Jan 2013 23:36 - 13 Jan 2013 23:41 #4993
by Xermalk
Would it be possible to have separate dfus for the protocols? I'm guessing most wont be using all protocols. That way one could go with only the ones needed, saving space.
Edit: if you get the A7105 working, will there be a guide on how to wire/solder it? id love to rip one out from a faulty 911 tx(bad sticks) and use in my 7e.
Last edit: 13 Jan 2013 23:41 by Xermalk.
14 Jan 2013 02:50 #4995
Well, as I mentioned in a previous post, I've now implemented the protocols as loadable modules. This saves about 14kB of ROM (10kB if you don't count the A7105 stuff) at a cost of 4kB of RAM.
So I now have 10kB of ROM free and can support as many protocols as needed. I can use that 10kB of ROM for the 'Standard' mixer (though it doesn't leave any room for future expansion).
Now I just need to get eveything cleaned up and we should be ready for an Alpha release
- RoGuE_StreaK
14 Jan 2013 06:16 #4998
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo7e work
I'll be watching this thread with interest, good to see progress.
I'm contemplating buying a Super CP with a Devo 7E, depending on the outcome here; I want to move from my analogue 36MHz TX to a programmable 2.4GHz, with cheap available RXs. Previously I was going to get a Turnigy 9X, but if the 7E can be made to bind with the OrangeRx R610, then a Super CP combo for $140 shipped looks like a good deal to me!
I think I won't mind a "mini" TX, as I've become used to using the TX of the NE Solo Pro II, and I want something portable. Want a TX for use with a 400-size CP heli, a 4ch plane, and a tricopter, so don't need too many extra features. Though would be interesting to see if another channel or two can be hacked in, using the blank spaces where switches are in the Devo6? Any obvious unconnected spots on the main board?
Or as someone suggested in another thread, using the menu buttons for dual purposes?
Time to create page: 0.442 seconds
- Devo7e work
