Battery beep
- domcars0
05 Jan 2013 17:47 #4704
by domcars0
Battery beep was created by domcars0
PB as you are here .. Have you an idea of how often firmware enter the main.c::BATTERY_Check() ? I'm playing with code to have multiple bip when TX battery is low.
05 Jan 2013 18:02 #4705
Replied by PhracturedBlue on topic Battery beep
It is called every 100msec in the LOW_PRIORITY section.
The other call only executes on powerdown.
Also, Please create new topics for new ideas. I don't really like having threads polluted with unrelated topics. It makes search very hard.
- domcars0
05 Jan 2013 18:14 #4706
by domcars0
Replied by domcars0 on topic Battery beep
OK thank you and sorry for posted in bad topic
05 Jan 2013 18:15 #4707
take a look at the timer code. that beeps every several seconds after going negative. it'll give you an idea how to make the battery beep continue.
- domcars0
05 Jan 2013 20:01 - 06 Jan 2013 17:30 #4709
by domcars0
I've made code modification in the main.c file...
Now Battery alarm is beeping every 5 secunds.
It works on my Devo10 and in the devo8 emulator.
bitbucket.org/destructionBlack/deviationdevo10/commits/all
Last edit: 06 Jan 2013 17:30 by domcars0.
06 Jan 2013 03:51 #4719
I would just remove the use of 'warned' for bit 0x02 altogether, you don't need it.
I'd probably also use CLOCK_getms() instead of a counter, so it is more obvious exactly how frequently to warn.
- domcars0
06 Jan 2013 09:16 - 06 Jan 2013 09:29 #4724
by domcars0
Hi PB,
I kept the warned 0x02 bit in case of hysteresis issue ( in the worst case we can have a beep every 200ms
) , but for sure you can remove it ...
We can also use the CLOCK_getms() but I tought that use of a counter variable is much less power hungry (no function call) and beep interval is not critical at all.
Last edit: 06 Jan 2013 09:29 by domcars0.
Time to create page: 0.165 seconds
- Battery beep
