USB HID Joystick & PPM-In program
- SadSack
25 Apr 2013 03:55 #9183
by SadSack
Replied by SadSack on topic USB HID Joystick & PPM-In program
Would it be hard to connect GPIOA.10 to trainer port?
Other TX can't do both without hold switch on.
I personally wouldn't mind connecting it but not everyone wants to solder.
- hmjack2008
25 Apr 2013 04:18 - 25 Apr 2013 08:20 #9185
by hmjack2008
Replied by hmjack2008 on topic USB HID Joystick & PPM-In program
(1) the Walkera Cable
(2) my cable (my own ideas in this ppm-in program)
- Coach : select PPM protocol , PPM out-put (audio-left)
- Student : select PPM protocol ,
this program will get PPM in-put (audio-right) then out-put (audio-left).
- Monitor :
Use PC to capture the PPM out-put (audio-left) from Student.
Attachment Walkera_cable.jpg not found
- Monitor :
Last edit: 25 Apr 2013 08:20 by hmjack2008.
- hmjack2008
25 Apr 2013 08:44 #9193
by hmjack2008
25 Apr 2013 12:50 #9194
Replied by PhracturedBlue on topic USB HID Joystick & PPM-In program
hmjack, I don't think you understood the issue I had.
On the devo8, GPIOA.9 is connected to the 'left' pin
GPIOA.10 is connected to the 'plug connect' pin (that is it is shorted to ground once thephono jack is inserted). Nothing is connected to the 'right' pin of the phono jack. thus without hacking the radio, it is not possible to use GPIOA.10
This may be different on other radios. I did not check any of the others, buton the Devo8 at least it doesn't seem possile to use GPIOA.10 today.
25 Apr 2013 12:52 #9195
And hmjack, your picture properly describes the code I already have (but have not yet released for lack of testing) for how the trainer mode will work. The 'FPV' mode will be simpler, instead introducing new inputs for the mixer.
25 Apr 2013 14:35 #9201
Also, after switching the code to work with GPIOA.9 (and yet again re-soldering my USB port which I accidentally ripped off the Tx again), I was able to configure a trainer switch and use my Devo8 as a master and my Devo10 as the slave.
There's still a bunch of work to get the code polished up, but I have the basic functionality working now.
25 Apr 2013 14:52 #9202
Replied by rbe2012 on topic USB HID Joystick & PPM-In program
Great, this is really useful. Too bad I can not help with those things...
26 Apr 2013 01:48 #9214
I checked in the full support for PPM-In using both 'train' and 'fpv' (actually named 'input') mode.
I've done some testing with my Devo8 & 10 and things seem to work ok so far.,
Note that the 'Center PW' in 'PPM In' is not the same as the one in the PPM protocol.
the PPM In 'Center PW' is equivalent to the PPM-Out 'Center PW' + 'Notch PW'
So 'Center PW' will generally be 1500 in the PPM-In configuration
26 Apr 2013 05:23 #9216
Replied by vlad_vy on topic USB HID Joystick & PPM-In program
So, how it works now? If enabled PPM out, what happened with PPM-In? Can you explain how it works in detail?
26 Apr 2013 05:34 #9217
PPMIn will disable PPM-Out. You cannot use them together.
If trying to setup a 'master' trainer:
You need a standard mono or stereo 1/8" jack to tie the transmitters together.
The slave should be set to use 'PPM' protocol
The Master should have the proper protocol set and set 'PPM In' to 'train'
Then click on 'Train' and make sure that the PW values are set properly as well as setting a toggle switch.
You can choose to change the Master-Slave channel mapping as well. This works by taking the specified channel in the spin-box from the slave and applying it to the specified Master channel. Thus if you set:
Ch3 = <Ch5>
It means that Slave Ch5 will be attached to master Ch3
Now turn on the slave.
you can now toggle the specified switch and the Slave values will be passed to the radio on the Master.
You should be very careful using it. The code is very new, and probably has bugs.
If you lose a connection with the slave the channels will hold their last position until you flip the toggle back. I'm not sure that's the right way to do it though, so feedback would be appreciated on the whole thing.
Ch3 = <Ch5>
26 Apr 2013 06:36 #9218
Some FPV guys with external modules (PPM) very interested in simultaneous use PPM-Out and PPM-In (for headtracker).
Is it possible to do any hardware mod (e.g. trainer jack resolder) and software patch to enable such feature?
- hmjack2008
26 Apr 2013 10:15 #9222
by hmjack2008
I'm sorry to cause misunderstanding, I should have to provide this photo before.
I use the stereo audio jack, the Walkera is mono jack, they are different.
- hmjack2008
26 Apr 2013 10:17 - 26 Apr 2013 10:39 #9223
by hmjack2008
Thank PhracturedBlue , you will finish it, you do better than me !!
Last edit: 26 Apr 2013 10:39 by hmjack2008.
- Hexperience
26 Apr 2013 10:28 #9224
by Hexperience
Yep, that's me as well at the moment. I'm using ppm out for frsky module and my fpv plane has head tracking. Obviously if/when frsky protocol is working that solves my problem. (Not having enough to eat is a problem.. head tracking not working is not really a problem on the grand scale..
PB, I recall that the devo12 had something different in the ppm output. Have you had a chance to try ppm in on a devo12 yet?
CHEERS again on the great work.
Replied by Hexperience on topic USB HID Joystick & PPM-In program
vlad_vy wrote: Some FPV guys with external modules (PPM) very interested in simultaneous use PPM-Out and PPM-In (for headtracker).
26 Apr 2013 12:44 #9228
Thank you for providing the code. I uzed it mostly verbatim from the low-level stuff.hmjack2008 wrote: Thank PhracturedBlue , you will finish it, you do better than me !!
26 Apr 2013 12:51 - 26 Apr 2013 12:51 #9229
I need to open up each of my radios to see how they function. It sounds like the one hmjack used didn't need a hardware mod to access Rx pin.
certainly it is possible to replace the phono jack with a new one. The proper pins are already there, the main issue will be mounting it. Modifying the existing jack may be hard. It mostly depends on whether you can get access to the relevant trace so you can cut it. I'll give it a try.
And so far I've only actually run it on my devo8. The devo10/7e is basically the same, so it should work fine. In theory it should just work on the devo12 too. I did modify the code properly for that, but it is untested.
Last edit: 26 Apr 2013 12:51 by PhracturedBlue.
26 Apr 2013 19:24 #9241
Replied by FDR on topic USB HID Joystick & PPM-In program
I wanted to translate the new language elements of the PPM config pages, and was confused about the usage of "Ch%d" and "Ch %d" strings on the trainer channel assignment.
Wouldn't it be more clear to show "PPM%d" in the spinboxes just like they are in the source list? After all they are used here as sources too...
26 Apr 2013 19:55 #9244
yes that is probably a good idea.
I'm still trying to decide whether I'd rather have the channels mapping be from Slave->Master (i.e choose a channel on the master for each PPM channel) or Master->Slave (i.e. choose a PPM channel for each master channel, which is how it is today).
26 Apr 2013 20:41 #9249
I think the current is more clear, especially in case of none selected.
Otherwise what would you select for an unused PPM channel? "Not used", perhaps?
Actually I couldn't decide which is which where it was Ch1 = Ch 1, so using the PPM instead will self-explanatory...
27 Apr 2013 05:10 #9261
For me, at 'Trainer config' page, more natural will be place channels mapping by column, not by rows.
Time to create page: 0.163 seconds
- USB HID Joystick & PPM-In program
