When did the main page layout change?
09 Feb 2013 19:43 - 09 Feb 2013 19:44 #6180 by FDR
Now the boxes are larger, they are already touching the trims, and the bars are more to the left with larger spaces between them, reaching the trims too:
Here is the previous layout:
EDIT: Forgot to mention, that I like the old one more...
Last edit: 09 Feb 2013 19:44 by FDR.
09 Feb 2013 20:26 #6182 by PhracturedBlue
Replied by PhracturedBlue on topic When did the main page layout change?
It wasn't done on purpose by me. I agree with you, that it doesn't look right. Maybe domcars adjusted it to allow displaying really big timer values. I'll dig into it.
09 Feb 2013 20:40 - 09 Feb 2013 21:38 #6183 by domcars0
Replied by domcars0 on topic When did the main page layout change?
PhracturedBlue wrote: Maybe domcars adjusted it to allow displaying really big timer values. I'll dig into it.
That is ... This is because the permanent timer may have a value of 99:59:59...
I changed :
-#define BOX_W 100
+#define BOX_W 113
In pages/320x240x16/main_config.c
If we want to keep the previous width, we have to denied the permanent timer display on the four top Boxes main page ...
Last edit: 09 Feb 2013 21:38 by domcars0.
09 Feb 2013 21:34 #6184 by FDR
Replied by FDR on topic When did the main page layout change?
OK, I thought about that too, but why did the bars move? Do they use the same BOX_W?
BTW why did you choose such a nice prime number? :lol:
Anyway, no problem, just need to move them more to the edges...
09 Feb 2013 21:40 #6185 by domcars0
FDR wrote: OK, I thought about that too, but why did the bars move? Do they use the same BOX_W?
Probably yes ....
09 Feb 2013 22:51 - 09 Feb 2013 23:07 #6186 by domcars0
I've recentered/replaced the Boxes and GraphBars on the 320x240x16 main page.
I think now it's nice again ;)
@PB: You may take a look on my repository, I've coded the button to reset the permanent timer.
Last edit: 09 Feb 2013 23:07 by domcars0.
10 Feb 2013 06:37 #6195 by PhracturedBlue
did you test this with 'outer' trims? The boxes are too close to the toggles. if you move the bars and boxes a little toward sthe outside for this case, I think it will be good.
10 Feb 2013 09:20 #6199 by domcars0
You're right ... I forget it...
Now it's good
10 Feb 2013 13:27 #6208 by PhracturedBlue
Thanks. I'll pull once I've looked over the timer stuff
Time to create page: 0.385 seconds
