How To apply "two switches" patch for Devo7e soft
- Krejzi
24 Feb 2013 07:50 - 04 Mar 2013 17:50 #6934
by Krejzi
How To apply "two switches" patch for Devo7e soft was created by Krejzi
Hi.
First of all sorry for my language.
I have devo7e with "Two switches" mod.
"How To" from this topic:
www.deviationtx.com/forum/how-to/1436-ad...tches-to-the-devo-7e
But If you want to have a newest soft with patch for this mod, you should learn how to do it.
What you Need:
- installed VirtualBox
- imported Virtual Machine
this thread:
www.deviationtx.com/forum/how-to/1200-vm...-compiling-deviation
- patch file:
I'm goona start in the point where you've got running virtual machine.
Put file "7e_buts.patch.txt" to the c:/deviation on your machine ( NOT VIRTUAL MACHINE)
Back to VirtualMachine and type:Then type:
Now you should see somethink like:
If you've got any error just stop and check if you wrote everythink properly if yes, just put quote of error in this thread.
If something goes wrong you can revert changes, just type:And try again.
Now the final point:
Type:After this done, you have alredy compiled and ready to install on your transmiter files on your Machine i c:/deviation ( not virtual machine ).
You should have two .rar files: filesystem and dfu file.
I'm gonna share all my build which i've patched ( without filesystem ):
Please correct my language and other mistakes.
Cheers.
What you Need:
this thread:
- patch file:
cd /home/dev/deviation/patch -p1 < /media/deviation/7e_buts.patch.txtNow you should see somethink like:
patching file src/target/devo7e/capabilities.h
patching file src/target/devo7e/channels.c
patching file src/target/devo7e/tx_buttons.cIf you've got any error just stop and check if you wrote everythink properly if yes, just put quote of error in this thread.
hg revert -aNow the final point:
Type:
deviation build devo7eYou should have two .rar files: filesystem and dfu file.
Cheers.
Last edit: 04 Mar 2013 17:50 by Krejzi.
24 Feb 2013 08:07 #6935
Replied by rbe2012 on topic How To apply "two switch" patch for Devo7e
Save the text formatted as code (orange bar at the left) from your post and name the file "file.patch". Save it to your deviation build directory (where README, src/, ... resides). Then you apply the patch with "patch -p1 < file.patch" which will make the rest for you. (it takes file.patch, parses it for the changes mentioned there and applies them to the affected files).
Be aware that the files could have changed while developement goes on; I don't know if the patch-command will try it or throws errors.
Give it a try and if errors occur you can post them here so we will have a look.
- Krejzi
24 Feb 2013 08:24 #6937
by Krejzi
Replied by Krejzi on topic How To apply "two switch" patch for Devo7e
24 Feb 2013 09:12 #6938
Looks as if the last line is missing
in the patch file.}
24 Feb 2013 15:38 - 24 Feb 2013 15:39 #6957
Replied by PhracturedBlue on topic How To apply "two switch" patch for Devo7e
Here is the patch as an attachment.
Start by reverting the changes you have:
cd ~/deviation (I think this is where deviation is. if not, put the right path here)
hg revert -a
Now put the 7e_buts.patch.txt file in the current dir and rerun the patch (again you must be in the main deviation dir (with the README):
patch -p1 < 7e_buts.patch.txt
It should look like this:
now you can:
cd src
make TARGET=devo7e
hg revert -a
now you can:
cd src
make TARGET=devo7e
Last edit: 24 Feb 2013 15:39 by PhracturedBlue.
- Krejzi
24 Feb 2013 16:27 - 24 Feb 2013 16:36 #6963
by Krejzi
Everythink great.
But I use "deviation build devo7e" instead "make TARGET=devo7e".
And it looks that I have newest (almost ) soft with switch mod.
I'm gonna make the whole toutorial how to make this but for now i have to test this.
Thanks a lot guys
Thanks a lot guys
Last edit: 24 Feb 2013 16:36 by Krejzi.
- cmpang
24 Feb 2013 17:31 #6973
by cmpang
Replied by cmpang on topic How To apply "two switch" patch for Devo7e
it is too good. Why not share it up here for we all who has done the mod?
- Krejzi
24 Feb 2013 18:07 #6974
by Krejzi
I've changed first post.
- Mullson
26 Feb 2013 21:50 #7117
by Mullson
Are you still having voltage jumping (~1.0v) on throttle movement with this version?
Replied by Mullson on topic How To apply "two switches" patch for Devo7e soft
Krejzi wrote: I'm gonna share all my build which i've patched ( without filesystem ):
- Krejzi
27 Feb 2013 04:15 #7120
by Krejzi
Replied by Krejzi on topic How To apply "two switches" patch for Devo7e soft
I don't know, when i can see this issue ?
- Mullson
27 Feb 2013 07:12 #7125
by Mullson
When you move the throttle from min to max.
- Krejzi
27 Feb 2013 11:58 #7134
by Krejzi
then no, i don't see anything like that.
- Mullson
27 Feb 2013 12:16 #7135
by Mullson
So your TX volt indication up in right corner is stable all the time? And you are using "deviation-devo7e-b1b5bcecde6b.zip"? Dident you have this error in the last build ether?
- Krejzi
27 Feb 2013 12:19 #7136
by Krejzi
yes is stable all the time, bind or not bind, with devo and dsm2.
I don't know I had this issue before, I hadn't noticed that.
- Krejzi
04 Mar 2013 17:51 #7346
by Krejzi
New patched soft added in first post.
- cmpang
05 Mar 2013 00:35 #7364
by cmpang
thanks for your patch soft.. will load it later today...
Replied by cmpang on topic How To apply "two switches" patch for Devo7e soft
Krejzi wrote: New patched soft added in first post.
- cmpang
05 Mar 2013 10:24 #7380
by cmpang
new patch soft loaded and running ok.. thx
- Mullson
05 Mar 2013 11:59 #7387
by Mullson
Is this version better then devo7e-v2.3.8.1? If so what's the changes?
cmpang wrote: new patch soft loaded and running ok.. thx
- Krejzi
06 Mar 2013 10:30 #7423
by Krejzi
Actually it's not a topic about devo soft, you should try this soft.
What I know is in newer soft's a lot of bugs was fixed.
And I'm not sure but in 2.3.8.1 you don't have a Standard GUI mode, but I don't know this for sure.
I'm using a Standard GUI mode in newest soft.
- Mullson
06 Mar 2013 10:36 #7425
by Mullson
Thanks I have installed it and it works good, the switches to.
Time to create page: 0.350 seconds
- How To apply "two switches" patch for Devo7e soft
