Need testers for USBcode
27 Nov 2017 16:00 #66205 by vlad_vy
Replied by vlad_vy on topic Need testers for USBcode
It can't be compiled - ERROR
27 Nov 2017 16:57 - 27 Nov 2017 16:58 #66207 by Moeder
Replied by Moeder on topic Need testers for USBcode
Did you try building the master branch (github) with the additional build instructions in the Readme.md (concerning usb4java)?
Last edit: 27 Nov 2017 16:58 by Moeder.
27 Nov 2017 17:00 #66208 by vlad_vy
It's for new version install. Current version already installed.
27 Nov 2017 19:01 #66211 by Moeder
Was just a bad guess. I guess we need to do some more debugging of the USB connectivity in the uploader. I have neither devo nor jumper at hand to help out this week. Maybe PB can clue us what is different with his build?
27 Nov 2017 22:11 - 27 Nov 2017 22:15 #66216 by Moeder
@vlad_vy: try the build linked below (without your changes, should be a true 0.8.0) and see if it recognizes your devos
WeTransfer
edit: if it works, it's likely that the first commit after 0.8.0 introduced the bug
Last edit: 27 Nov 2017 22:15 by Moeder.
28 Nov 2017 04:23 #66221 by vlad_vy
now I can get info from Devo8:
d:\4>java -jar DeviationUpload-0.8.0-jar-with-dependencies.jar -list
Found: Runtime [00483:df11] cfg=0, intf=0, alt=0, name='1155:57105:@Internal Flash  :@SPI Flash: Config:@SPI Flash: Library'
Determining device status: statue=dfuERROR status=10
dfuERROR, clearing status
Determining device status: statue=dfuIDLE status=0
dfuIDLE, continuing
dfuIDLE, continuing
  Setting address pointer to 0x8000400
   Poll timeout 104 ms
bytes_per_hash=1024
Starting device read
Device  Interface    Start        End    Size   Count
DEVO8
                0 08004000   0803ffff    2048   120
                1 00002000   0000dfff    4096   12
                2 00010000   003fffff   65536   63
28 Nov 2017 05:43 - 28 Nov 2017 05:52 #66223 by Moeder
OK try compiling This one
Just change jdk version in pom.xml to 1.8 (twice) in this section:
<plugin>
        <groupId>org.apache.maven.plugins</groupId>
        <artifactId>maven-compiler-plugin</artifactId>
        <version>2.5.1</version>
        <configuration>
          <source>1.5</source>
          <target>1.5</target>
        </configuration>
      </plugin>
Last edit: 28 Nov 2017 05:52 by Moeder. Reason: Correct github link + code snippet
28 Nov 2017 05:56 #66224 by vlad_vy
With your previous build I get:
Found: Runtime [00483:df11] cfg=0, intf=0, alt=0, name='1155:57105:Unknown:Unknown:Unknown'
Determining device status: statue=dfuERROR status=14
error clear_status
error clear_status
dfuseDownload: libusb_control_msg returned -5
Error during special command download
Exception in thread "main" java.lang.NullPointerException
        at java.util.Arrays.copyOfRange(Unknown Source)
        at deviation.TxInfo.<init>(TxInfo.java:24)
        at deviation.TxInfo.getTxInfo(TxInfo.java:83)
        at deviation.DeviationUploader.main(DeviationUploader.java:457)
28 Nov 2017 06:08 - 28 Nov 2017 06:22 #66225 by vlad_vy
No, my compiled version This one doesn't work:
d:\deviation-upload\target>java -jar DeviationUpload-0.8.0-jar-with-dependencies.jar -list
error clear_status
error clear_status
Last edit: 28 Nov 2017 06:22 by vlad_vy.
28 Nov 2017 10:03 #66227 by Moeder
vlad_vy wrote: No, my compiled version This one doesn't work:
That is odd... Are you sure you checked it out correctly and did a clean build?
28 Nov 2017 10:13 #66229 by vlad_vy
All clean build, with deleted target and cache. Probably Windows build will not work at any case.
28 Nov 2017 10:36 - 28 Nov 2017 10:37 #66230 by Moeder
You could try building it using a more recent usb4java version, 1.0.0 is pretty old
Edit: could you send me your 0. 8. 0 build jar file for comparison?
Last edit: 28 Nov 2017 10:37 by Moeder.
28 Nov 2017 12:57 - 28 Nov 2017 12:58 #66232 by vlad_vy
Bingo! Windows 7 build works normally! I can get info from Devo8.
c:\deviation-upload\target>java -jar DeviationUpload-0.8.0-jar-with-dependencies.jar -list
Determining device status: statue=dfuUPLOAD-IDLE status=0
aborting previous incomplete transfer
dfuIDLE, continuing
dfuIDLE, continuing
   Poll timeout 104 ms
bytes_per_hash=1024
DEVO8
Last edit: 28 Nov 2017 12:58 by vlad_vy.
28 Nov 2017 14:35 #66233 by Moeder
Is that using new usb4java version and the commit 8ec03c4?
Would you mind testing the version linked below compiled on macOS 10.12.6?
WeTransfer
28 Nov 2017 14:53 - 28 Nov 2017 14:54 #66234 by vlad_vy
Nothing changed except PC and Windows version, it's commit 8ec03c4.
With current code I get errors:
dfuIDLE, continuing
dfuIDLE, continuing
   Poll timeout 104 ms
bytes_per_hash=1024
        at deviation.TxInfo.<init>(TxInfo.java:27)
Last edit: 28 Nov 2017 14:54 by vlad_vy.
28 Nov 2017 15:38 #66235 by vlad_vy
It looks like problem related to line 27 TxInfo.java, it changed after commit 8ec03c4.
28 Nov 2017 16:45 - 28 Nov 2017 16:45 #66237 by FDR
Replied by FDR on topic Need testers for USBcode
It seems to me, that we would need to call "TransmitterList.init" somewhere before that line, probably in the "DeviationUpload.main".
I didn't check if it happened or not, but judging from the "null pointer exception" rather not...
Last edit: 28 Nov 2017 16:45 by FDR.
28 Nov 2017 16:59 - 28 Nov 2017 17:05 #66238 by vlad_vy
Yes, TransmitterList.init() added. Devo8 and T8SG:
dfuIDLE, continuing
dfuIDLE, continuing
   Poll timeout 104 ms
bytes_per_hash=1024
Devo 8
dfuIDLE, continuing
dfuIDLE, continuing
   Poll timeout 104 ms
bytes_per_hash=1024
Devo 7e
                0 08003000   0803ffff    1024   244
                1 00000000   0001ffff    4096   32
                1 00020000   001fffff   65536   30
I can successfully flash Devo8, but T8SG get black screen after flashing.
Last edit: 28 Nov 2017 17:05 by vlad_vy.
28 Nov 2017 17:05 #66239 by FDR
Probably the filesystem is missing...
28 Nov 2017 17:06 - 28 Nov 2017 17:11 #66240 by vlad_vy
No, I flash DFU file only. Something is wrong.
If I flash firmware DFU with Dfuse all OK again.
    public static void main(String[] args)
        if (args.length == 0) {
        	//DnDFrame.main(null);
            DeviationUploadGUI.main(null);
            while(true) {}
        TransmitterList.init();
        CommandLine cl = handleCmdline(args);
Last edit: 28 Nov 2017 17:11 by vlad_vy.
Time to create page: 0.186 seconds
