Need testers for USBcode
24 Nov 2017 08:59 #66123 by FDR
Replied by FDR on topic Need testers for USBcode
I think we should port it to the DeviationTX GitHub repo, and maintain the code there...
24 Nov 2017 10:56 #66125 by Neuer_User
Replied by Neuer_User on topic Need testers for USBcode
vlad_vy wrote: I think that anybody need to change "transmitters.yml" and rebuild Deviation Uploader to 0.9:
bitbucket.org/PhracturedBlue/deviation-u...68c4f69f8?at=default
Probably will be enough to change "matchRules":
numChannels: 7
fsProtocols: ALL
root:
    sectorOffset: 0
    sectorCount:  512
    fsType:       FAT
    inverted:     true
matchRules:
    - "DEVO-7E.*"
    - ".*devo7e.*"
    - "7e"
    - "t8sg"
Looks like an easy change. I have, however, no experience with compiling java code (and not much with compiling anything else). Otherwise, I might have tried to do it myself.
24 Nov 2017 19:44 #66134 by Moeder
Replied by Moeder on topic Need testers for USBcode
I guess it's time to move it to github and setup Travis ;)
24 Nov 2017 19:54 #66137 by vlad_vy
Replied by vlad_vy on topic Need testers for USBcode
I can't get working version of Deviation Uploader with Windows environment. Maybe at first worth to test it locally?
24 Nov 2017 19:55 #66138 by FDR
Yep.
We only need to decide whether it should be a new repository or only a folder within deviation/utils....
24 Nov 2017 20:24 #66142 by Moeder
I vote for a separate repository.
24 Nov 2017 20:28 #66143 by FDR
That's what I was afraid of... ;)
What are the pros/cons?
25 Nov 2017 07:49 #66152 by Moeder
Why afraid? We would have a clean repo with separate CI, separate issue tracking etc.
25 Nov 2017 12:24 #66160 by FDR
25 Nov 2017 16:11 #66162 by Moeder
I added a pull request for CI using travis. The current codebase compiles fine and jar runs for me on Debian 8.6 and macOS 10.12. Remember to install JDK 8 for working with the code. Compile using
mvn package
in the base directory
25 Nov 2017 19:26 #66164 by FDR
I've added the T8SG to the 7E, but I'm not sure if it wouldn't be better to have a separate TX definition...
26 Nov 2017 02:54 - 26 Nov 2017 04:29 #66170 by Deal57
Replied by Deal57 on topic Need testers for USBcode
I also recall a problem with the Devo 12e with the uploader. The transmitter fails to be recognized, and I think it is because the script is thinking it is a 12s. My computer is down so I can't get to my notes :blush: but I'd appreciate it if someone could look at this.
This is discussed in more detail in this thread.
Thank you!
Last edit: 26 Nov 2017 04:29 by Deal57.
26 Nov 2017 07:54 - 26 Nov 2017 07:58 #66173 by vlad_vy
Can you attach test build with change for T8SG? My Windows build jar can't communicate with Tx, but "DeviationUpload-0.8.0.jar" can.
Last edit: 26 Nov 2017 07:58 by vlad_vy.
26 Nov 2017 08:12 #66174 by vlad_vy
I'm looking into DevoDetect.java and I think that change will not work, all patterns contain DEVO:
    public boolean Analyze(String id) {
        //init();
        Type thisType = Type.UNKNOWN;
        Matcher m;
        int idx;
        if ((idx = id.lastIndexOf("/")) > -1) {
            id = id.substring(idx+1);
        if ((m = Pattern.compile("devo([^-]+)-(\\S+) Firmware").matcher(id)).matches()) {
            firmware = Firmware.DEVIATION;
            version = m.group(2);
            model = TxInfo.getModelFromString(m.group(1));
            thisType = Type.FIRMWARE;
        } else if ((m = Pattern.compile("devo([^-]+)-(\\S+) Library").matcher(id)).matches()) {
            thisType = Type.LIBRARY;
        } else if ((m = Pattern.compile("deviation-devo([^-]+)-(\\S+)\\.zip").matcher(id)).matches()) {
        } else if ((m = Pattern.compile("deviation-fs-devo([^-]+)-(\\S+)\\.zip").matcher(id)).matches()) {
        } else if ((m = Pattern.compile("DEVO-([^-]+) FW\\S* (\\S+)", Pattern.CASE_INSENSITIVE).matcher(id)).matches()) {
            firmware = Firmware.WALKERA;
        } else if ((m = Pattern.compile("DEVO-([^-]+) Lib\\S* (\\S+)", Pattern.CASE_INSENSITIVE).matcher(id)).matches()) {
        if (thisType != Type.UNKNOWN) {
        	addRemoveType(thisType, true);
        return (firmware == Firmware.UNKNOWN) ? false : true;
26 Nov 2017 09:29 #66176 by FDR
Yep, it looks like we will need some more measures...
26 Nov 2017 09:49 - 27 Nov 2017 05:23 #66178 by vlad_vy
And, I don't see parsing for DevoF4, DevoF4-XMS, DevoF7-XMS, Devo F12E-XMS.
Last edit: 27 Nov 2017 05:23 by vlad_vy.
27 Nov 2017 06:07 #66193 by vlad_vy
I placed the pull request to add T8SG and Devo F4. Will be nice if anybody can build it with Linux environment and attach here for testing.
27 Nov 2017 14:21 #66200 by Moeder
I compiled from the branch in your repo and uploaded deviationUploader with dependencies to the following link (file size 4.4 MB, too much for attachment):
WeTransfer
27 Nov 2017 15:13 - 27 Nov 2017 15:54 #66203 by vlad_vy
Something wrong with USB communication.
The GUI interface working normally with T8SG firmware files, both *.zip and *.dfu. But, after flashing firmware and final OK, I get black screen.
New DeviationUpload (with option -list) can't get info from T8SG, old "DeviationUpload-0.8.0.jar" can detect it as "DEVO7e".
New DeviationUpload can't get info from Devo8 also, old "DeviationUpload-0.8.0.jar" can detect it as "DEVO8".
So, the USB communication problem is not related to Windows build. JDK version?
Last edit: 27 Nov 2017 15:54 by vlad_vy.
27 Nov 2017 15:51 #66204 by Moeder
Hmm.. Looking at the bitbucket repository there have been a few changes after the date the version on this homepage was updated. Maybe get the old sources from bitbucket.org/PhracturedBlue/deviation-u...ed7f4ddd1524e52f5c39 and try with those? Didn't look into the details...
Time to create page: 0.294 seconds
