devo 12 wide screen...
11 May 2013 15:10 #9846 by PhracturedBlue
Replied by PhracturedBlue on topic devo 12 wide screen...
The new PPMin method we were discussing in the other thread would replace the stick-input with the PPM input. If we do that, then getting the main page to show the ppm-input would just-work.
  • rbe2012
  • rbe2012's Avatar
11 May 2013 17:24 #9860 by rbe2012
Replied by rbe2012 on topic devo 12 wide screen...
Sorry, accidentally uploaded an in-work-version (and leave it there for switching my development station easier...).
For testing please use 97e0e10.
12 May 2013 14:46 #9893 by PhracturedBlue
I added a ticket with a rough implementation of how to save the state of elements below the currently selected element and restore them when they happen to fit. It makes the interface a lot nicer in my opinion, but I haven't tested it thoroughly for bugs.
Another thing that really needs to be fixed before submitting a pull request:
You have rows and columns reversed. rows go down and columns go across. I was really confused initially until I figured that out.
A little regex search and replace should fix most of it, but it definitely needs to be resolved.
Thanks again for your work on this, I think it'll be very slick when finished.
  • rbe2012
  • rbe2012's Avatar
12 May 2013 15:42 #9897 by rbe2012
PhracturedBlue wrote: I added a ticket with a rough implementation of how to save the state of elements below the currently selected element and restore them when they happen to fit. It makes the interface a lot nicer in my opinion, but I haven't tested it thoroughly for bugs.
Thank you for this, I will take a look at it as fast as I can but probably not today. An idea that came to me in between: a mechanism to determine how much elements of a special type are visible (with a "visible" flag?) could suffice. Or being generous and removing the limits...
This is something what I never noticed before yesterday when I was writing some comments in the code because I got totally confused.
For sure this has to be cleaned and I will do this next.
I had a similar interchanging of horizontal and vertical for the crosses - the horizontal stick draws a vertical line... I corrected this with the separation of the two sources but it took some time to recognize it. With columns and rows it should be more obviously.
13 May 2013 18:40 #9938 by Wene001
Replied by Wene001 on topic devo 12 wide screen...
i mentioned that trim_l and trim-r (if 6 trims are displayed) are interchanged on the display too.
  • rbe2012
  • rbe2012's Avatar
13 May 2013 18:44 - 13 May 2013 18:44 #9939 by rbe2012
I have extended my work to be able to handle a three- and a four-column-design.
As a real big benefit the new gui can completely be run on a Devo8 with its 320x240-screen.
This is especially for me a huge improvement because now I am capable to test my development with a real tx.
There are still some issues which will be corrected, but from my point of view it is usable.
Maybe I should change the title of the thread?
If you want to test: get if from my repo (links somewhere above, take commit 0e42f12). The main switch is in gui/320x240x16/gui.h (#define GUI_ADVANCED 1).
Have fun...
Last edit: 13 May 2013 18:44 by rbe2012.
  • rbe2012
  • rbe2012's Avatar
14 May 2013 11:14 #9975 by rbe2012
PhracturedBlue wrote: Another thing that really needs to be fixed before submitting a pull request:
This is fixed now.
15 May 2013 17:31 - 15 May 2013 17:55 #10034 by Wene001
good work rbe
but one thing i don´t like is the gap between the two middle columns in this view
Also it would be nice to have ppmin as input for the bars in the middle of my picture
Last edit: 15 May 2013 17:55 by Wene001.
  • rbe2012
  • rbe2012's Avatar
15 May 2013 20:21 #10040 by rbe2012
The gap looks so wide because there are no trims to fill them. This needs some fine tuning.
PPM inputs for bars are not available in the main deviation development but easy to add. I will think about this, but as long as the PPM in development is not finished this might change again.
15 May 2013 22:33 - 15 May 2013 22:33 #10043 by RandMental
Replied by RandMental on topic devo 12 wide screen...
Wene001 wrote: good work rbe
I would not necessarily see the gap as an error nor as a bad thing - having 8 equally spaced bars will be confusing for the normal eye. Although nice and symmetrical, it requires one to "count" to identify a specific bar on the fly. Normally you would have groups of up to 4 items which the brain can decode on sight, there after one split it into subgroups of 2/3, etc, to allow an intuitive recognition and grasp of the information presented.
(Just a suggestion based on a bit of experience in these things)
Last edit: 15 May 2013 22:33 by RandMental.
12 Jul 2013 11:02 #12212 by cedric
Replied by cedric on topic devo 12 wide screen...
hello, is it possible to have a version 3.0.0 Dfu upgrate Full screen for devo12?
(sorry I'm french and I do not understand all the topic, I understand that the emulator version of the most boring work but it is to have it on the radio, this is why I ask this question because it is not clear to a small french understand that not all discution in English ^ ^)
12 Jul 2013 11:07 - 12 Jul 2013 11:07 #12214 by cedric
reponce to FDR:
Devo 12 layout for template
FDR
The v3.0.0 doesn't support the full screen on a DEVO 12.
In order to have full screen support you have to wait for the next release, or use the nightly builds if you please...
Last edit: 12 Jul 2013 11:07 by cedric.
12 Jul 2013 11:11 #12216 by cedric
you think out a Full screen when official version?
31 Jul 2013 07:27 #12636 by hamdikoc
Replied by hamdikoc on topic devo 12 wide screen...
Hi
I have a new devo12
After the software update with the original walkera
constantly opening screen comes up and restarts .
I have reinstalled the software several times nothing has changed.
I tried to acess sys files with the ENT key open does not work.
Help me please
  • rbe2012
  • rbe2012's Avatar
31 Jul 2013 12:01 #12638 by rbe2012
Sorry hamdikoc,
this forum discusses a replacement firmware for the factory installed Walkera Devention firmware called "deviation". If you want to install deviation you will have to read the manual ( http://www.deviationtx.com/user-manual/user-manual-2 ) where the installation is described (don't forget to install the library too - only for Devo12).
For installing Walkera Devention again you can download the dfu-file at Walkera's web site.
If I have misunderstood you please clarify.
31 Jul 2013 13:04 #12639 by hamdikoc
Dear rbe 2012
I read the user manual.I want to install deviation but it did not work.
Because Prss ENT button and turn on radio instructions did not work.
I can not access the system files and I can not do anything.
I want your help on how to access the system files.
Thank you.
31 Jul 2013 13:08 #12640 by FDR
Replied by FDR on topic devo 12 wide screen...
Look, since you wrote this:
hamdikoc wrote: After the software update with the original walkera
...he thought you were upgrading the original Walkera firmware, which BTW doesn't have an USB mode pressing the ENT button.
So relax, and try to ask again with a bit more detail...
31 Jul 2013 13:10 #12641 by sbstnp
Replied by sbstnp on topic devo 12 wide screen...
hamdikoc wrote: I read the user manual.I want to install deviation but it did not work.
Did you flash the LIB?
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
31 Jul 2013 13:12 - 31 Jul 2013 13:13 #12643 by vlad_vy
Replied by vlad_vy on topic devo 12 wide screen...
Can you describe how you flash Devo 12?
1. Flash (upgrade) firmware from firmware archive
2. Flash (upgrade) library from filesystem archive
3. Press ENT, switch on Tx, format Tx filesystem
4. Write Tx filesystem from filesystem archive.
Last edit: 31 Jul 2013 13:13 by vlad_vy.
Time to create page: 0.302 seconds
