publishing an intermediate release 3.1.0?
22 Oct 2013 19:24 #14887 by victzh
Replied by victzh on topic publishing an intermediate release 3.1.0?
Understood. Thanks, I used fork without knowing the difference.
  • rbe2012
  • rbe2012's Avatar Topic Author
23 Oct 2013 05:47 #14889 by rbe2012
Replied by rbe2012 on topic publishing an intermediate release 3.1.0?
As WheresWaldo said I will place a pull request to PBs repo so all changes can be easily included in the main deviation repository.
For now forking my repo and placing pull requests to mine is the easiest way to get your changes integrated in the coming 3.1 version.
23 Oct 2013 11:19 - 23 Oct 2013 11:21 #14899 by vlad_vy
Replied by vlad_vy on topic publishing an intermediate release 3.1.0?
vlad_vy wrote: Possibly it was discussed already. Is it possible to remap channels mixers automatically with protocol change or it will be complex task?
It's even more complex than I think. Channels scales also remains unchanged.
Possible more safe will be save and parse model.ini file (reorder channels, change sources, boxes and so on), then again save with new protocol and reload model.ini file.
Last edit: 23 Oct 2013 11:21 by vlad_vy.
  • rbe2012
23 Oct 2013 12:28 #14901 by rbe2012
Yes, could be a way, and more and more I think it will be the best way because we easily get all occurrences of a channel in the config (and it is a simple text parsing instead of knowing what happens in the model / mixer structure and where values are stored which can refer to a channel...). We can also do some checking and skip the remapping if the prerequisites do not fit.
But I don't know how much space is required for that and if it will be implementable for all tx models.
  • rbe2012
23 Oct 2013 20:16 #14907 by rbe2012
Published beta-02 with only changes to th language files.
24 Oct 2013 14:58 - 24 Oct 2013 14:58 #14925 by vlad_vy
RBE, what is the language files *.*.1860 in language folder (filesystem archives)?
Last edit: 24 Oct 2013 14:58 by vlad_vy.
  • rbe2012
24 Oct 2013 15:27 - 24 Oct 2013 17:16 #14926 by rbe2012
Sorry - leftover from analyzing the language files (versions from commit 1860).
I did not realize that they are included in the fs-zips.
EDIT: I have uploaded the correct zip files.
Last edit: 24 Oct 2013 17:16 by rbe2012.
25 Oct 2013 16:15 - 25 Oct 2013 16:16 #14968 by WheresWaldo
Replied by WheresWaldo on topic publishing an intermediate release 3.1.0?
I have two quick questions:
  1. Are we going to use this thread for open discussions of bugs/fixes/code changes?
  2. If Deviation uses the files in /filesystem/common/layout/ during the build process is there a need to duplicate that same structure with the same files in the /filesystem/devo10/layout/ sub-directory?
I ask question #2 because clear.ini does not have a blank section for the 128x64 screen type, and for consistency it should be there even if deviation defaults to a blank model configuration screen when you load clear.ini. I modified the files and tested this with both the emulator and my devo10 and then made a pull request. The same situation applies to default.ini, why is there a need for one in common and another in the devo10 sub-directories (the devo8/12 system doesn't seem to need it and it builds correctly)?
Thanks in advance.
Last edit: 25 Oct 2013 16:16 by WheresWaldo.
  • rbe2012
25 Oct 2013 17:33 #14970 by rbe2012
Quick answer for (1): we can discuss here but I think better will be a ne thread or even an issue in my repo to have it concentrated at one place...
(2): I did not investigate those new design templates yet. I hope I can have a look at the weekend. I saw your pull request and have to understand what you want to be pulled so I have to learn about...
25 Oct 2013 20:16 #14978 by WheresWaldo
rbe2012 wrote: Quick answer for (1): we can discuss here but I think better will be a ne thread or even an issue in my repo to have it concentrated at one place...
I think I did the pull request correctly, I made two small changes to clear.ini in common/layout and devo10/layout they were simply the addition of line 4 which is "[gui-128x64]" then committed both file changes to my repo, then made a pull request to yours to pull those two files. Was that not the correct way to make a pull request?
  • rbe2012
26 Oct 2013 06:38 #14983 by rbe2012
WheresWaldo wrote: I think I did the pull request correctly, I made two small changes to clear.ini in common/layout and devo10/layout they were simply the addition of line 4 which is "[gui-128x64]" then committed both file changes to my repo, then made a pull request to yours to pull those two files. Was that not the correct way to make a pull request?
Yes, you did it correct. But I have to understand what your changes mean and since I don't know anything about the gui templates I have to read and learn...
It has nothing to do with the work you have done. I regret having been misunderstandable...
26 Oct 2013 07:09 #14985 by vlad_vy
I don't see any changes before and after I added [gui-128x64] to empty.ini file. If I load 'Empty' layout in both cases I get the same result.
  • rbe2012
26 Oct 2013 08:19 #14986 by rbe2012
I got it! It took some time to find all the relevant places in the code...
Vlad, you don't see any difference because if a section does not exist it can not contain any parameters - this leads to an empty page. But for clarifying (and because it does not cost anything, because every file is at least 4kB of size) I added it.
WheresWaldo: I have declined your pull request because I did not wand to insert a new file (the one in Devo10 folder) and made the change manually. Don't get confused.
  • rbe2012
26 Oct 2013 09:42 #14987 by rbe2012
Minor issue with the length of the version string (because it contains quotes which I didn't count). Fixed.
26 Oct 2013 09:56 #14988 by vlad_vy
RBE, can you say what I need to do to get version info? I simply download sorce files archive and build firmware, but version always = devo8-Unknown.
26 Oct 2013 11:31 - 26 Oct 2013 11:32 #14992 by WheresWaldo
RBE, you needn't worry about hurting my feelings if you decline anything I offer, I do not take offense.
Why not eliminate the filesystem\devo10\layout\ directory altogether with fix 4b971f1?
As I have mentioned before, I am not a programmer but when I see two source files with the same info I tend to want to make sure both are edited the same way, that filesystem\devo10\layout\ directory seems useless and it along with the files in it should be removed.
Note: I probably should have added the above statement to the commit on bitbucket, I am doing that now.
Last edit: 26 Oct 2013 11:32 by WheresWaldo. Reason: added Note
26 Oct 2013 12:51 #14996 by Hexperience
Replied by Hexperience on topic publishing an intermediate release 3.1.0?
Often what looks like duplicate files and folders is for the compile process. The target variables need to be there or you might not be able to compile for that particular target.
26 Oct 2013 13:18 #14998 by Lyndros
Replied by Lyndros on topic publishing an intermediate release 3.1.0?
That's great news guys I already push some changes to the main repo like two months ago ... and no body replied so I got demotivated and thought that the project was dead.
I will then fork your rbe repo and I will push there the changes.
26 Oct 2013 14:52 #15000 by RandMental
Replied by RandMental on topic publishing an intermediate release 3.1.0?
vlad_vy wrote: RBE, can you say what I need to do to get version info? I simply download sorce files archive and build firmware, but version always = devo8-Unknown.
Vlad
I think if you use Mercurial to clone the remote repo to your local drive, then you will get the hg (mercurial/bitbucket)versions included when you build the local repo. That is how I do it and I get ZRBE's 3.1-beta versions.
  • rbe2012
26 Oct 2013 16:31 #15012 by rbe2012
Vlad,
RandMental guesses right. The version is determined from the "hg log" command - you wll get a wrong version number (or "unknown") if you don't have the correct mercurial repository information. You can look at utils/get_version.pl.
Time to create page: 0.203 seconds
