publishing an intermediate release 3.1.0?
28 Nov 2013 13:50 - 28 Nov 2013 13:51 #15965
EDIT: written before reading your last post.
Replied by rbe2012 on topic publishing an intermediate release 3.1.0?
Looks like a suitable alternative. What about copyright? I have not found any hints.PhracturedBlue wrote: I modified the printf code to add snprintf support based on this:
github.com/mludvig/mini-printf
It adds less than 100 bytes of code.
I think that using snprintf will negate most of the need for tr_n.
Last edit: 28 Nov 2013 13:51 by rbe2012.
28 Nov 2013 13:56 #15966
Replied by PhracturedBlue on topic publishing an intermediate release 3.1.0?
I didn't actually use the code, just the idea for it, so copyright isn't an issue.
Why didn't you replace dlgstr? it is the largest static string in the code, and I see no reason it can't be tempstring
28 Nov 2013 14:34 #15968
I don't remember for sure... I believe I spared this for later.
28 Nov 2013 15:56 #15973
Ok, I've committed the last set of changes.
My repo should now have all the patches you have in 3.1
If you wouldn't mind getting rid of the TXID usage in pages/ that would help me out. Hopefully I didn't cause any regressions during the merge process.
28 Nov 2013 16:13 #15976
Replied by FDR on topic publishing an intermediate release 3.1.0?
In the meantime I found an other little bug: the curve editor doesn't take the invertion of the source into account.
This is not because of the merge, it is probably there for long time already...
28 Nov 2013 16:24 #15977
I'm not sure it should.
The curve editor is just defining a curve. The fact that the channel is inverted doesn't really have much to do with the defined curve.
So, we could change it if it is the right thing to do, but it isn't a bug and probably needs a bit of discussion.
28 Nov 2013 16:41 #15979
I think the cursor should move the other way - if normal, from (-100,f(-100)) to (100,f(100)); if inverted from (100,f(100)) to (-100,f(-100)), but the curve should look the same.
28 Nov 2013 16:44 - 28 Nov 2013 16:45 #15982
OK, just try to create the needed curve, when the source is inverted...
But you are right, it doesn't apply the scale and offset either, so it will be different in the curve editor anyway...
Last edit: 28 Nov 2013 16:45 by FDR.
28 Nov 2013 20:56 - 28 Nov 2013 20:56 #16000
Give my latest code a try.
I reversed the graph when the input is negated.
I also added the ability to select the nearest point when using touch to define a curve, so you don't need to 1st select a point and then its position.
Last edit: 28 Nov 2013 20:56 by PhracturedBlue.
28 Nov 2013 21:13 #16003
It's cool!
Finally I can draw the curve with dragging, at least in the emulator!
28 Nov 2013 21:18 #16004
I haven't pulled out my Tx yet, so I've only tested it in the emulator as well. I'm not sure how it'll work on a real Tx, but it is worth a try.
29 Nov 2013 04:02 - 29 Nov 2013 04:16 #16014
Replied by vlad_vy on topic publishing an intermediate release 3.1.0?
Last edit: 29 Nov 2013 04:16 by vlad_vy.
29 Nov 2013 04:14 #16015
29 Nov 2013 04:28 #16016
I had setup the emulator to use our internal sprintf implementation to get more thorough testing. But it doesn't support %f which is why you saw that.
I've fixed both the issues you mentioned.
29 Nov 2013 04:50 #16017
Thanks, now all looks fine!
- richardclli
29 Nov 2013 05:31 #16018
by richardclli
Replied by richardclli on topic publishing an intermediate release 3.1.0?
So the latest version in PB's repository is beta-5?
29 Nov 2013 06:05 - 29 Nov 2013 06:06 #16019
Beta-15
Last edit: 29 Nov 2013 06:06 by vlad_vy.
- blackmoon
29 Nov 2013 10:55 - 29 Nov 2013 10:57 #16032
by blackmoon
Replied by blackmoon on topic publishing an intermediate release 3.1.0?
Looked on the nightlies page it was beta05
Then, just compiled and it still says deviation-devo7e-v3.1.0-beta-05-6f0119d.zip, not 15...
Typo ?
Typo ?
Last edit: 29 Nov 2013 10:57 by blackmoon.
29 Nov 2013 12:20 #16033
I don't know why it is beta-05, but PB repository now include all RBE changes up to beta-15.
29 Nov 2013 13:33 #16035
PB has taken the first of my commits where I added these beta-tags but not all so numbering stops at -05 actually.
I would recommend tagging with beta-16 since there are some differences.
Time to create page: 1.050 seconds
- publishing an intermediate release 3.1.0?
