publishing an intermediate release 3.1.0?
16 Oct 2013 13:23 - 16 Oct 2013 13:24 #14705 by RRacer
Replied by RRacer on topic publishing an intermediate release 3.1.0?
rbe2012 wrote: ...
How can we see if the switches are integrated if they are not active? There is no way to detect an open line inside the tx... So we have to store somewhere the information that this tx has the switches mod done.
I don't think you have to add anything to the tx.ini file. The user would know what mods have been done to his transmitter.
The switches (connected or not) could have fixed names, and it is up to the user to select the switches for his configuration.
This is pretty much like the differences between any two tx's, they have different types and number of knobs and switches, and if you don't have them you can't use them.
The only difference is that on an unmodded tx you could select switches you don't have.
For the first time users of Deviation, those switches could perhaps be marked with '*' to point out that they are optional hardware.
Oh, and by the way, great idea with the 3.1 release.
Last edit: 16 Oct 2013 13:24 by RRacer.
17 Oct 2013 00:04 #14710 by richardclli
Replied by richardclli on topic publishing an intermediate release 3.1.0?
Nice, I can contribute to test out the 3.1.0 pre-release in my normal flight.
17 Oct 2013 03:15 #14711 by Kdean
Replied by Kdean on topic publishing an intermediate release 3.1.0?
Ok, just to be clear. The plan is to use the latest nightly (as it is) to be the 3.1 release?
I will soon have an 8s to go along with my 12s and will be updateing to the latest nightly. Or will there be changes to the latest nightly before it goes to 3.1 status?
17 Oct 2013 05:09 #14713 by WheresWaldo
Replied by WheresWaldo on topic publishing an intermediate release 3.1.0?
Kdean wrote: Ok, just to be clear. The plan is to use the latest nightly (as it is) to be the 3.1 release?
I think the plan is that the current nightly plus the few critical bug fixes will be the 3.1, then the programmers can look at adding features.
17 Oct 2013 08:24 #14715 by cmpang
Replied by cmpang on topic publishing an intermediate release 3.1.0?
RRacer wrote:
rbe2012 wrote: ...
........I don't think you have to add anything to the tx.ini file. The user would know what mods have been done to his transmitter...
the point here is to avoid causing any confusion to the casual user that has NOT done the mod...
17 Oct 2013 10:21 - 17 Oct 2013 10:23 #14718 by RRacer
cmpang wrote:
RRacer wrote:
rbe2012 wrote: ...
Yes, that's why I suggested this:
RRacer wrote: For the first time users of Deviation, those switches could perhaps be marked with '*' to point out that they are optional hardware.
It will be fairly obvious that you have selected the wrong switch when you try to flick it and it's not there!
Last edit: 17 Oct 2013 10:23 by RRacer.
  • rbe2012
  • rbe2012's Avatar Topic Author
17 Oct 2013 12:39 #14721 by rbe2012
Replied by rbe2012 on topic publishing an intermediate release 3.1.0?
We will fix the most important issues in the nightlies, but not add additional features.
Even if the nightlies are stated to be more stable than the 3.0.0 is there are a few things which are not working correctly or can lead to a reset in bad conditions. Because we know them we can not ignore them...
  • rbe2012
17 Oct 2013 13:40 - 17 Oct 2013 15:27 #14723 by rbe2012
I have copied it to the new repo.
EDIT: ...and fixed it.
Last edit: 17 Oct 2013 15:27 by rbe2012.
  • rbe2012
17 Oct 2013 17:04 - 21 Oct 2013 11:19 #14730 by rbe2012
rbe2012 wrote: Ok. I have made the first step and cloned PhracturedBlue's repository into a new clean one called deviation-3.1 .
I have fixed the first issues:
  1. PB #422: rename virtual channels in Devo10
  2. PB #421: Devo10 German language file causes chrashes
  3. Edit: PB #409: Bigbox nut fully implemented on Devo7e/10
  4. PB #413: emulator for Devo6
  5. PB #414: rework chantest_page
  6. PB #423: Trim page doesn't save trim step changes
  7. PB #411: Italian language file truncated
  8. Bargraphs not working for Devo7e/10
The list is empty now... for a short while.
Here is the list of bugs reported in PBs repo:
#32: Nine-Eagles binding with non-telemetry module
#56: Model won't re-connect when Tx is rebooted.
#60: Fixed ID is not the same assigned by Walkera radios
#195: Virt channel as a source
#334: devo10-v3.0.0 rebooted
#352: AR7200BX Compatibility Issue
#356: Errors.txt is not generated on Devo12
Edit: fixed #360: Currently selected model not saved as current model
#370: Devo 12 sliders
#373: Devo 7e Hangs going to menu
#374: Devo 7e Reboots on moddel resett
#375: DEVO 8s start bug
#382: Devo 12 reboot with telemetry
Edit: fixed #383: Touch screen position
#386: Dev08s Reset while using Flysky V911 protocol
#387: devo10 hangs at bootup
#388: Standard Mixer GUI
#389: Devo 12 Issue
Edit: fixed #402: Telemetry box changed after model change
Edit: fixed #404: toggle_select.c miscalculates scrollbar
Edit: fixed #409: Devo10 reboot in main page config nightly build 07/07/2013
Edit: fixed #411: Italian language file truncated
Edit: fixed #412: 320x240: ok/cancel on reorder page
Edit: fixed #414: Devo6: button test page error due to missing trim buttons
Edit: fixed #415: Wrong elements selected in listbox
Edit: fixed #417: display.c can not handle header_time if no RTC found
#419: Flysky protocol option always Off after reboot on Devo7e
#420: Fatal reboot on DEVO 8S and 2.1.1 deviation
#421: Devo 10 German Language file causes crashes
#422: DEVO 10 - Rename virtual channels
The green colored are already fixed, for the blue colored I have solutions.
I have solutions for #404, #412, #415 and #417 which I can add.
I also have done some work for increasing the accuracy of the touchscreen (#383) in Devo12 which was reported to be bad. I would like to add this too.
What about the rest?
And above only the bugs are listed. What about the proposals, enhancements...?
Last edit: 21 Oct 2013 11:19 by rbe2012. Reason: many issued fixed (2013-10-21)
17 Oct 2013 17:56 #14731 by victzh
Replied by victzh on topic publishing an intermediate release 3.1.0?
I have a small fix for V202 protocol, can I make pull request against your repo?
17 Oct 2013 18:20 #14733 by FDR
it's not really a bug, just not implemented
not a bug
there was no decision about this one
probably same as #389
#389: Devo 12 Issue
probably same as #360
I don't see any protocol options for Flysky at all... :unsure:
This bug probably has already corrected in v3.0.0
I would say, don't care about those, which you can't reproduce...
17 Oct 2013 18:26 #14735 by WheresWaldo
One of the first rules of QA, if you can't reproduce it, it never happened! ;)
I would say that priority one is squash bugs that result in a reboot or loss of control, those things are what causes accidents and injuries.
  • rbe2012
17 Oct 2013 18:52 #14736 by rbe2012
FDR wrote: #419: Flysky protocol option always Off after reboot on Devo7e
There is one: "WLToys V9x9" can be on or off...
Agreed, but I will need some help with Devo7e and Devo10 transmitter (Devo6 has minor imprtance from my point of view).
Thank you for your evaluation.
I will restart work on deviation on Monday (perhaps some hours on Sunday).
17 Oct 2013 19:09 #14737 by FDR
Strange! It is there in the emu_devo10, but missing from the 8 and 12!
17 Oct 2013 22:10 #14740 by Kdean
What kind of time frame are we looking at for this release? The 8s will be here next week so it will be my first test subject to the 3.1 firmware.
18 Oct 2013 02:00 #14742 by richardclli
I am using current nightly build with this Rx without any problem. So I think we can just skip this one.
18 Oct 2013 03:22 #14743 by vlad_vy
Replied by vlad_vy on topic publishing an intermediate release 3.1.0?
RBE, can you fix:
#389: Devo 12 Issue
It's very annoying when I change/view settings for several models.
It's confuse me (and others) when changing models with Devo and DSM2/DSMX protocols.
  • rbe2012
18 Oct 2013 06:35 #14746 by rbe2012
FDR wrote:
rbe2012 wrote: There is one: "WLToys V9x9" can be on or off...
I just looked into the code. I will check this.
  • rbe2012
18 Oct 2013 06:43 #14747 by rbe2012
Kdean wrote: What kind of time frame are we looking at for this release? The 8s will be here next week so it will be my first test subject to the 3.1 firmware.
My personal idea:
I can spend two more days for intense working on deviation (Monday and Tuesday next week), the other days I will have to work and care for the family... I hope I can solve some more issues (esp. #360, #389 which are annoying vlad; take a look in #402 but no way for testing due to a lack of Spektrum telemetry receivers here). Maybe I have a chance to confirm that #352 (AR7200BX) is no general problem this weekend.
So I hope the main issue fixing work will be done until the end of next week so we can publish a 3.1-alpha. We should take one week or two for testing and release the final 3.1 in mid-November.
Time to create page: 0.427 seconds
