publishing an intermediate release 3.1.0?
29 Nov 2013 13:48 - 29 Nov 2013 13:57 #16036 by vlad_vy
Replied by vlad_vy on topic publishing an intermediate release 3.1.0?
Devo protocol telemetry monitor color indication is messed.
bitbucket.org/PhracturedBlue/deviation/i...devo8-devo-telemetry
It looks like DSM2/X telemetry monitor color indication also is messed.
Last edit: 29 Nov 2013 13:57 by vlad_vy.
29 Nov 2013 14:57 - 29 Nov 2013 14:57 #16038 by HappyHarry
Replied by HappyHarry on topic publishing an intermediate release 3.1.0?
So its ok to pull from pb's repo again now?
Last edit: 29 Nov 2013 14:57 by HappyHarry.
29 Nov 2013 15:15 #16040 by PhracturedBlue
Replied by PhracturedBlue on topic publishing an intermediate release 3.1.0?
I specifically chose not to merge the 'beta' tags after I manually implemented Rbe's change because there was no way to make them identical to rbe's original.
I haven't decided to continue using them (the nightlies will be updating, so I'm not sure of the value of having them in my trunk)
29 Nov 2013 15:38 #16041 by PhracturedBlue
vlad_vy wrote: Devo protocol telemetry monitor color indication is messed.
Is this something new? I don't see any changes to the telemetry code for a long time.
I don't see any odd behavior on the emulator. Once I break out my transmitters again, I'll take a look.
29 Nov 2013 15:45 #16042 by vlad_vy
I don't know how long time it has place. I didn't use telemetry monitor very long time.
  • rbe2012
  • rbe2012's Avatar Topic Author
29 Nov 2013 16:55 #16053 by rbe2012
Replied by rbe2012 on topic publishing an intermediate release 3.1.0?
PhracturedBlue wrote: I specifically chose not to merge the 'beta' tags after I manually implemented Rbe's change because there was no way to make them identical to rbe's original.
Actually you have a tag "v3.0.0-beta-05" in your trunk - to avoid confusion I recommend to remove the beta tags or set a completely new one (does not matter if it's named beta-16 or else).
29 Nov 2013 17:06 #16055 by PhracturedBlue
sorry, I meant that the changes that were exactly the same still have them, and those that are different don't.
But yes, I removed all the beta tags. I don't think about my code as having stable point. If I push to the repo, I expect it to be stable (though it isn't always so)
  • rbe2012
29 Nov 2013 17:11 #16057 by rbe2012
Works on my Devo8 so far, just an issue with icon selection found. I will collect them before reporting.
29 Nov 2013 18:04 - 29 Nov 2013 18:09 #16065 by vlad_vy
Trim setup do not work, with emulator and Devo8. I can change trim step, but nothing more.
Last edit: 29 Nov 2013 18:09 by vlad_vy.
29 Nov 2013 18:18 #16069 by PhracturedBlue
It works for me. Can you be more precise what doesn't work?
30 Nov 2013 01:59 - 30 Nov 2013 02:12 #16080 by PhracturedBlue
vlad_vy wrote: Trim setup do not work, with emulator and Devo8. I can change trim step, but nothing more.
This appears to only occur when using the standard mixer. I'll look into it
Never mind. I have no idea what I was doing earlier, but I see it now too.
Last edit: 30 Nov 2013 02:12 by PhracturedBlue.
30 Nov 2013 02:44 #16081 by PhracturedBlue
Rbe:
Can you explain the behavior that led you to implement f2c209f7c61e (resolve 423)? I can't reproduce that behavior on earlier builds, and this change seems to have completely broken saving trims.
That makes sense since the logic is to save the trim data in a temporary struct and copy it into 'Model' once the save happens. But obvviouslythere must have been an issue or you wouldn't have changed it.
For now I've reverted that patch.
  • rbe2012
30 Nov 2013 06:56 #16083 by rbe2012
Yes, I'll look into. It's some time ago...
  • rbe2012
30 Nov 2013 08:11 #16084 by rbe2012
The motivation for this change was that when editing a trim value and changing the trim step, this value was not shown on the overview page after exiting with ok, but with cancel. It seemed clear to me that the conditions are inverted so I re-inverted it.
It was the wrong solution.
The reason for this behavior is that set_trimstep_cb() works on the Model.trim, not on tp->trim while okcancelcb() copies the tp->trim where the trim step is not changed. The problem is: if we simply change this (work on tp->trim.step), in the overview page all trim step values are identical.
The solution is not to copy the complete struct trim to Model.trims[x] but to spare trim.step (pages/common/_trim_page.c):
static void okcancel_cb(guiObject_t *obj, const void *data)
    (void)obj;
    if (data) {
        //Reset trim here (automatically saved in the Model.trim[])
        struct Trim *trim = MIXER_GetAllTrims();
//        trim[tp->index] = tp->trim;
        trim[tp->index].neg = tp->trim.neg;
        trim[tp->index].pos = tp->trim.pos;
        trim[tp->index].src = tp->trim.src;
        trim[tp->index].sw = tp->trim.sw;
        MIXER_RegisterTrimButtons();
    PAGE_RemoveAllObjects();
    PAGE_TrimInit(0);
I pushed a correction to my repo.
  • rbe2012
30 Nov 2013 10:43 #16087 by rbe2012
PB, do you remember why the rf monitor was disabled? I had some requests for it and it is not too hard to re-enable, but I did not want to do that without knowing the reason for disabling.
30 Nov 2013 11:35 #16088 by PhracturedBlue
Thanks for debugging Rbe. I've fixed this in my repo (though I chose a different solution than you)
As for the radio monitor, in practice it is virtually useless. At worst, it gives a false sense of knowing what is going on. If you want, you can add a 'HAS_RADIO_MONITOR' but it should be left disabled by default.
30 Nov 2013 13:44 #16091 by WheresWaldo
Replied by WheresWaldo on topic publishing an intermediate release 3.1.0?
I want to apologize in advance for this question especially if it is stupid. I am not a programmer but more of User Interface guy and I have a question about memory usage. Is there a significant difference in memory usage using separate screen pages (with no user interaction) or a modal dialog box?
30 Nov 2013 15:35 #16092 by PhracturedBlue
Generally, No.
We've already 'paid' for all of the graphical elements, so putting them on a page has minimal cost. Creating a new element type can be costly depending on what it is. Most of the cost of a new page is the logic that defines what it does.
30 Nov 2013 19:27 #16094 by PhracturedBlue
Rbe,
Another bug for you to look at:
#431
It is caused by patch a51e777df3e8
Specifically by this:
   if (type == ELEM_MODELICO) {
        if (*h > LCD_HEIGHT - 32) *h = LCD_HEIGHT - 32;
        if (*w > LCD_WIDTH)       *w = LCD_WIDTH;
        if (*x + *w > LCD_WIDTH)  *x = LCD_WIDTH - *w;
        if (*y + *h > LCD_HEIGHT) *y = LCD_HEIGHT - *h;
in GetWidgetLoc()
I'm not sure what this is for. I guess the -32 is for the Devo8 header (which isn't the same size on the Devo10), but I'm not exactly sure of the intent here. If the image is too bug, it seems to drop it into the lower right corner of the screen. I'd think you would leave x and y alone, and just adjust w and h if the image doesn't fit on the screen. If you are trying to center the image than this won't work if the image is smaller, so I guess that isn't the intent.
My fix would be:
        if (*y + *h > LCD_HEIGHT) *h -= LCD_HEIGHT - (*y + *h);
        if (*x + *w> LCD_WIDTH)   *w -= LCD_WIDTH - (*x + *w);
But I'm not sure that is what you intended.
01 Dec 2013 00:59 - 01 Dec 2013 01:08 #16099 by HappyHarry
I've came across a bug that happened before that was corrupting model ini's stopping access to dual rates screen, plus more importantly it totally disables the right stick output, as in on my mode 2 setup it disables aileron and elevator output completely. This is on a 7e, using a build done from pb's repo tonight, with the hisky patch applied. Version number finishes 2db21e1. I've finally worked out how to make it happen, just enable ppm as the protocol and enable standard GUI.
Last edit: 01 Dec 2013 01:08 by HappyHarry.
Time to create page: 0.363 seconds
