devo7e install both A7105 and NRF24L01
20 Dec 2013 03:21 #16815 by yuqiang
hi guys,
I installed A7105 and it worked well(on A13), but after I installed NRF24L01 on A14 and setup TX.ini, A7105 does not work!
Devo7e can not boot up, it seems blocked at A7105 init, If I remove the connection of VDD on NRF24L01, devo7e works well with A7105.
That means A7105 and NRF24L01 can not be installed together?
Thanks for your help~
PS: NRF24L01 module works well with STM32 dev board.
20 Dec 2013 04:08 #16816 by vlad_vy
Replied by vlad_vy on topic devo7e install both A7105 and NRF24L01
Is you A7105 module connected to TMS pin and NRF24L01 module connected to TCK pin on main board?
Can you list all other connections of NRF24L01 module?
20 Dec 2013 05:06 #16818 by yuqiang
Replied by yuqiang on topic devo7e install both A7105 and NRF24L01
hi vlad_vy,
Thanks for your help.
A7105 --> TMS
NRF24L01 --> TCK
I connected NRF24L01 just follow here: www.hacksmods.com/2013/05/nrf24l01-devo7e-pinout/
20 Dec 2013 05:14 - 20 Dec 2013 06:12 #16819 by vlad_vy
Both modules can work together. Check connection MOSI and MISO lines, probably you can interchange that lines. At any case it seems you have some hardware conflict.
Last edit: 20 Dec 2013 06:12 by vlad_vy.
20 Dec 2013 07:10 #16822 by yuqiang
thanks, I will check hardware connection again,
just make sure they can work together~
Time to create page: 0.056 seconds
