devo 7e deviation 4.0.0 - 2 switch patch problem
- southtirol32
01 Jan 2014 14:55 #17636
by southtirol32
devo 7e deviation 4.0.0 - 2 switch patch problem was created by southtirol32
happy new year!!
i have try to patch deviation 4.0.0 (deviation building station) whit the 2 way patch for devo7e 7e_buts.patch.txt whit errors result..., its possible that not support 4.0.0 ?!,
you can help me?!
very nice job, the build is great!!
you can help me?!
01 Jan 2014 15:08 - 01 Jan 2014 15:09 #17641
Replied by PhracturedBlue on topic devo 7e deviation 4.0.0 - 2 switch patch problem
there were several files that moved around, and thatis probably the issue.
in your patch file replace common_devo with common/devo everywhere and it'll probably apply again.
Last edit: 01 Jan 2014 15:09 by PhracturedBlue.
- southtirol32
01 Jan 2014 17:19 #17648
by southtirol32
Replied by southtirol32 on topic devo 7e deviation 4.0.0 - 2 switch patch problem
hi, the problem is the patch, i send a screenshoot
Attachment DeviationBuildStation.png not found
01 Jan 2014 18:09 #17659
Replied by rbe2012 on topic devo 7e deviation 4.0.0 - 2 switch patch problem
I think we need a new patch... maybe I will find some time tomorrow...
- blackmoon
01 Jan 2014 18:33 - 01 Jan 2014 18:33 #17661
by blackmoon
Replied by blackmoon on topic devo 7e deviation 4.0.0 - 2 switch patch problem
ho please pretty please and a two 3-positions switches patch to, to bring joy and happiness for the new year to come
Last edit: 01 Jan 2014 18:33 by blackmoon.
- kreidler
01 Jan 2014 19:50 - 01 Jan 2014 19:51 #17671
by kreidler
Replied by kreidler on topic devo 7e deviation 4.0.0 - 2 switch patch problem
The old patches from here:
www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e
always stuck on the last lines of tx_buttons.c which can be easily corrected manually.
I applied the 2-two switch and the 1-three switch patches without any problems. There might be problem with your patch file.
Please find attached both patches as they are working on my system with the addition that the switches are working in the emu also.
Last edit: 01 Jan 2014 19:51 by kreidler.
- southtirol32
01 Jan 2014 21:25 #17684
by southtirol32
hi kreidler
emu patch?!what is this?? i search a 2 way patch for the devo 7e to compiling whit the deviation build station, the emu patch don´t go..
- kreidler
01 Jan 2014 22:07 #17685
by kreidler
I do not know if the VM of the Build station is somehow limited. The attached patch works and adds also the functionality to the emulator even if you do not use it.
Maybe sbstnp as the developer can clarify.
- HappyHarry
01 Jan 2014 22:39 - 01 Jan 2014 22:41 #17687
by HappyHarry
Replied by HappyHarry on topic devo 7e deviation 4.0.0 - 2 switch patch problem
here is a modified version of the 1 3way switch patch, this patches to the current code without errors
Last edit: 01 Jan 2014 22:41 by HappyHarry.
- marciaa
02 Jan 2014 02:14 #17699
by marciaa
Replied by marciaa on topic devo 7e deviation 4.0.0 - 2 switch patch problem
esky big lama
esky big lama
- John-Boy
02 Jan 2014 06:00 - 02 Jan 2014 06:01 #17709
by John-Boy
Replied by John-Boy on topic devo 7e deviation 4.0.0 - 2 switch patch problem
Hi Marciaa,
Would you post a link to the patched versions you made?
I added a 3 way switch for multiwii use to my 7e.
I haven't had any luck with building a 'patched version...
Just me I guess....
John L.
Just me I guess....
John L.
Last edit: 02 Jan 2014 06:01 by John-Boy.
- dianjing
02 Jan 2014 06:08 #17710
by dianjing
Replied by dianjing on topic devo 7e deviation 4.0.0 - 2 switch patch problem
can you help me to add 3sw to 7e ver4.0
thank you
thank you
- HappyHarry
02 Jan 2014 15:03 - 02 Jan 2014 15:13 #17737
by HappyHarry
you can find my 4.0 7e 3way switch build here >>
www.deviationtx.com/forum/builds/2531-4-...ra-toggle-icon#17736
and my 4.0 7e 2 x 2way switch build here >>
www.deviationtx.com/forum/builds/2532-4-...ra-toggle-icon#17738
also dianjing you have sent me an encrypted pm, without the encryption password i can't decrypt and read it?
Last edit: 02 Jan 2014 15:13 by HappyHarry.
02 Jan 2014 16:39 #17745
I think that is just a bug in the PM system. There is no way of encrypting a PM in our board, and likely no way to decrypt it either.
For future reference, sending the same message to multiple users and/or posting the same question in multiple threads is not acceptable practice on this board.
- HappyHarry
02 Jan 2014 16:55 #17748
by HappyHarry
I think this happens when you select the 'password' checkbox and input a password, but if the person on the receiving end doesn't have the password its pointless using it.
- southtirol32
02 Jan 2014 19:25 - 02 Jan 2014 20:24 #17768
by southtirol32
i don´t understand why its not possible to compile, is the nightly v4.0.0-b5ebe69, the patch is attached´:, it´s possible that the building station has a problem ?
Last edit: 02 Jan 2014 20:24 by southtirol32.
- HappyHarry
02 Jan 2014 19:28 - 02 Jan 2014 19:33 #17769
by HappyHarry
you can find working patches in the same posts as my builds, and there is nothing wrong with sbstnp's vm build machine as i have just tested it, i dowloaded the latest source from pb's repo, applied the two 2way switch patch, and compiled the firmware on it without issue
Last edit: 02 Jan 2014 19:33 by HappyHarry.
- dianjing
02 Jan 2014 21:36 #17776
by dianjing
- dianjing
02 Jan 2014 21:52 #17780
by dianjing
- dianjing
02 Jan 2014 21:53 #17781
by dianjing
can you help me again. to send me the new firmware for 2*3sw .
thank you !!
thank you !!
Time to create page: 0.302 seconds
- devo 7e deviation 4.0.0 - 2 switch patch problem
